How do i get rid of this bump steer? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2019, 10:53 PM   #1 (permalink)
Member # 865902
I have a 08 Tundra with 16" of lift on 40s. Its a SAS with Curry axles in the front and rear. I bought it like this and it even came with a Atlas divorced transfer case. It use to have a Appleton hydro steering set up but it leaked bad and the steering radius sucked. I had it changed over to a 1 ton Chevy power steering box with crossover steering and Psc hydro steer. It has a single triangular front 4 link with Fox adjustable coilovers. It has some crazy bump steer right now. I have looked at a bunch of forums on this and 90% of the people say not to put a track bar with the triangular 4 link. I see the other option is to get rid of the triangle 4 link and make those bars parallel to the other two bars and install a track bar. Then i have seen a few say something about installing a 3 link with a track bar. What is the best set up to get rid of this bump steer besides full hydro which i don't want?
Ericjh74 is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 10:56 PM   #2 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
You likely will have to change the suspension from a triangulated 4 link to a 3 link or parallel 4 link with track bar. Make sure the track bar is parallel to drag link and similar length.
A 3 link will bind less on articulation and a parallel 4 link permits some degree of backup if you break a link or joint.
& Blaine
:tank:
Old 03-20-2019, 11:03 PM   #3 (permalink)
Member # 865902
The guy in charge is going to get rid of the triangle and doing a custom parallel 4 link with track bar. Looks like were going in the right direction.
Old 03-21-2019, 08:23 AM   #4 (permalink)
Member # 196897
You were better off with the full hydraulic and your links are going to be so steep it will be hard to get rid of the bump steer with the 5 link set up.
Who sent you in the direction of a conventional steering with assist? How are your driveline angles at that height?
thedirtman is offline   Reply With Quote Quick reply to this message
Old 03-21-2019, 08:33 AM   #5 (permalink)
Elwenil's Avatar
Member # 41063
Lower it.
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
I put on my robe and wizard hat. - Bloodninja
Elwenil is offline   Reply With Quote Quick reply to this message
Old 03-23-2019, 08:50 AM   #6 (permalink)
Member # 548137
Post a pic of this thing. Gonna be a pain in the ass to get it right
Sent from my SAMSUNG-SM-G930A using Tapatalk
denverd1 is offline   Reply With Quote Quick reply to this message
Old 03-23-2019, 12:45 PM   #7 (permalink)
Member # 37016
Keep 4 link. Run bell crank steering with cylinder assist.
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 08:13 PM   #8 (permalink)
Member # 866988
I'm curious as to how much travel and/or articulation the suspension has since it would seemingly influence options with regards to the steering.
MAKman989 is offline   Reply With Quote Quick reply to this message
Similar Threads
Chevy Crew Cab (C3) Truck Build bark beetle Chevy 295 08-13-2018 06:25 AM
bad bump steet erich545 Newbie General 4x4 Discussion 31 08-23-2015 12:55 PM
bump steer problems 53 pickup 1950kale Chevy 8 05-25-2015 04:26 PM
caster angle after lift bump steer issues badbowtie1982 Ford 12 03-05-2015 10:23 PM
Clayton Off Road High Steer Kit Clayton Off Road Mfg Suspension 1 03-01-2014 11:51 AM
