removing motor and trans from 98 blazer(4.3) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-28-2019, 07:53 AM   #1 (permalink)
Member # 73218
I found a 98 blazer with a 4.3 and 4L60e that will be going into my 71 commando.
Has anyone pulled the motor/trans out as a combo through the front?
I know the front grill will need to be removed but I am looking for any clearance issues that may come from the oil pan and front differential.
Every post I can find only address pulling the trans or the motor. Not both at once.
[QUOTE=soilantgreen;10014492]Sorry, I couldn't hear you over the sound of your rig sucking.
[/QUOTE]
[QUOTE=TJDukit;12169111]No, I'm not a fag, I suck a dick at least once a year to make sure I still don't like it.:flipoff2:[/QUOTE]
[QUOTE=CSR;14325560]I can't tell. Looks like him. I'd need to see his ass or wang to 100% certain! [/QUOTE]
proskier101 is offline   Reply With Quote Quick reply to this message
Old 02-28-2019, 07:59 AM   #2 (permalink)
El Conquistador
Valley Rock's Avatar
Member # 208306
You can pull them both still together out the front, take T-case off first though .
Valley Rock is offline   Reply With Quote Quick reply to this message
Old 02-28-2019, 05:11 PM   #3 (permalink)
RXT
RXT's Avatar
Member # 493505
You can pull the engine, trans, and t-case together. You'll have to remove the rad and rad wall, or just remove the entire front clip and hood. The key is raising it high enough to clear the frame and diff and you may have to tilt it at an angle. (If the t-case has a slip yoke, pull the yoke and cover the hole with a bag using rubber bands to hold the bag on)
Or if the truck is junk, unbolt the body from the frame and get a few friends to flip the body off to the side, then you can lift the engine/trans/t-case easy-peasy
Ed
99 Dakota, Cummins, 47RE, NP241HD, Dana60/70, 41.5 Rockers. I love it when a plan comes together!
RXT is offline   Reply With Quote Quick reply to this message
Old 02-28-2019, 05:37 PM   #4 (permalink)
Member # 69594
Rip the body off and pulling the whole powertrain out as a unit is easy as pie.
TrikeKid is offline   Reply With Quote Quick reply to this message
Old 03-01-2019, 08:58 AM   #5 (permalink)
Member # 73218
So far I've removed radiator and support. I'll pull the fenders just for convenience.
Ill just pull the Tcase so I don't have to worry about it and see if I can angle the trans down to it out of there.
[/QUOTE]
Old 03-01-2019, 01:15 PM   #6 (permalink)
El Conquistador
Member # 208306
Hope you drained the ATF from the trans and T-case first, or you will have a mess . About a 30/40ish degree angle on the engine/trans combo and up and out .
If the diff gets in your way you can jack the body up away from it a little bit and let the suspension hang for clearance Clarence .
Old 04-09-2019, 11:51 AM   #7 (permalink)
Member # 73218
I got the motor and transmission out of this. Before I junk the rest, do I need anything other than:
-Motor(4.3)
-Transmission(4l60e)
-Computer
I will not be using cruise control, so that is staying out.
Are shift cables normally interchangeable? I need to get rid of the blazer so I have room to look at what I now have.
[/QUOTE]
Old 04-11-2019, 09:47 AM   #8 (permalink)
Newbie
Member # 861326
-Motor(4.3)
-Computer
You didn't mention it, but I'm sure you're keeping as much wiring as possible? I have a buddy who pulled an engine out of a Mountaineer to swap into a Bronco, ran into issues with keeping the Anti Theft system happy since he didn't have the gauge cluster of all things - so he had to have the ECU flashed. Just be aware of some anti-theft system f*ckery if you're swapping into a new vehicle.
Ford Guy
landen300 is offline   Reply With Quote Quick reply to this message
Old 04-12-2019, 06:39 AM   #9 (permalink)
Member # 73218
I am not keeping the wiring harness. I will be using the stand alone harness from Painless.
[/QUOTE]
Old 04-12-2019, 11:00 AM   #10 (permalink)
Newbie
Member # 861326
Problem solved!
Ford Guy
