Infinitely clockable GM T-case adapter kits replaces stock full spline engagement! - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 08-23-2011, 09:19 PM   #101 (permalink)
Member # 123514
Originally Posted by OKMudn View Post
price for an INFINITELY CLOCKABLE sm465 to gm205 with the figure 8 face. shipped to 73040
Same to 87109 10 spline
[COLOR="Red"][SIZE="5"]For the best deal on 8 lug disc brakes click here[/COLOR]-->
[/SIZE]
I don't build it pretty I build it to function.
frikenwoodro is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 04:33 AM   #102 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Originally Posted by MCMLXIX View Post
All the 4L80e adapters I see, seem to have an O-ring and a raised lip. Your adapters seem to be flat where they mate to the trans.... Is this correct?
Aslo can you post pics of a 4L80e to Round NP205 kit?
The NP205 I have (pictured below) has a retainer around the input shaft. Does your adapter use this or replace this?
I think you are looking at the front side of the plate. All of our adapters have a lip or a recess to align to the transmission or t-case. This is a pic from page 1 of the TH-400 mounting plate.
The 4l80E is essentially the same with a minor diameter change for the 4l80E. You can see the locating lip. We currently supply these with a gasket. I'm digging for a 4l80E to round 205 pic but coming up dry right now. Attached is a pic of the SM 465 to Ford 205 (round face). The plate on the 205 replaces the seal/bearing retainer. The 4l80E kit would come with a new seal for your 205 input, gasket for the 4l80E, hardware, etc.
CAD photo of short 4l80E setup.
Let me know if you have any questions,
Thanks,
Mike
Trail Tech Fab
Home of Infinitely Clockable T-Case Components and Adapter Kits
CNC plasma cutting up to 1 inch, PM me for more info.
mpascino is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 05:35 AM   #103 (permalink)
MCMLXIX's Avatar
Member # 110338
here are some pics of an original 1991 4L80e NP205 adapter.... it looks like they used an O-ring with a groove next to the locating lip...
1972 K5 Blazer Mall Crawler
LQ9 / 4L80e / NP205 / D60 / AAM 14bff / Hydroboost / Fox 2.0
MCMLXIX is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 10:15 AM   #104 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
You are correct that the factory adapter for the 4l80E had a machined groove for an Oring. Our standard issue kit utilizes a gasket, not an O-ring. This setup works well and when used with RTV won't ever leak. Most factory setups end up getting RTV'd together any way to ensure a good seal. This was standard practice most transmission techs. The second and main reasoning for not utilizing a oring is the material removed would be in a critical strength area of our adapter. By not having this groove in the adapter you have an extra .125" of steel supporting the adapter. While it doesn't sound like much it makes a big difference when it's the material supporting your drive line.
We can produce an adapter kit with the o-ring if you desire but it will add a little $$ to the cost since machining the grove is an addtional manufacturing seqence and is a relatively slow process.
Trail Tech Fab
Old 08-28-2011, 04:21 PM   #105 (permalink)
Mud4me!!'s Avatar
Member # 64078
Can you make an adapter for a late model sm465 32 spline output (originally had a 208 behind it) to a 203 range box that is flipped upside down? I may just redrill the face of the 203 and make the original adapter work but i like to have options. Is this something you can/have done?
Thanks
Mud4me!! is offline   Reply With Quote Quick reply to this message
Old 08-29-2011, 03:21 PM   #106 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Sorry for the delayed responses guys. We took a direct hit with hurricane Irene. I'm being told it will be another 7-10 days before we get power back. I spent 4 hours yesterday cutting up trees just so we could get access to the property. Unfortunately the generator is really only good for lights in the shop, production is at a stand still.
On the upside, all open orders have been shipped. I am hoping to respond to all pending questions/invoicing in the next day or two providing internet service stays up longer than 20 minutes at a time. Once again, sorry for the delay, we haven't forgotten anyone.
Thanks,
Mike
Trail Tech Fab
Old 08-29-2011, 04:09 PM   #107 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks
Most of our customers run our Diablo box instead of a traditional 203/205 doubler setup. While we can make the adapter you requested the overall investment would likely be greater all in than the Diablo that will bolt right up to your 208 adapter and 205. Do you already have the 203/205 built? The Diablo is a 2.72 ratio vs the 1.96 of the 203 box. Additionally the unit weighs in at around 45 lbs(you can pick it up with one hand, lets see you do that with a 203 range box). If you are unfamiliar with the Diablo, it uses the planetary gear set from a NP241 just like a klune or BB. Pic of the main unit shown below. Regardless of which way you want to go we can help you out. We can build a setup for any 31 or 32 spline 205, round or figure 8 pattern. Let me know what tcase you have in mind and which way you are looking to go.
Thanks,
Mike
Trail Tech Fab
Some other info.
https://www.pirate4x4.com/forum/showp...9&postcount=17
Trail Tech Fab
Old 08-29-2011, 05:32 PM   #108 (permalink)
Mud4me!!'s Avatar
Member # 64078
pm sent
Old 08-30-2011, 10:23 AM   #109 (permalink)
little guy's Avatar
Member # 120246
Good luck with the huricane cleanup. Could you make an adapter for a 700r4 to a chevy 205 figure 8. Basicly it needs to be a th350 to 205 but 2" longer than a factory adapter on the transmission side?
you rock eatin, tater-brained, chicken chasin hubcap stealin gooberheaded fucktard.
little guy is offline   Reply With Quote Quick reply to this message
Old 09-05-2011, 06:16 PM   #110 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Just got power back this am. It's been a long miserable 8 days.....
700r4 to figure 8 205 is a very popular application for us. This adapter kit runs $325 shipped and to your point is nearly identical to the th350 adapter except longer. All of our kits include gaskets/seals and required hardware. Shoot me a PM if you have any questions.
Thanks,
Mike
Trail Tech Fab
Old 09-14-2011, 01:57 PM   #111 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Back to the top!
Trail Tech Fab
Old 09-15-2011, 06:32 AM   #112 (permalink)
Member # 120067
Thanks,
Mike
Trail Tech Fab
Some other info.
do you have a pic and dimensions of this mated to the fig 8 205 thanks
TPIfj40 is offline   Reply With Quote Quick reply to this message
Old 09-15-2011, 07:49 AM   #113 (permalink)
Member # 150595
Price on the Diablo box please.
Did some searching, found nothing.
Thanks Nat
Nat_sters Haul All
nat_ster is offline   Reply With Quote Quick reply to this message
Old 09-15-2011, 08:54 AM   #114 (permalink)
Member # 56693
Hey mike, lookn forward to hearing from you on the 4L80e to ford 205 adapter, i left a PM and voicemail, wow sorry to hear about the hurricane. contact me as soon as you can, thanks chris 701 640 9683
[SIZE="4"][CENTER]"America is at that awkward stage. It's too late to work within the
system, but too early to shoot the bastards."
:usa:
'79 F-350 Crewcab, Cummins, 6spd. 37s
NPF chassis, 6.0, 4L80E, 404s, 42s,
97 FJ-80, 3" OME, 35s, Lockers, 335k and counting...[/SIZE]
[SIZE="5"][/SIZE][/CENTER][/SIZE]
montanatrout is offline   Reply With Quote Quick reply to this message
Old 09-16-2011, 02:31 PM   #115 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Chris, invoice on the way, thanks.
Trail Tech Fab
Old 09-16-2011, 02:32 PM   #116 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Let me dig through some files and see what I have. I'll get back to you soon, Thanks,
Mike
Trail Tech Fab
Old 09-16-2011, 02:33 PM   #117 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks Nat
PM sent, need to know your setup.
Thanks,
Mike
Trail Tech Fab
Old 09-22-2011, 08:02 AM   #118 (permalink)
Member # 150821
What about a 2wd SM465 to Jeep Dana 300?
Malkey is offline   Reply With Quote Quick reply to this message
Old 09-23-2011, 07:04 PM   #119 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Do you have a stub shaft to fit your 2wd output shaft and mate to your 23 spline input? If so we can make the adapter to mate the two. Let us know.
Thanks,
Mike
Trail Tech Fab
Old 09-28-2011, 10:41 AM   #120 (permalink)
Member # 15779
Quote on Diablo Box Th400 to NP205
TH400 has 32 spline currently setup with a NP203
NP205 has short 32 spline input with GM 6 bolt pattern
67FJ40/Chevy350/Th400/NP203/SplitCase/42" Irok's/Full Hydro/Detroit's/Dana 60/14 Bolt/110"WheelBase
RCK FJ40 is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 08:54 AM   #121 (permalink)
Member # 138801
Hey I just got the kit yesterday, the parts look great thanks!
Looking for a Ram G56/T case to buy or swap with 48re.
geo in a K5 is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 07:01 PM   #122 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
PM sent!
Trail Tech Fab
Old 10-08-2011, 05:12 AM   #123 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks for the orders!
Trail Tech Fab
Old 10-08-2011, 02:01 PM   #124 (permalink)
jduck's Avatar
Member # 26935
Send a message via Yahoo to jduck
Got my kit today! Cant wait to get it put on.
That guy...... :Middel Fangers:
jduck is offline   Reply With Quote Quick reply to this message
Old 10-21-2011, 04:11 AM   #125 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
All open adapter orders shipping today, Thanks guys!
Trail Tech Fab
