Frame patching - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2019, 04:05 PM   #1 (permalink)
Member # 143737
Frame patching
Not sure if this is newb tech or more GCC tech worthy.
Getting ready to patch the frame on the wheeling rig Ranger, it sees a decent amount of road time so I'm trying to do my best and looking for criticism. Plan is to trim out the bad, and weld 1/4" plate patches over the outside.
The spot around the leaf spring hanger is getting a 30" long patch to help spread out the load. Both sides already have patches on the inside of the rail from several years ago. Driver side got the old metal cut out when it was patched, passenger side wasn't. So it will be double layered, in and out.
The plan where I need a little direction is where the original shock mounts were. The frame bulges around the rivet holes. On the driver side there's a lot of meat around them to cut them out and use a large patch around the hole. The passenger doesn't have as much room around the bulges. I'm thinking grind the bulges flush with the rest of the frame and plate over it. Thoughts?
1st pic is the passenger leaf spring hanger, 2nd is the passenger shock mount holes, if you look at the lower left, you can see where the frame bumps in over the axle, that's the clearance that I'm concerned with. 3rd is of the driver side shock mounts.
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 04:46 PM   #2 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Id plate over and where the rivets are Id hole saw holes and plug weld the bump out to the new plate. Id also fish mouth the plates.
Old 04-01-2019, 08:56 AM   #3 (permalink)
2big bronco's Avatar
Member # 66684
All of this. I always add a few holes and plug weld anyway when playing a frame.
if you didnt grow up riding, crashing, and fixing 3 wheelers you had a shitty childhood
Old 04-01-2019, 12:08 PM   #4 (permalink)
Member # 143737
Ok that's pretty much where I was at. Thanks
Old 04-02-2019, 04:07 AM   #5 (permalink)
arse_sidewards's Avatar
Member # 256962
If you need some perfectly pitted metal so you can say "well clearly it's been passing inspection for many years with that patch there" I have some F250 frame that I've been saving specifically for this kind of thing.
Also, my Ranger has the same holes just below the shock mounts. There's no good reason for that to rust out since nothing collects there. I suspect that it's a weak point that just shows up after 10yr of pounding from the shock so you should probably consider making your patch have a footprint that goes further to that side than just the bare minimum to cover the hole.
Old 04-02-2019, 09:55 AM   #6 (permalink)
JDWeeler's Avatar
Member # 170770
plate it and speed holes for more weld surface. if you do inside and out side make them different lengths so it spreads the strength out.
I ain't stuck,I've stopped to grab another beer :flipoff2:
JDWeeler is offline   Reply With Quote Quick reply to this message
Old 04-02-2019, 10:13 AM   #7 (permalink)
Member # 143737
Thanks but I'll pass, got a half sheet of 1/4" plate, not worried about the sticker, that's the easy part
Looks like the shock mount collects mud and shit? At least they did. They're cut off now.
Attachment 2925498
Hard to have weld surface when there's no metal underneath I'm trying to hide the junk frame while strengthening it
Old 04-02-2019, 10:19 AM   #8 (permalink)
Member # 256962
I'm talking about the hole outside the perimeter of the mounts. Mine has literally the same hole. No good reason for it to be there unless the mount is making the frame web flex.
Old 04-02-2019, 10:21 AM   #9 (permalink)
Member # 143737
Yeah true, went back and looked That is pretty fucked up
Similar Threads
Jeep YJ, TJ, & LJ Back Half Kits MotoBilt Suspension 9 05-06-2019 02:21 PM
FJ40 Frame Boxing Kit.....! Gravel Maker Suspension 32 11-17-2018 01:40 PM
1979 Jeep CJ7 Frame - No rust - $550 (20111) geohoss Misc. Stuff For Sale 6 04-06-2015 11:35 AM
COE car hauler project? 52K-mile 1999 Ford Super Duty (E350/450) Winnebago frame 1x1_Speed_Craig Misc. Stuff For Sale 3 02-07-2015 05:43 PM
