Should I grind & reweld? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-15-2018, 09:22 AM   #1 (permalink)
Member # 806329
Last night I welded a control arm bracket on. To be honest when I look at it this morning I am not happy with it. I don't think I had it set hot enough.
Jesse_01 is offline   Reply With Quote Quick reply to this message
Old 09-15-2018, 09:23 AM   #2 (permalink)
Member # 806329
Sent from my iPhone using Tapatalk Pro
Old 09-15-2018, 09:28 AM   #3 (permalink)
Member # 178200
Yes you should.
SLOWPOKE693 is online now   Reply With Quote Quick reply to this message
Old 09-15-2018, 09:34 AM   #4 (permalink)
Member # 37016
grind it out and practice off the truck with the welder first. You moved way too fast and not enough heat into the piece
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 09-15-2018, 09:36 AM   #5 (permalink)
Member # 685826
Quit trying to make a smooth slug weld. Get a nice pattern goin and try in both pieces. That weld is plenty hot but u weren’t directly in the root and we’re moving to fast so it’s not tied in everything.
Toyota97 is offline   Reply With Quote Quick reply to this message
Old 09-15-2018, 09:43 AM   #6 (permalink)
Member # 806329
okay will do. I had some nice welds when practicing. Then when I went to weld it up, it went sideways. Practice welding on a bench vs welding laying under an axle is totally different.
If I am welding to a cold axle tube, I should increase the heat vs would you normally would have it set at for 3/16?
Old 09-15-2018, 12:08 PM   #7 (permalink)
Member # 806329
I think for safety sake of this project(wife's Jeep). It's going to be tacked in place then let a skilled welder weld it up.
Old 09-15-2018, 03:25 PM   #8 (permalink)
Member # 685826
Just practice man. I’ve seen way worse welds hold and although yours would probably be fine it only takes a few minutes to grind it down and weld over it. If your worried grind a v into the seem of the brackets and tube and put a nice hot root pass down first. I wouldn’t give up is all I’m sayin Your welds definetly arent horrible.
Old 09-15-2018, 03:49 PM   #9 (permalink)
lpukas2's Avatar
Member # 55139
X2, when I do .25 I run beads on both sides if possible
lpukas2 is offline   Reply With Quote Quick reply to this message
Old 09-15-2018, 04:16 PM   #10 (permalink)
Chief Rocka's Avatar
Member # 196079
It looks like you were moving too fast because the edge of the stack is ">" shaped, when it should have been more ")" shaped. Maybe try a triangle/christmas tree weave to help slow down.
Was this burnt with a 110v or 220v?
Chief Rocka is offline   Reply With Quote Quick reply to this message
Old 09-15-2018, 04:36 PM   #11 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
when i do 1/4" i bevel pretty good so that i can fit 3 passes worth of weld in there.
'odds are' it would be fine, or fail slowly enough that you can notice it before death, but if you have the time, now is the time to do it again.
Old 09-15-2018, 05:01 PM   #12 (permalink)
Member # 806329
It was done with 220v, .03 wire on a Miller mp215. Had it autoset for 3/16 mild.
I grabbed a bunch of steel to practice my pattern on before I attempt it again. I have 2 frame brackets & 1 more axle brackets to do.
When I ground it down a bit, it looked like it had good contact with both the axle & bracket.
No air pockets like some of the factory welds.
Thanks for the advice & tips.
Old 09-15-2018, 05:12 PM   #13 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
i'm sure it looked good inside, but you can clearly tell from looking at the back side that it is not all the way through and possibly only half or less of the base metal thickness actually welded.
so yeah, it was probably as good as a factory weld, but that isn't good enough for anybody else
Old 09-15-2018, 05:38 PM   #14 (permalink)
Member # 806329
Practice welds.
Old 09-15-2018, 07:10 PM   #15 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
alright, now take a cutoff and wheel and cut across all of them perpendicular (like how subway cuts your sandwhich in two after they assemble it)
just by looking at the cut edge, you can probably see where the weld is relative to the unwelded metal pretty easily. might need to sand it. in lieu of acid, try and spray some vinager on it, might highlight where the heat lines are.
that will tell you how far you are getting into the metal and you can adjust your settings from there, or adjust your material prep by V-ing it out to get the thickness down
they all look nice and straight
Old 09-16-2018, 09:18 AM   #16 (permalink)
Member # 228875
Running beads on flat plate is not good practice. You need to roughly replicate the actual work piece: a fillet weld on a 90° joint with the similar thickness materials, and the same orientation (vertical, overhead, etc.). You could substitute plate for tubing if you don't have any scrap.
stephen wilson is online now   Reply With Quote Quick reply to this message
Old 09-16-2018, 09:40 AM   #17 (permalink)
Member # 806329
Yeah makes sense. I plan on getting some 1/4 or 3/8 flat bar & start doing different kind of joints.
I find I do rush a bit & need to slow down. Also I need to readjust more for a better position & not be afraid to stop & start a weld.
Old 09-16-2018, 09:53 AM   #18 (permalink)
Member # 228875
I still have that problem, I just want to knock out a project and rush to get it done. But if it's an "unusual" joint, or I'm rusty from not welding for a while, it really pays to get in some practice. Otherwise you risk making junk instead of the desired part !
You bring up another good point, if you can't position yourself to see the weld puddle, and have a reasonably comfortable welding position, you are unlikely to have quality results.
Old 09-16-2018, 09:57 AM   #19 (permalink)
Member # 85771
Id weld the inside, take a break to piss, and then lay two big ol fat caterpillars over the outside weld.
Make Forums Great Again!
ky scrambled is online now   Reply With Quote Quick reply to this message
Old 09-17-2018, 05:06 AM   #20 (permalink)
arse_sidewards's Avatar
Member # 256962
This.
Either practice vertical or pull the axle and weld it horizontal.
Old 09-17-2018, 10:28 AM   #21 (permalink)
Member # 79509
Originally Posted by arse_sidewards View Post
This.
If hes doing link mounts I would think the axle is already loose. Needs to burn them in on the bench instead of trying to overhead
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 09-17-2018, 01:22 PM   #22 (permalink)
Member # 18776
To help control the speed of your hand, try to keep the beat/rhythm of your hand movement in your head as you move your hand back and forth, 1-2, 1-2, 1-2.......
CA_Snowtoy is offline   Reply With Quote Quick reply to this message
Old 09-17-2018, 06:48 PM   #23 (permalink)
POR
Member # 206074
Practice welds.
Practice this as much as possible! Tighten up the welds and practice laying them next to each other and overlapping them halfway (does that make sense?)
Then go on top of welds and lay beads other way (think checkerboard) the weld on the far right in the pic looks good.. your not staying in the end of the puddle long enough also.. thats why there's a divit at the end of weld.
Kudos to you for welding uphill. That's the way it should be laid. Your weld is nowhere near as strong as the factory welds. You need to grind out and try again.. make sure you expose the root crack as well when grinding.
POR is offline   Reply With Quote Quick reply to this message
Old 09-17-2018, 06:52 PM   #24 (permalink)
POR
Member # 206074
You can't do what your talking about on flat welds.. your talking about 2 beveled pieces with backer plate and ypu have to bend the welds to see if they fail
Old 09-17-2018, 06:58 PM   #25 (permalink)
POR
Member # 206074
You have absolutely no idea what your talking about! Do the world a favor and quit giving welding advice, you do not know how to weld!!! The first thing you do in welding school is weld on plate just as he has done. It teaches puddle control and feel.
