Engine Stand Wiring help 2006 Cummins 5.9L - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2019, 12:45 PM   #1 (permalink)
Member # 866706
Thanks for viewing! I have a 2006 dodge Cummins 5.9L on and engine stand out of a 2500 ST and need to start and run it before swapping it into a 2008 F350 that had a 6.4L. Need help with what wires to use to start and run while on engine stand. Thank you
p100kman is offline   Reply With Quote Quick reply to this message
Old 04-07-2019, 07:25 PM   #2 (permalink)
Member # 200478
Go to https://quickserve.cummins.com/info/index.html
Register for a free account. Enter the s/n of your engine, then get the wiring diagram. You will need an electronic pedal, and supply 12v and ground to the proper pins. You can also find the part numbers for the repair pins for the oem harness, which you will need. Also, the pedals use delphi 150 pins i believe. You will need some of those. No need to actually get the connectors. Here is my 2004 ISL set up to run on a stand.
isbj60 is offline   Reply With Quote Quick reply to this message
Similar Threads
Stock 2006 dodge Cummins egt? gavan Tow Rigs and Trailers 21 04-04-2016 04:22 PM
Diesel Vs Big Block Gmm213 Mud 93 10-16-2014 06:57 AM
2006 Dodge Ram 2500 SLT, 5.9L Cummins, Big Horn, 4x4, Manual XJ_ranger Vehicles and Trailers For Sale 3 04-16-2013 10:23 PM
2000 z71 4x4 engine swap to 2006 aluminum block jpeters Chevy 3 02-26-2013 07:57 PM
2007 5.9L Cummins, mild mods, very clean, needs nothing bbaXJ Vehicles and Trailers For Sale 3 01-22-2013 01:08 PM
