To narrow or not to narrow. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-16-2019, 08:44 PM   #1 (permalink)
Member # 865174
First post here, thanks for the add BTW. Don’t know if this belongs in the Jeep Hardcore or not. I have a 02 TJ that I’ve building over the past year a little at a time $ dependent. I’ve owned a lot of Jeeps over my 50 years ( to this day I still regret selling my 83’ CJ8) but this is my first true build. Currently I have a F8.8 that I built in the rear (c clip eliminator making it WMS to WMS 61.6”) with a RE 7200 extreme duty long arm sus. The D30 is out and I have a line on a 76’ F150 Dana 44 for $200. From the research I’ve seen, that axle is 65.5” WMS to WMS. That’s a difference of 3.9” between front and rear. Is that enough of a difference to require the axle to still be shortened? I understand you still have to get the coil mounts centered under the vehicle. Any opinions would be welcome. I also have a NP241C drivers drop that I got from a guy who owed me some money. Anyone have any advice on swapping out a NP231 for a NP241C? This going to be going behind a 4L60E on the 5.3L swap I’m going to do. Thanks in advance for any input.
Hawkdriver is offline   Reply With Quote Quick reply to this message
Old 04-16-2019, 09:16 PM   #2 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
This is the perfect place for this thread. What size tires are you going to run?
& Blaine
:tank:
Old 04-16-2019, 09:20 PM   #3 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
The 241 has 2 problems.
Input spline and bolt pattern clocking
You can get clocking and adapter rings but you need to make sure they have seal extentions included.
You should be abole to swap the input gear from the 231 into the 241 as long as the 241 is 1994+
Old 04-16-2019, 09:41 PM   #4 (permalink)
YotaAtieToo's Avatar
Member # 25632
Get some ~1" 5x4.5 to 5x5.5 adapter/spacers for the rear and call it good. ~65" is a very nice width. If you are running small tires (33-35s) you can run ~5" back spacing. Or if you want 37s and a little more clearance and stability you can go with a 3.5-4" back spaced wheel.
Old 04-16-2019, 09:54 PM   #5 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
This is basically what I was thinking, I just didn’t want to spoonfeed him.
& Blaine
:tank:
Old 04-17-2019, 07:36 AM   #6 (permalink)
Member # 865174
Should have put that in there, plan on running 35”. The RE sus is 5.5”. I had given some thought to 1” spacers as well. Nice thing about the c clip eliminator shafts is that they are cut for 5x4.5 and 5x5.5. Thanks for the input on NP241C.
Old 04-17-2019, 10:58 AM   #7 (permalink)
Member # 25632
4" narrower in the rear is not a big deal. Many factory trucks are this way. Or run the spacers if you want it to be closer.
Old 04-17-2019, 11:05 AM   #8 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
61” or 65” wide front axle will work with that. If you were going 37’s, I like the extra width for steering clearance.
& Blaine
:tank:
Similar Threads
Narrow diff for independent suspension rcx950 General 4x4 Discussion 21 01-25-2015 08:37 AM
Narrow / wide radius arm bushes 100SRV Land Rover 30 07-29-2014 09:58 AM
Opinions Please: Axle swap or narrow 1tons 89lc Toyota - Truck and 4Runner 23 09-17-2013 10:13 PM
Poison Spyder Narrow JK Crusher Flares Dusty Body/Armor 5 07-11-2013 01:51 PM
