Front axle upper link bracket - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2018, 05:37 PM   #1 (permalink)
lpukas2's Avatar
Member # 55139
Ok, is this angled too much? Is seems like it is to me but this is my first.
Thanks
lpukas2 is offline   Reply With Quote Quick reply to this message
Old 09-08-2018, 06:27 PM   #2 (permalink)
Member # 145904
Looks like a good angle to me.
winter4x is offline   Reply With Quote Quick reply to this message
Old 09-08-2018, 06:52 PM   #3 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Its mounting angle is partly dictated buy link calculator geometry
Old 09-08-2018, 07:02 PM   #4 (permalink)
Member # 196897
As long as you clear everything it should be fine. I like the look of a straighter up and down but sometimes it can conflict with steering links or hit the oil pan. Whats your separation between the uppers and lowers? Looks like the lower mounts could be angled down just a bit more.
thedirtman is offline   Reply With Quote Quick reply to this message
Old 09-09-2018, 03:54 PM   #5 (permalink)
lpukas2's Avatar
Member # 55139
5.5 seperation on the axle, its tilted down to clear the steering and to get it to 25". At that height my AS is around 80%. If i tilt it forward to say 26" on the lower bolt hole my AS goes to around 100%. Frame side upper bracket it pretty much fixed postition.
Old 09-09-2018, 04:11 PM   #6 (permalink)
Member # 196897
I would work on getting more separation unless you are running 28" tires. A 36" tire should be around 8" of separation. If your upper frame location is fixed I would try and get the upper close to level and make your AS adjustments with the lower arm geometry. Do you have a target AS #?
Old 09-09-2018, 04:24 PM   #7 (permalink)
twistedyota's Avatar
Member # 82261
Iv always avoided angling them like that for the sole reason that changing hole positions will change your pinion angle considerably and you may or may not be able to adjust it out with your heims. If clearance is an issue or that is what you want for geometry then look for and offset style link mount.
twistedyota is offline   Reply With Quote Quick reply to this message
Old 09-10-2018, 06:40 PM   #8 (permalink)
lpukas2's Avatar
Member # 55139
I was told to shoot for 80 so I’m trying to get it adjustable from 80 to 100. I really didn’t think about if I had to adjust as your right in that I would basically have to build a new arm. Ill play with it this week and see what I come up with. On another note, is 4 degrees of roll over steer bad in the front
