LS Engine Wiring Harnesses - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 06-29-2016, 03:49 PM   #151 (permalink)
Pacific Fabrication's Avatar
Member # 127840
Thanks for the orders!
Follow us on
Pacific Fabrication is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 02:15 PM   #152 (permalink)
Member # 127840
Contact us for a quote today!
Follow us on
Old 01-04-2017, 05:11 PM   #153 (permalink)
Member # 205109
Would you be able to make a harness with a metal braid sleeve such as copper or stainless, and how much would that add to the cost?
1986 CJ7
www.lsxjeep.com
Deino is offline   Reply With Quote Quick reply to this message
Old 01-06-2017, 06:50 PM   #154 (permalink)
Member # 127840
While we could put a metal braid sleeve on a harness, I wouldn't recommend it. You would run the risk of frequency or electrical interference as well as the possibility of the metal braid chaffing a wire and causing an electrical short or possibly worse. If you still wanted to do it I would at least want to put heatshrink on all the wires prior to adding the sleeving to minimize the possibility of issues. This would be pretty labor intensive though.
Follow us on
Old 02-21-2017, 10:05 AM   #155 (permalink)
Member # 497753
Need a harness for a 4l80e tranny, but just from the main connector off the engine harness back to the tranny. Is this something you can do? Engine is a L29
K5BEAST is offline   Reply With Quote Quick reply to this message
Old 02-23-2017, 01:03 PM   #156 (permalink)
Member # 127840
PM sent
Follow us on
Old 03-07-2017, 04:34 PM   #157 (permalink)
Member # 110237
phreddei166 is offline   Reply With Quote Quick reply to this message
Old 05-08-2017, 05:28 PM   #158 (permalink)
Member # 127840
Follow us on
Old 06-19-2017, 05:25 PM   #159 (permalink)
Member # 127840
Thanks for your continued support! Have a question? Don't hesitate to ask! We are here to help.
Follow us on
Old 09-13-2017, 10:57 AM   #160 (permalink)
Member # 127840
Each harness is hand built for that perfect fit. Give us a call for a customized quote!
Follow us on
Old 09-13-2017, 03:28 PM   #161 (permalink)
Member # 127840
Follow us on
Old 09-14-2017, 11:55 PM   #162 (permalink)
Newbie
theorangejeep's Avatar
Member # 754601
Nice wiring harness, I'm going to start collecting things for an LS swap. I will be giving you guys a call when I'm ready for wiring.
USAF OEF Veteran. Owner of a 2006 Jeep TJ.
Instagram @theorangejeep
theorangejeep is offline   Reply With Quote Quick reply to this message
Old 09-15-2017, 10:01 AM   #163 (permalink)
Member # 127840
Sounds good! If you have any questions along the way feel free to reach out. I'd be more than happy to discuss your build with you and help you out any way I can.
Follow us on
Old 09-22-2017, 10:47 AM   #164 (permalink)
Jeepman14wheel's Avatar
Member # 46071
Running an LQ4 (408 stroker), 6L80E, Magnum Doubler, NP205.
Need a harness w/ transmission & fan
Jeepman14wheel is offline   Reply With Quote Quick reply to this message
Old 09-22-2017, 11:40 AM   #165 (permalink)
Member # 127840
PM sent
Follow us on
Old 10-25-2017, 05:13 PM   #166 (permalink)
Member # 127840
Follow us on
Old 01-05-2018, 05:14 PM   #167 (permalink)
CamJake3's Avatar
Member # 120342
Quote for a dbc 5.3/4l60e harness with dual fans. With braided loom if possible...
Thanks
SI VIS PACUM PARABELLUM
_____________________________________________
My (old)crapcan
CamJake3 is offline   Reply With Quote Quick reply to this message
Old 01-08-2018, 09:53 AM   #168 (permalink)
Member # 127840
PM sent
Follow us on
