Check axle tube for straightness - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-09-2019, 08:47 AM   #1 (permalink)
I over tighten sh!t
paulhead's Avatar
Member # 41976
whats a good way for a backyard mechanic to check that an axle housing is straight?
paulhead is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 09:38 AM   #2 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
I usually put the axle on jack stands and measure to the ground in several spots. If the concrete is flat that is. Toyota housings Iíve found them this way.
Old 04-09-2019, 09:48 AM   #3 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Put a straight edge along the tube.
& Blaine
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 04-09-2019, 10:48 AM   #4 (permalink)
Member # 4243
Works best of a rear axle out of the vehicle, with tires, chocked from rolling away.
Measure across the tire treads with a tape measure and have a buddy swing the pinion around. If the measurement changes, its bent.
Dodge cobbler... (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 12:49 PM   #5 (permalink)
Member # 192976
For Dana style axles, pull carrier and look down the tubes. Not the most perfect way but fairly easy to see.
04 TJ - Some links, small axles, and 38 TSL's
Carolina Trail Blazers
Redneck92 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 02:33 PM   #6 (permalink)
I over tighten sh!t
paulhead's Avatar
Member # 41976
thanx guys
Similar Threads
JK TO TJ AXLE SWAP KIT Artec Axles/Tires/Wheels 1 10-31-2016 08:43 AM
Toyota FJ Cruiser Front Axle Disconnect Actuator justdifferentials Axles/Tires/Wheels 0 11-15-2013 11:03 AM
JK axle gussets and sleeves justdifferentials Axles/Tires/Wheels 1 07-14-2013 07:29 PM
How can you tell if an axle tube is bent? doclouie Jeep - Non Hardcore 4 08-01-2012 12:41 AM
