How much triangulation needed on lowers? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2019, 09:33 PM   #1 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
It's time to fix my rear 4 link with panhard. Currently it's running parallel lowers and slightly triangulated uppers with a panhard. Plan is to fully triangulate the uppers and get rid of the panhard. I won't be able to get much angle on the lowers though. Maybe 10 degrees on each. I'll inboard the brackets on the frame on some outriggers but won't be able to do a full crossmember. Is 10 degrees on each lower with good angle on the uppers still going to give me a ton of rear steer? Lowers are around 44" iirc and uppers will be around 30"
Here's a super old pic showing how bad the rear steer is with the current setup
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Old 03-23-2019, 10:12 PM   #2 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Because you are triangulating the uppers, technically you can run parallel lowers. It will rear steer though. Put what you can in the lowers and run it. Anything is better than nothing.
& Blaine
:tank:
Old 03-23-2019, 10:42 PM   #3 (permalink)
yozsi's Avatar
Member # 91857
Yea. I know that much. Don't know how much angle it takes on the lowers to really get the rear steer under control.
Foreign Car Center
Vallejo, CA
Old 03-24-2019, 03:08 AM   #4 (permalink)
Member # 700266
Few ways. Widen the arc that the rear wheels have to follow through there droop with longer control arms.
Or, the closer you can get the lower arms together on the frame end, the better.
Then you can do a triangulated (A frame) radias arm setup with panhard bar. Flatter or less angle from frame to axle, the less your steer
Like this.
Sent from my SM-G925F using Tapatalk
1997 Nissan D21 Hardbody/Sani Station wagon, SFA with 6" lift
33" rubber, Duel TC's with 4.1 gears
ABCAB is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 10:31 AM   #5 (permalink)
yozsi's Avatar
Member # 91857
If I were to do that or bring the lowers in, I would have to make the lowers like 60" long so the crossmember will clear the driveshaft under droop.
Foreign Car Center
Vallejo, CA
Old 04-14-2019, 08:27 PM   #6 (permalink)
Member # 866988
Just a suggestion but the TRIAGED 4-link calculator does have link tension and compression values based on a variable loading condition that can be set via the "Acceleration" value from the 'materials" tab (Cell C2).
MAKman989 is offline   Reply With Quote Quick reply to this message
Similar Threads
Wiring 110v outlets in the garage... Info needed Flargen Shop and Tools 75 11-11-2014 04:23 PM
Washington Input Needed: Governor's Task Force on Parks and Outdoor Recreation 4x4n Elkaholic daWg Land Use Issues 0 05-05-2014 06:03 PM
Thoughts and input needed on hidden shotgun safe Ol'Customcj7 Outdoor Sports and Recreation 23 10-30-2013 01:44 PM
Attached garage addition - framing help needed 87JeepWrangler Shop and Tools 9 05-23-2013 11:25 AM
Military Says No Presidential Authorization Needed To Quell “Civil Disturbances” JK3078 General Chit-Chat 36 05-20-2013 08:47 AM
