Infinitely clockable GM T-case adapter kits replaces stock full spline engagement! - Page 16 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 07-17-2015, 10:53 AM   #376 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Originally Posted by mvranish View Post
Mike,
Doing a Chevy Cummins conversion and using a 47re and the Chevy np205 race track. Both units will be upgraded to 29 splines, will the Getrag to 205 be the way to adapt these 2 units?
You'll likely need to remove the rear seal from the back of the transmission, but other than that, the Getrag kit should work out fine. The adapter kit comes with a double lip seal that will do the job of the seal in the back of the trans so there is no issue.
Regards,
Mike
Trail Tech Fab
Home of Infinitely Clockable T-Case Components and Adapter Kits
CNC plasma cutting up to 1 inch, PM me for more info.
mpascino is offline   Reply With Quote Quick reply to this message
Old 07-30-2015, 10:09 PM   #377 (permalink)
Member # 233825
Interested in a price for a clockable adapter for sm465/205 shipped to 28411
surfwagoneer is offline   Reply With Quote Quick reply to this message
Old 08-03-2015, 04:56 AM   #378 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
PM sent, Thanks.
Mike
Trail Tech Fab
Old 08-15-2015, 10:50 AM   #379 (permalink)
496&44s's Avatar
Member # 356210
Location: Warren, Nokomis, Gunnison... wherever I may roam
4L80E to Ford NP205, shipped to 16365... thanks
drivin' junk I can barely keep runnin'...
496&44s is offline   Reply With Quote Quick reply to this message
Old 08-20-2015, 02:37 AM   #380 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Good Morning, We'll just need to confirm you output shaft on the 4l80e and which version 32 spline input gear you are using on the NP205. Sending PM now.
Thanks,
Mike
Trail Tech Fab
860-341-1883
[email protected]
Trail Tech Fab
Old 09-29-2015, 12:32 PM   #381 (permalink)
Member # 222635
I am trying to devise a game plan for my 72 blazer. Wanting to start collecting parts for a 5.3 to GM NV4500 to my existing NP205 which should be a 10 spline if I'm correct. I know you make an adapter for that but what else would I need source for that if anything. For example, will I need to swap the input shaft in the np205? IF so do you have this shaft? Are there options that you are aware of. The clocking ability should help with any clearance issues that my arise. Could you give me a price quote for this adapter and any other components you may have to couple the two together shipped to 72943?
Thanks.
Daymond is offline   Reply With Quote Quick reply to this message
Old 09-30-2015, 05:51 PM   #382 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks.
Daymond, what transmission is in your 72 blazer? If it's an original SM465 it will be a 10 spline unit. If it's a TH350 automatic, it will be a 27 spline unit. Either way you will need to swap the input gear in the 205 or run an adapter coupler with a cut NV4500 shaft. Clocking options may be somewhat limited. Do you already have the NV4500? There are a bunch of different combinations that can be paired together. Feel free to give us a call directly to go over your options, it might be easier. We have a few different 205 input gears on the shelf, if not we can have them in a few days.
Regards,
Mike
Trail Tech Fab
860-341-1883
Trail Tech Fab
Old 10-03-2015, 04:47 PM   #383 (permalink)
rabbiporkchop's Avatar
Member # 181404
How much for an unwelded adapter to mount a Dodge NP241 to a 2002 Chevy 4l60e shipped to 18660??
95 solid axle Tahoe with LM7 swap
rabbiporkchop is offline   Reply With Quote Quick reply to this message
Old 10-14-2015, 03:39 PM   #384 (permalink)
Member # 196977
How much for one to fit a TH400 to a 6 bolt round style NP205 long input 32 spline?
I hope your ass is jealous from the shit that's coming out of your mouth:flipoff2:
88 chev, rockwells, 454 stroker, th400, 205 twinsticked. :smokin:
charlie2tight is offline   Reply With Quote Quick reply to this message
Old 10-21-2015, 12:34 PM   #385 (permalink)
Member # 196977
BUMP!
Old 10-26-2015, 05:02 AM   #386 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
PM sent, Thanks!
Trail Tech Fab
Old 10-26-2015, 05:24 AM   #387 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
This adapter kit sells for $345 shipped in the USA. All gaskets/hardware is included. Our rear torque mount kit sells for $60 when purchased with an adapter kit($15 savings). We use paypal for secure transactions. Credit cards can be accepted over the phone of course. Lead time currently is approximately 7-9 business days. Let us know if you have any questions we can answer.
Regards,
Mike
Trail Tech Fab
860-341-1883
[email protected]
Adapter kit photos
TH400 or 4l80e to Round 6 bolt Case
Rear Mount photos
NP 205 rear support torque/mount
Trail Tech Fab
Old 11-11-2015, 05:03 PM   #388 (permalink)
Member # 191879
Allison/NP205 Adapter
GM Allison 1000 to GM NP205 Adapter shipped to 95370? Thank you!
Precision Fabrication Plus, Inc.
(209) 588-1000 M-F 6am-4:30pm PST
rdpxtreme is offline   Reply With Quote Quick reply to this message
Old 01-03-2016, 08:20 AM   #389 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks for the business guys. All messages should be up to date.
Regards,
Mike
Trail Tech Fab
860-341-1883
[email protected]
Trail Tech Fab
Old 02-16-2016, 08:54 PM   #390 (permalink)
Member # 546098
Interested in a kit for an np241c with a ford np205 doubler, going on a th400. Shifter linkage stuff and everything.
manther is offline   Reply With Quote Quick reply to this message
Old 02-29-2016, 09:12 PM   #391 (permalink)
Member # 654985
Regards,
Mike
Trail Tech Fab
860-341-1883
[email protected]
Hi Mike,
I'm interested in the kit for the 4L80e to NP205 and would like to know the cost, shipped to 59102? Just bought a 4L80e out of a 2002 Chevy 2500 HD 4x4, today. My NP205 is in a 1979 GMC 4x4 short bed I am restoring. What measurements do I need to get you if any before ordering?
Thanks,
Jeremy
79SierraGrande is offline   Reply With Quote Quick reply to this message
Old 02-29-2016, 09:35 PM   #392 (permalink)
Member # 654985
Regards,
Mike
Trail Tech Fab
860-341-1883
[email protected]
Hi Mike,
I forgot to mention also that my NP205 is a passenger side drop and has the figure-8 bolt pattern.
Thanks,
Jeremy
Old 03-03-2016, 10:19 PM   #393 (permalink)
Member # 655786
Good morning,
More Pic here
Getrag to 205
This Infinitely Clockable Adapter kit sells for $345 shipped in the USA. All hardware, gaskets, and seals are included. The kit comes unwelded of course. Let us know if you have any other questions.
Regards,
Mike
Trail Tech Fab
860-341-1883
[email protected]
Hello i was needing this kit as well for my cummins swap and was seeing if you could email me at [email protected]
or Contact me at 913-775-2019
72Cumminschevy is offline   Reply With Quote Quick reply to this message
Old 03-06-2016, 06:20 PM   #394 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Originally Posted by 79SierraGrande View Post
Hi Mike,
Thanks,
Jeremy
PM sent, thanks!
Trail Tech Fab
Old 03-16-2016, 09:25 PM   #395 (permalink)
Member # 10144
I'll be picking up a 4x4 4L80e this weekend. What do I need to adapt a NP205 to this trans? The NP205 will probably be one of the earlier versions from a SM465. What about the VSS sensor? Thanks
not4show is offline   Reply With Quote Quick reply to this message
Old 03-18-2016, 04:58 AM   #396 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Not a problem, Sending Pm now.
Thanks!
Trail Tech Fab
Old 04-07-2016, 03:26 PM   #397 (permalink)
Member # 664810
I'm looking for an adapter kit to bolt a 4wd 6l80e transmission to a race track style 8 bolt np205. I was wondering the length of the adapter from trans housing to transfer case. Also was wondering how much the kit would be welded together with hardware, gaskets and the correct 32 spline input shaft with bearing for the transfer case. Thanks for the help.
Jordan
72ChevyBlazer is offline   Reply With Quote Quick reply to this message
Old 04-11-2016, 06:06 PM   #398 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Jordan
Jordon, email sent with all the details specific to your setup. Kits are sold unwelded.
Regards,
Mike
Trail Tech Fab
Trail Tech Fab
Old 04-26-2016, 10:31 AM   #399 (permalink)
Member # 166573
2WD SM465 to Ford NP205
Looking for a kit to mate these two. The SM465 is a 2WD unit with 1350 Yoke and the NP205 is a divorced unit. I was going to run them divorced but I think I want them married. Do you offer an adapter for that? if so what is the cost and what else would I need?
Thanks,
Leigh
checkmatesd is offline   Reply With Quote Quick reply to this message
Old 05-18-2016, 10:57 AM   #400 (permalink)
Member # 79306
Probably a dumb question but do you have any pictures of the TH400 to 205 adapter mounted in a vehicle. I really like your design just trying to figure out how much I am going to have to change my cross member. Thanks.
akecj7 is offline   Reply With Quote Quick reply to this message
