Bronze Kingpin Bushing Install Issues? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-15-2019, 01:56 AM   #1 (permalink)
Member # 74066
I'm installing my Bronze Kingpin bushings in my '92 Dodge Dana 60. When installing the bushings in the knuckles, and then installing the roll pins supplied, the roll pins seem to fit like shit. They are super tight to get in, and I had to hammer the hell out of them to get them to just sit flush with the top of the bushing, and I can't get them any deeper than just flush with the top of the bushing, yet they are much shorter than the notch in the bushing, so they should be able to recess in a bit. The knuckles are pretty tight to turn now without even having the steering arms on. Should I just leave them as-is, or pull those roll pins and get different roll pins that are a bit smaller diameter and use them? Shouldn't they just tap into place relatively easily instead of beating the hell out of them?
92 YJ, stroker, 4-linked, ORIs, full hydro, 60/shaved 14b, detroits, 114", 40" sticky Treps, KMCs
SkysTheLimit is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 07:49 AM   #2 (permalink)
Member # 50690
Send a message via MSN to jemarshall
Leave them as is, put a couple of miles on them and then re-adjust the pre-load. They are always a tight fit on initial install.
I am figuring you are running arms with the screw adjuster instead of the spring set up, right?
What ever you do, please do not suck start a shot gun.
Stick it up your ass...that way you're likely to hit something vital.
jemarshall is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 02:15 AM   #3 (permalink)
Newbie
anwat's Avatar
Member # 867202
I had to pound the hell out of mine, too. I think they're supposed to be pretty tight, think about the vibration and force that's going to be trying to make them come out. They won't get any tighter, but in a couple hundred miles, they will be looser!
anwat is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 01:16 AM   #4 (permalink)
Member # 74066
Yes, I'm running arms with the screw adjuster, so I can tighten them back up as they loosen up once I get the Jeep under it's own weight and mobile again. The upper kingpin spring setup is gone, now.
Old 07-10-2019, 03:04 AM   #5 (permalink)
Newbie
YJUnlimited's Avatar
Member # 870338
I donít recall having to beat the hell out of mine. Iím pretty sure I just tapped them in with a hammer.
87 YJ, Unlimited stretch, TPI 350, links, tons, 4Dís, and stuff.
YJUnlimited is offline   Reply With Quote Quick reply to this message
Similar Threads
reid racing bronze KP bushing with crane knuckle phi564 General 4x4 Discussion 12 09-25-2013 09:18 AM
Front Spring Bushing issues ryanonthevedder Toyota - Truck and 4Runner 1 08-02-2013 08:15 PM
Bronze spindle bushing problems [email protected] General 4x4 Discussion 7 06-17-2012 09:13 AM
