HP44 Axle Tube Length? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-04-2019, 11:28 PM   #1 (permalink)
Newbie
Member # 680402
Hoping someone on here might have a 1/2 ton Ford Dana 44 laying around that can help me with getting a measurement for the driver's side tube length (diff housing to inside edge of the C) and maybe a measurement from ball joint to ball joint? I've been searching online for a couple days now but can only find info on the WMS, retubing, or how much needs to be cut to work with a Jeep and other smaller vehicles...
Reason I ask is I found one out of a 70's F-150 with the welded on c-wedges pretty cheap because it has the drum brakes that nobody wants. I'm thinking about picking it up, grinding off the wedges and welding on some perches and then swapping everything from the knuckles out of a spare 10 bolt I have laying around to make a cheap hybrid HP44 to SAS a GMT400 truck down the road. Just trying to figure out if it's even possible before wasting a good chunk of my day off to go see/measure it in person. Thanks.
ps Yes I know there are other easier options out there (78-79 F-250 or 77-79 F-150 super cab axles) but they're hard to find and pricey when you do plus I already have a drilled and talked knuckle for crossover and everything to rebuild the Chevy outers so this would be a cheapish just for fun project.
NorCalAnthony is offline   Reply With Quote Quick reply to this message
Old 04-05-2019, 12:12 AM   #2 (permalink)
Member # 787073
hey man mine measured 53" upper balljoint to upper balljoint before narrowing and knowing how much was removed i just grabbed current measurements and added what was removed to get 24.5" from casting to C on the long side and 6.7" on the short side. I got lucky and scored a supercab axle for pretty cheap. Sounds like a solid plan as the outers should be a straight swap between 10 bolt and 44
4speedhandler is offline   Reply With Quote Quick reply to this message
Old 04-05-2019, 07:06 AM   #3 (permalink)
Newbie
Member # 680402
Thanks man appreciate it. Not sure that helps since it's a leaf spring axle with the perch taking away tube length though. Looks like it should be a lot more than 6.7" inches on the radius arm axles from the pictures online?
Old 04-05-2019, 11:15 PM   #4 (permalink)
Member # 787073
sorry i couldnt be more help. hope the balljoint measurement helped though
Similar Threads
Suck at search...leaf spring set up thread? squamch Toyota - Truck and 4Runner 26 09-09-2015 03:26 PM
Axle Shaft Length, Would you be concerned? TheHardWay9 General 4x4 Discussion 8 02-24-2015 06:47 AM
Suspension Help geota94 Toyota - Truck and 4Runner 56 11-01-2013 11:18 AM
Hp60 to rear conversion axle tube length Jby1999tj General 4x4 Discussion 2 04-23-2013 05:00 PM
Bastard Axle Technology Buck Dodson International Harvester 22 12-23-2012 09:20 PM
