T.g. Rock assault question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2019, 09:25 AM   #1 (permalink)
clb 017's Avatar
Member # 166307
Any one have issues after cutting off the 15\32" off the bottom of the carrier that hangs down below the axle housing ?
It looks like I would be cutting into the bolt boss for the bottom 2 studs, and leaving the nuts to get caught on a rock...
The answer I got was
"Thats how its made" um ok...
We Been doing it like that for years and no problems.
You could weld a plate in there,(this would miss align the flange) .
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 10:19 AM   #2 (permalink)
arickvan's Avatar
Member # 188882
Me and my buddy both ground ours down
No problems so far
The threads will get gacked and a little bent but no leaks
He's had his for 2-3yrs and I've had mine for 1-2yrs
I can take a pic of how far we ground down later if you want
arickvan is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 03:20 PM   #3 (permalink)
clb 017's Avatar
Member # 166307
Thanx for the responce... I thought the studs would git beat.
Interested in a pic when ya get time .
Phawk photofukkit.
Old 04-01-2019, 12:44 AM   #4 (permalink)
2big bronco's Avatar
Member # 66684
Hmm, have to go look at mine but I dont recal grinding or cutting anything down. Either way no problems, haha
2big bronco is online now   Reply With Quote Quick reply to this message
Old 04-02-2019, 10:45 AM   #5 (permalink)
arickvan's Avatar
Member # 188882
Uhh maybe don't grind it off
I'll post pics soon
Old 04-02-2019, 11:36 AM   #6 (permalink)
arickvan's Avatar
Member # 188882
uh so cut at your own risk because im now missing a stud and have a very slight leak
this would have either happened at fordyce or the rubicon and i tend to drive by braile so take this for what its worth
your results may vary
[IMG]IMG_20190401_183515 by [url=https://www.flickr.com/photos/[email protected]/] on Flickr[/IMG]
[IMG]IMG_20190401_183439 by [url=https://www.flickr.com/photos/[email protected]/], on Flickr[/IMG]
Old 04-02-2019, 01:38 PM   #7 (permalink)
Member # 39436
You will smash the studs. It will probably leak a little.
I usually ending up replacing the studs whenever I pulled the third.
Public lands for Public use
dirtyjed is offline   Reply With Quote Quick reply to this message
Old 04-02-2019, 02:37 PM   #8 (permalink)
clb 017's Avatar
Member # 166307
Thanks gents..
Looks like I gotta fubared one...
My cutoff line would be thru the bottom edge of the bolt hole.
Still waiting for low range AND t.g. To respond
Phawk photofukkit.
Old 04-02-2019, 02:39 PM   #9 (permalink)
clb 017's Avatar
Member # 166307
Any one plate the bottom of the axle housing with good results?
Phawk photofukkit.
Old 04-02-2019, 03:29 PM   #10 (permalink)
Member # 39436
My buddy did and has been running it for a couple of seasons.
Old 04-02-2019, 04:04 PM   #11 (permalink)
YotaAtieToo's Avatar
Member # 25632
Thanks gents..
So was that hole not threaded?
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 04-02-2019, 04:15 PM   #12 (permalink)
clb 017's Avatar
Member # 166307
Facing the rear of the rig back to grill, the lower right hand bolt hole on the carrier housing (3rd) would be ground open, allowing down force to snap the stud off.
That and the fact the fasteners would need replacing at the gearcase fluid change, how long before the threads in the housing give it up from being the forward lowest item to contact a rock...
Phawk photofukkit.
Old 04-02-2019, 06:59 PM   #13 (permalink)
Member # 25632
Im having a hard time understanding how you need to grind that much if the threaded hole in the housing isn't right on the bottom edge?
Maybe just weld a piece of 3/16 or 1/4 to the bottom and be done.
Old 04-02-2019, 07:20 PM   #14 (permalink)
clb 017's Avatar
Member # 166307
I understand, it's to bad I cannot post a pic to explain the situation.
The bottom of the 1\2" face or flange of the housing ( holds the studs) has less than 1\16" of material from the stud to the edge of and bottom of axle housing.
Make a semi clear picture?
Phawk photofukkit.
Old 04-02-2019, 07:38 PM   #15 (permalink)
Member # 25632
OK, so it is right on the edge
Old 04-02-2019, 07:41 PM   #16 (permalink)
Member # 79509
I need pics, because i have no idea whats going on.
Black Sheep is online now   Reply With Quote Quick reply to this message
Old 04-02-2019, 10:18 PM   #17 (permalink)
Member # 53528
what i did to solve the issue(it is an issue iff you beat the snot out of your rig) was weld a piece of 1/4" flat plate to the bottom of the housing to act as a skid plate and also pulled the two bottom diff studs out and installed them as button heads from the outside so theres no big nut to get hit by rocks
Old 04-02-2019, 10:19 PM   #18 (permalink)
Member # 53528
this is exactly why i did it
Old 04-02-2019, 10:46 PM   #19 (permalink)
clb 017's Avatar
Member # 166307
Have a look at the above pic, where he cut the bottom off, mine is even closer to the stud.
Phawk photofukkit.
Old 04-02-2019, 11:03 PM   #20 (permalink)
ArTi54N's Avatar
Member # 104539
just what are good results??
and you do mean skid plates right?
so people can have some lame ideas, and as long as nothing breaks.. it will look like it worked..
I remember a long time ago.. when someone put what looked like a pair of removable skis.. under there.. and against the bottom of the pumpkin.. it never messed up on him.. so even though the idea was stupid as hell.. he always claimed it was a good idea..
I looked for a pic, and couldnt find one..
ArTi54N is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 06:49 PM   #21 (permalink)
Member # 53528
which is why i welded a flat plate to the bottom of the housing and took the two bottom studs out of the housing and turned them around and installed them from the outside as bolts instead of studs, no more nuts
Old 04-03-2019, 07:22 PM   #22 (permalink)
clb 017's Avatar
Member # 166307
That's what I'm thinkin.
Carnage (studs gettin toasted) and leaks are phawked.
Only issue plating the bottom is the way they cut the flange it's going to have a gap of .270 high and .135 wide to weld into under the carrier flange, BEFORE the radius of the axle housing starts.
I know lousy description..
Phawk photofukkit.
Old 04-03-2019, 07:50 PM   #23 (permalink)
clb 017's Avatar
Member # 166307
@rockyota83
Any chance of Details and a pic of the setup you made?
Phawk photofukkit.
Old 04-03-2019, 08:04 PM   #24 (permalink)
Member # 25632
Dude, sand a little of the flange. Take a piece of 3/16 or 1/4 and cut it to shape, weld it on.
Old 04-04-2019, 08:59 AM   #25 (permalink)
clb 017's Avatar
Member # 166307
I am gunna mill up some plate to fill the void where it clamps down, and carry on out to the bottom of housing, in one piece.
I am hoping for this to add some tech for the next guy down the road (errr TRAIL)....
Thanx for all the replies.
Phawk photofukkit.
Similar Threads
W.E. Rock Eastern Series Round 2 Dayton TN Charlene Competitions and Events 8 04-24-2016 07:52 PM
NEW! W.E. Rock Professional Rock Crawling To Include UTV Class Charlene Side by Sides 0 08-28-2015 05:58 PM
AC/DC to call it quits? Shawnboy General Chit-Chat 101 05-01-2014 01:00 PM
Trail Gear Rock Assault Axle Arb 4.88 Complete AB2007 Axles/Tires/Wheels For Sale 3 11-18-2013 08:02 PM
The Rock íní Roll Casualty Who Became a War Hero Renee General Chit-Chat 9 07-05-2013 08:39 PM
