Machinists projects: tj edition - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-01-2019, 09:43 PM   #1 (permalink)
Member # 787073
Question Machinists projects: tj edition
As both a relative newbie in the 4x4 world and in the world of machining i'm looking to see what other machinists have done as far as projects on their TJ. I'm thinking I may make some links from aluminum or possibly another alloy depending on what cost i can get it for just because I like making my own stuff.
Also definitely contemplating making custom adapters for trans/t-case application as well as a custom intake manifold for a budget supercharged LS setup down the road. Most recent idea was to make an aluminum shell to replace the little tray above the radio that would house an air pressure gauge and switches for compressor/locker.
What have you guys custom machined for your TJ or other rig?
4speedhandler is offline   Reply With Quote Quick reply to this message
Old 05-02-2019, 05:38 AM   #2 (permalink)
Member # 143737
Nothing for my truck, too busy making rockets.
I buzz out little dub shit as I need it, but nothing trick. One day I'll throw together a doubler for fun.
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 05-02-2019, 06:06 AM   #3 (permalink)
Member # 85771
I machined a 60 brake caliper to fit a 15" wheel.
Make Forums Great Again!
ky scrambled is online now   Reply With Quote Quick reply to this message
Old 05-02-2019, 06:16 AM   #4 (permalink)
Member # 143737
See and for me, I think it would be quicker to grind the caliper than fixture it to machine it. If I was doing more than a pair it might make sense, but idk.
Maybe spending all day doing this stuff makes me hesitant to do it at home
Old 05-02-2019, 06:23 AM   #5 (permalink)
Member # 85771
You say grind, I say machine. Its like the tomato, tomato thing
Old 05-02-2019, 07:49 AM   #6 (permalink)
Master Baiter
Provience's Avatar
Member # 138976
little brackets and tabs, adapters, tube adapters, bushings, bearing supports.
machining isn't just mills and lathes, every time i flick on my 4.5" grinder i'm a machiner
edit: as another example, i could program a mill to cut out some brackets, or i could use a crayon and torch to cut them out in less time than it would take to setup and warmup the mill Still Machining
I just want to build cars, collect watches and get tattoos.
The largest tax modification in 30 years, check it out!
Old 05-02-2019, 07:59 AM   #7 (permalink)
Member # 85771
Dats right!
Old 05-02-2019, 08:05 AM   #8 (permalink)
Member # 143737
4.5" grinder? Pssht, Makita 7" is where its at
I guess depends on what I'm making, I'm lazy and do whatevers quicker
Old 05-03-2019, 04:11 AM   #9 (permalink)
arse_sidewards's Avatar
Member # 256962
You need a rotary table in your life.
Old 05-03-2019, 05:48 AM   #10 (permalink)
Member # 143737
Yes I do.
Similar Threads
Ultimate Wrangler Build Ups and Swaps thread gtxracer Jeep - Hardcore Tech 364 09-28-2017 04:54 AM
Lots of Jeep TJ parts MO1535M Misc. Stuff For Sale 38 01-28-2016 05:10 PM
TJ 2.5 to 4.0 swap using XJ driveline - gauge BUS / wiring questions bwiencek Jeep - Hardcore Tech 0 02-12-2015 09:49 AM
