NWF Eco Box Billet Planetary Doubler Case - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 06-28-2017, 04:38 PM   #151 (permalink)
NorthWestFab's Avatar
Member # 40695
Originally Posted by caliZuki View Post
Yes, id sure like too.. think it can be done?
Not with an EcoBox.
We made a couple custom ones for a local customer. there are floor board mods and shifter mods. the work part is making the transmission mate to the BlackBox Input we have a flange with the sami pattern but if you dont move the tcase back its really hard to make a midshaft work without vibrations.
Kris
NWF
The Little BIG Guys.
250-248-6024
NorthWestFab is offline   Reply With Quote Quick reply to this message
Old 06-29-2017, 07:40 PM   #152 (permalink)
caliZuki's Avatar
Member # 665490
Thank you for the info. if you ever want to make one for a sammy. ill be your tester haha. thanks a bunch
86 samurai with stuff.
caliZuki is offline   Reply With Quote Quick reply to this message
Old 06-30-2017, 06:22 AM   #153 (permalink)
Member # 40695
Like i said we already made a BlackBox for the Sami, we will not be making an "EcoBox" as well, there are too many special parts required to work. i still have enough parts to build Sami BlackBox, they retail at $2049 without a shifter if you want a cable shifter they are $199.
Kris
NWF
250-248-6024
Old 09-08-2017, 03:06 PM   #154 (permalink)
Member # 43820
So I guess I'll ask one more time before I buy an atlas. Are you guys ever going to do a 25 spline ford box? You posted about it ages ago, but then nothing.
Sent from my SAMSUNG-SM-G930A using Tapatalk
99 ford ranger 4.0 4x4 with some 33s workin on the SAS swap.
ben10 is offline   Reply With Quote Quick reply to this message
Old 09-12-2017, 07:15 AM   #155 (permalink)
Member # 40695
We are going to be doing a 1350/1354 doubler eventually but we have no ETA as to when it will be available. we also make an adapter to go from the 25 Spline to 23 or 31 spline.
Kris
NWF
250-248-6024
Old 10-03-2017, 12:37 PM   #156 (permalink)
Member # 169347
Great product btw; do you ever have issues with high temps coming from the crawl box? I always run my np205 in low, but i shift the crawl box to high when im traveling between obstacles. The front box gets very hot....should i consider this normal?
85 4Runnner Truggy- 4.3, rmvb th350,205 doubler, Fox CO's, Link'd f & r on D60/14B, on 47's
bbtank45 is offline   Reply With Quote Quick reply to this message
Old 10-03-2017, 12:45 PM   #157 (permalink)
Member # 40695
Yes this is normal, There isnt alot of gear oil to dissipate the heat plus the Unit would get little to no air flow. That why we suggest 75/90 full synthetic changed every time you do an engine oil change. it only holds 500ml of oil so frequent changes are necessary.
Kris
NWF
250-248-6024
Old 10-03-2017, 01:13 PM   #158 (permalink)
Member # 169347
Kris
NWF
Got it, thanks Kris. Appreciate it.
Old 11-02-2017, 07:23 PM   #159 (permalink)
Member # 92978
I'm looking at an eco box. I am running a 32 spline NV4500 and a 32 spline Ford NP205. Can you tell me how much length the Eco box would add? Also, under the options on your website, there's a dual oiling billet bearing retainer and a crossmember mounting foot(Ford 205) option. Do you guys have any pics of those? Also can I get a quote(shipped) for all that to 89508?
www.vehicross.info/showthread.php/17331-Ascinder-s-1-Ton-VX-Cont-d
Ascinder is offline   Reply With Quote Quick reply to this message
Old 11-10-2017, 10:33 AM   #160 (permalink)
Member # 129055
I could not find it anywhere on the website but do you guys offer a dual cable setup for the 241/eco box setup?
https://www.pirate4x4.com/forum/chevy/2575401-damn-blue-chevy-2003-silverado-build.html
mccustomize is offline   Reply With Quote Quick reply to this message
Old 01-21-2019, 05:37 AM   #161 (permalink)
Member # 214670
What is needed to put an eco box between a jeep AX15 and a married ford np 205? Price?
Keydet15 is offline   Reply With Quote Quick reply to this message
Old 04-02-2019, 09:16 PM   #162 (permalink)
Member # 1792
Looking at doing the ecobox with chevy round pattern 205. Does it matter which 465 you use. I have both 465/208 combo and 465/205 round pattern combo. Also which 241 to use and how much length does the box add?
Thanks
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kid's '70 Jeepster D44/14bolt FF.
Cheepin is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 01:39 PM   #163 (permalink)
in the garage
skunked's Avatar
Member # 235291
Thanks
you want to use a 6 pinion 241 and the eco box is about 8".
skunked is offline   Reply With Quote Quick reply to this message
Old 04-05-2019, 06:23 PM   #164 (permalink)
Member # 1792
Will the 465/241 combo from the late 80's work for this? Can't seem to find the specs.
Old 04-08-2019, 11:51 AM   #165 (permalink)
in the garage
skunked's Avatar
Member # 235291
IIRC those are 32 spline so they work. I cut up a driver drop 241 because they're cheaper and easier to find.
Old 04-08-2019, 03:35 PM   #166 (permalink)
Member # 1792
Thought I had a parts truck lined up with this in it. Turns out it's a 465/208 anyways.
Old 04-09-2019, 05:54 AM   #167 (permalink)
Member # 687330
Thumbs up to NW Fab on the ECO BOX! Mine shipped a little slow, but it didn't hold my build up, and Kris was really up-front with updated on the production!! It only took me about 3-4 hours total to strip my 241 & build the ecobox. Build quality and finish seem top-notch & I can't wait to put it into use!! For you facebookers check out some assembly pics here. Mine will be going between a Turbo 400 & a married Ford 205.
https://www.facebook.com/mitchell.ny...5332394&type=3
nyebrosfab is offline   Reply With Quote Quick reply to this message
Old 07-19-2019, 12:04 PM   #168 (permalink)
Member # 95025
Any possibility of a BW1356 doubler/reduction gear yet?
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 08-20-2019, 10:49 AM   #169 (permalink)
Newbie
Member # 767417
Im interested in an eco box to put between a th400 and a ford 205 transfer case was wondering if you could give me a quote and lead time thank you
Cherokee_94 is offline   Reply With Quote Quick reply to this message
