K10 rear shackles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-27-2019, 08:12 PM   #1 (permalink)
Member # 766441
K10 rear shackles
Who makes stock replacement shackles for a 1985 k10? I got the Dorman 722-066 shackles and they bind really bad and the holes arenít spaced the same. Need some help. Thanks
Ehmer53 is offline   Reply With Quote Quick reply to this message
Old 03-27-2019, 08:16 PM   #2 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Bind? Theyre bonded eyelet bushing, they arent spupposed to free cycle.
Old 03-27-2019, 08:57 PM   #3 (permalink)
Member # 13786
Do you have the stock set-up in tension or did you flip them to swing
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 03-28-2019, 05:00 AM   #4 (permalink)
Member # 766441
Still stock
Old 03-28-2019, 07:28 AM   #5 (permalink)
Member # 13786
If you have the bolts tight on the serrations, they're supposed to bind. Loosen the bolts, then set the weight of the truck down then tighten, OR If you want them to pivot freely, you'll have to sand the serrations off of the edge of the bushing sleeve end and not tighten the pinch bolt all the way.
Old 03-30-2019, 07:24 AM   #6 (permalink)
Member # 766441
The holes were species differently and the shackle would actually bind on the hanger (was too wide) I got some for a 2012 Silverado and they fit perfectly and match up identical to the factory ones
Old 03-30-2019, 08:18 AM   #7 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Sounds like you got some shitty shavkles.
Similar Threads
New Revolution Gearing packages available now! SweetCJ7 Axles/Tires/Wheels 2 07-15-2016 11:11 AM
*** Jimmys 4x4 U4 Podium Trailing Arm Car w/ Removal Rear Seat! *** tlancaster Vehicles and Trailers For Sale 27 06-07-2016 06:45 AM
Rear output shaft bearing 241d Pjc360 Dodge 20 12-18-2014 04:16 PM
76' Suburban K10 rear drive line skippy89 Chevy 8 08-24-2014 04:59 PM
