Used gear set up question. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-09-2019, 06:29 PM   #1 (permalink)
Member # 120004
I've searched around and I'm still having trouble. (I'm a borderline functional retard btw)
I'm installing a used set of gears in to a rear D60. I haven't pulled the carrier bearings or adjusted the shims on it so it's still set from the factory.
Should I just set the pinion depth and run it? This is the pattern I got by matching the factory shim pack on the pinion. Backlash is 10 thousandths.
my truck might not be pretty but neither is your mom but she gets the job done and so does my truck!
rowdy fitzgerald is offline   Reply With Quote Quick reply to this message
Old 05-09-2019, 06:32 PM   #2 (permalink)
Member # 120004
This is about 6 thousandths added to the pinion and the back lash opened up to 14 thousandths.
Old 05-09-2019, 08:18 PM   #3 (permalink)
Member # 120004
Backlash is 10 thousands and this is the coast side.
Old 05-10-2019, 01:24 PM   #4 (permalink)
Member # 4243
I like the first pic best.... get the backlash down a couple more thou' and check.
Drive side more important on rear than coast. With used gears you can often only get the pattern so good, because of wear.
Dodge cobbler... (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 05-11-2019, 04:20 AM   #5 (permalink)
Member # 120004
Thanks, I think I've got it whooped. The coast side is centered and the drive side looks good too. I didn't get it finished but the pattern is much better. I forgot to take a picture before I left for work.
Old 05-11-2019, 10:01 PM   #6 (permalink)
CSP
Member # 1533
Is the pattern close to what it was as previously installed?
Used gears will show you what their pattern was.
CSP is offline   Reply With Quote Quick reply to this message
Old 05-12-2019, 01:55 PM   #7 (permalink)
Member # 120004
I dont know what the pattern was on the gears I am installing. I got them used from a co-worker.
Old 05-14-2019, 07:14 PM   #8 (permalink)
lil,yota's Avatar
Member # 102395
The shiney area on the used gears will be the old pattern
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 09:57 AM   #9 (permalink)
Member # 120004
It's a odd shape but it's within the desired area.
Old 05-15-2019, 10:28 AM   #10 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
I'll post these here for others future reference.
Like I said in your build thread. That pattern shows the pinion is too deep. Pull 2 thousandths and it should be good to go. With used gears you're going to fight an uphill battle to get an accurate pattern. It looks like they were installed on the edge of shallow fron the start. The likelihood of getting a good patern ar this point is pretty low. You'll instead just keep getting the old pattern. Now it looks like you've moved to a completely virgin part of the gear, which at least is showing you something other than the original setup. From there you can back the pinion out to what should be a good position.
Action Fab is online now   Reply With Quote Quick reply to this message
Old 05-15-2019, 12:56 PM   #11 (permalink)
Member # 120004
Sorry I took so long, I had to wait for the race to get to temp. So here's 2 thou removed. I feel like the it's now settled into the original wear pattern.
Old 05-15-2019, 01:01 PM   #12 (permalink)
Member # 120004
Old 05-15-2019, 01:52 PM   #13 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Run it, man.
Old 05-15-2019, 04:06 PM   #14 (permalink)
Member # 120004
Thank you for all the help!
Similar Threads
Junkyard axles to look for.. rabbiporkchop General 4x4 Discussion 4 02-14-2017 09:06 AM
Gear Set Question! toolman4x460 Newbie General 4x4 Discussion 10 02-06-2015 12:26 PM
Toyota Gear Packages justdifferentials JTS Parts & Accessories 0 12-28-2014 08:26 PM
NIB Trail Gear Samurai 6.5 Gear Set with new Bushing rubilooe Engines/Trannys/T-Cases For Sale 0 12-29-2013 10:46 AM
