Hydro Assist Troubleshooting Noob- where to start - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-07-2019, 08:25 AM   #1 (permalink)
Member # 28880
I've got an old(I'm guessing old judging by the amount of missing paint and rust on the ram) howe hydro assist system that was installed sometime before this jeep became mine. It works amazing at low speed about 90% of the time- barely takes any effort in the rocks, cruises down the road just fine.
Things get less amazing when we're going fast and need to countersteer quickly. Feels like suddenly I don't get any help from the system. I looked in the reservoir and it's full, the system has no leaks, and generally stays cool(has a temp gauge in the dash). Where should I look next?
Harry Johnson is offline   Reply With Quote Quick reply to this message
Old 01-07-2019, 10:41 AM   #2 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Search ďslow steeringĒ lots of hydro assist threads will pop up. Iím a newb pretty much myself but ram size the larger and longer the slower as all that fluid has to go from one side to the other relatively fast. Also piston size in steering box. Iím running a really small Toyota box and a realatively large ram 1.75x8 and itís on the slow side to counter steer. Also Iíve heard where the box is tapped and if the fittings are a sharp 90 can slow the fluid down.
Hope this helps.
Old 01-07-2019, 10:49 AM   #3 (permalink)
Member # 28880
Hope this helps.
Thanks! I think I need to figure out what steering box I'm running first, everything else seems to be setup just like other people with a howe assist, so I'm guessing that's what's different.
Old 01-07-2019, 12:12 PM   #4 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Jeep is Saginaw box. Not sure if there isnít different piston sizes. Maybe some one will chime in.
Old 01-09-2019, 09:16 PM   #5 (permalink)
Member # 861200
Yep
Wallie is offline   Reply With Quote Quick reply to this message
Old 01-10-2019, 07:18 AM   #6 (permalink)
Member # 196897
If you are slow at fast steering you need to increase the oil volume which generally means a high volume pump but it could also be having too small a hydraulic line to handle the flow.
A smaller diameter ram will also help in high speed but may cost you the power you need at slow crawling.
You also want to make sure your reservoir is big enough to supply enough oil in high flow pumps.
thedirtman is offline   Reply With Quote Quick reply to this message
Old 01-10-2019, 10:35 AM   #7 (permalink)
Member # 28880
Great info! Thanks!
Old 01-11-2019, 06:28 AM   #8 (permalink)
Member # 548137
Been reading up on this, will need assist on my uprades. What are the generally acceptable size ram for given tire size? West Texas says
1.5" up to 37" tire
1.75 up to 40"
2" for 40" and up
So you want the smallest ram that fits your application to improve steering speed?
Sent from my SAMSUNG-SM-G930A using Tapatalk
denverd1 is offline   Reply With Quote Quick reply to this message
Old 01-11-2019, 06:40 AM   #9 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
1.5" up to 37" tire
1.75 up to 40"
2" for 40" and up
Thatís exactly what psc told me when I was building my kit. I have 40ís and Iíve gotten my tires wedged enough I couldnít move them with my 1.75x8Ē ram. I wouldnít want to give up any power for speed even though my system is on the slow side like stated above.
Old 01-11-2019, 07:44 AM   #10 (permalink)
Member # 548137
smaller pulley on pump would spin it faster. is that a bandaid or a legitimate fix?
or do you need a bigger steering gear to handle the increased flow?
Old 01-11-2019, 07:48 AM   #11 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
I’ve been told that you can over spin a pump. Psc has some info on their site about crank pulley size and pulley size ratio. Again some great threads on here just have to search for them
Edit: specs on your setup might yield more answers. Size of ram, type of pump and line fittings etc.
Old 01-11-2019, 07:48 AM   #12 (permalink)
Member # 196897
I would call it more of a bandaid and people generally do it so they have more flow durning slow crawling where your engine RPM is low.
Old 01-11-2019, 08:48 AM   #13 (permalink)
Member # 548137
Iíve been told that you can over spin a pump. Psc has some info on their site about crank pulley size and pulley size ratio. Again some great threads on here just have to search for them
for me? I'm still in the ass scratching phase of development. Got axles and 37s, I'll be building around
Old 01-11-2019, 12:15 PM   #14 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Motor will more than likely dictate pump unless itís a real common application like last. Then youíll have choices. 37ís you want 1.5Ē ram. Length you wonít know until you mock up everything. But on my Cj I bought a 1.5Ēx8Ē ram. Iíll limit it to 5.75Ē internally and I can always use the same ram on a Dana 60 down the road when the time comes.
Again all these questions Iíve searched myself more than enough info on here.
Old 01-14-2019, 08:51 PM   #15 (permalink)
Member # 548137
Jeep XJ with 4.0. The gear worth tapping for hydro assist or should I find a better one? Will likely underdrive the pulley for low rpm flow
Old 01-14-2019, 09:48 PM   #16 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Yeah pretty common box to use. Plenty of videos online on how to do it.
