Unparalell motor - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-28-2018, 12:08 AM   #1 (permalink)
Member # 850702
Unparalell motor
So I found out today that my motor is offset about 2 inches from factory that has created a nightmare for my header as it's on the tight side. I'm wondering if its ok to run the motor sideways a bit to allow for the tranny output shaft to be centered and the header to clear the frame.
Also plan on building a radius arm setup. Is there a such thing as too long. I'm looking at approximately 54 inches long that seems a bit too long but that's where my front output shaft is gonna land.
Sent from my SM-G892U using Tapatalk
bikesndbugs is offline   Reply With Quote Quick reply to this message
Old 09-28-2018, 10:05 AM   #2 (permalink)
Member # 13786
Sure, won't hurt a thing
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 09-28-2018, 10:11 AM   #3 (permalink)
Member # 850702
Thank you
Old 09-28-2018, 12:09 PM   #4 (permalink)
Member # 850702
Anyone have insight on the radius arms.
My transfer case is gonna end up centered front to rear to allow for a sufficient center driveshaft with slipyoke.
If I was doing 3 or 4 link this would be a good thing as I could make equal lenth links but I'm not at the moment so it's a nogo plan is to extend the stock ford radius arm
