3500 for a bulletproof trans, or LS swap? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2019, 11:17 AM   #1 (permalink)
Member # 322034
Got a dodge dakota with a 5.9 that I want to put some heads/intake/cam on, maybe eventually a blower. I have heads/intake already. Truck needs a new trans. There's a reputable shop that builds a nice 46re (up to 750hp) for 2500 plus about 1000 for installation, putting me at 3500 for the trans. Then I will probably be about 1000 into a new cam, lifters, springs, throttle body, tune, getting me to maybe 340hp/380tq.
My question is, is it more logical to put the 4500 towards an LS/LQ swap? Being in California I would have to deal with making it CARB legal, pretty sure exhaust wouldn't be an issue, but not sure if fuel tank needs to be swapped as well. Will be a bigger project, but a 6.0 is a better platform.
Kind of torn on this, would like to keep it MOPAR but want to be stupid with my money
Thanks
montrose818 is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 07:00 PM   #2 (permalink)
RXT
RXT's Avatar
Member # 493505
It looks like you can save a bunch of money if you keep things simple. For one, it looks like you'd be putting more money into a trans thats over built for your engine build (46RE built up to 750hp for a 340hp 5.9) A 46RE can handle 340hp. So if it were me, I'd look for a 46RE thats either in usable shape or do a basic rebuild maybe add some small upgrades but not a lot. Next $1000 to install a transmission seems a bit high. I would do the installation myself and save that money for something else.
An LS swap is totally up to you. I do not live in Ca. but as I understand it, it's going to be difficult to comply with CARB which seems to get more restrictive every year. All I can suggest is do your homework and talk to those who specialize in LS swaps in your state to get the low down on all the legalities. Personally I think it can cost you more than $4500 to successfully swap the LS. Expect some hidden costs.
Ed
99 Dakota, Cummins, 47RE, NP241HD, Dana60/70, 41.5 Rockers. I love it when a plan comes together!
RXT is offline   Reply With Quote Quick reply to this message
Old 08-17-2019, 08:35 PM   #3 (permalink)
Old School
Technohead's Avatar
Member # 130090
$/horsepower LS is the only platform that makes sense. That said, if the budget is 4500 then the rebuilt 46re with some tweaks to the magum motor is the way to go. Scratch the blower Idea.
-Eric
Redneck-at-Large
Technohead is offline   Reply With Quote Quick reply to this message
Old 08-17-2019, 08:55 PM   #4 (permalink)
Member # 56430
Thanks
Strip out the 5.9 and sell it to some fool whom owns a TJ, and tell him how easy that would be.... then sell whatever is leftover from the Dakota and be happy it's gone.
Then... take the profits from above sales, and the 4500 you already were ready to spend, and go buy a GM vehicle. Done.
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12-'13
Member Eldorado Dust Devils, a PNW4WDA member
Treeclimber is offline   Reply With Quote Quick reply to this message
Old 08-17-2019, 08:58 PM   #5 (permalink)
Member # 79509
Sounds like he's not ready to suck dick, just wants to put it in his mouth.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 08-18-2019, 06:20 AM   #6 (permalink)
Member # 166653
$1000 to install a tranny? Buy a case of beer and have a buddy with a transmission jack come over. For someone who knows what they are doing this is a couple hour job. For someone with only a basic understanding it might be a weekend job.
As others have said, a 750hp rated tranny is overkill. If you are on a tight budget, get a basic rebuild and spend your money elsewhere.
If you are thinking about spending $1000 to have a tranny swapped, you are not ready for an LS swap. I am not a purist by any means but why would you want a LS when you can get 340hp out of your current engine? Yes it is cheaper and easier to get power out of a Chevy, but for the money you are spending to put a Chevy in your Dodge, you can build quite a bit of power from your 360.
Now for the best advice of all:
Take your $4500 and spend it on moving out of Commifornia. Just make sure you don't bring socialism with you to a free state. Then you actually get to keep more of your money, and with a cheaper cost of living combined with no CARB, you can build what you want for less money much easier.
4seasons is offline   Reply With Quote Quick reply to this message
Old 08-18-2019, 11:16 AM   #7 (permalink)
Member # 322034
I'm very attached to the Dakota platform, so that's staying.. I got a nice cowl hood, Hotchkis, and some other goodies. I've had Dakotas since 2003, and have grown very sentimental to them.
I have Magnum R/T heads, M1 intake 92/93 dakota manifolds (larger collector), a Hughes cam, and a flashed ECU (which I doubt I'll be able to reuse since its from a 5.2) from my old setup.. that had a 44re and it handled burnouts, 4x4, and drag strip without as much as a fluid change. 46re seems to bring the suck. I just figured it will cost me at least 1000 to get whatever I need to put the parts in my new truck, plus the tranny.
My reason for wanting to go LS is cheap transmissions and better MPG. 11.5 MPG brings teh suck.
The 750hp 46re is basically his standard build. I called some local shops, and they want about 2k for a regular rebuilt trans. The 46re in the truck was rebuilt about 50k ago (I wasn't the owner back then) and has been having issues shortly after the build, so I don't mind paying extra for something that will last.
I was being lazy about swapping it myself, maybe I am getting older and tired, but if you folks say 1k is too much, then I guess a weekend of work is in order. I have watched videos on rebuilding a 46re, but transmissions are foreign to me, and if I go through the work and end up needing to redo something, I will hate having to do all that work again, so I don't mind paying to get it right.
Sounds like paying for the trans and swapping myself is the idea. LS swaps seem easy, but yes I do live in California and no idea what would be needed to make it legal.
Thanks!
Old 08-18-2019, 11:16 AM   #8 (permalink)
Member # 322034
not sure if stab at me or LS platform
Old 08-19-2019, 01:17 AM   #9 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
You want an LS, but not a Chevy. Just the tip.
We had part of a slinky. But I straightened it.
Subybaja is offline   Reply With Quote Quick reply to this message
Old 08-19-2019, 08:41 AM   #10 (permalink)
Member # 278
You might call the ref before thinking you're going down the engine swap hole. I have heard it is now beyond a nightmare for rigs that have to be smog compliant. A shop I know of that used to do a LOT of smog compliant LS swaps quit doing the smog complaint version due to the new interpretation of the rules.
Since you mention smog compliant, you might double check your heads and intake to ensure they are smog compliant also.
I can't help on the tranny. Some of the skim reading I've done in the past implied the 46re was a large chunk of crap that barfs the first time you look at it... basically Dodge's version of a 700r4. Others claim a simple rebuild and it is good for thousands of hp
-1971 FJ55(aka Trail55): 6.0L-NV4500-LC split case, SOA, D60s, ARB'd... and cupholders
-1972 FJ55(aka Trail50): Turbo 5.3L-4L80-Blackbox-split case, D60s, ARB'd *stalled*
-1968 Mustang Fastback: not a restore but a refresh
Lil'John is offline   Reply With Quote Quick reply to this message
Old 08-19-2019, 08:58 AM   #11 (permalink)
Member # 322034
Interesting, I thought LS was "the" platform.
Old 08-26-2019, 11:31 AM   #12 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
It is. Once you start playing with a hot rod 5.9, you will want to burn the Dakota to the ground. The electronics are nowhere near as good as LS stuff.
& Blaine
:tank:
Old 08-26-2019, 02:54 PM   #13 (permalink)
Member # 79509
Correct
End of the day theyre both pushrod engines and he's not chasing the last horsepower.
If a 48RE can do 200k miles towing with a 300/600 engine in front of it, it can push around a dakota. Pretty sure they were offered in the 3500 with the 360 gasser. I'm not privy of the parasitic loss.
For fuel/ignition... I'm sure someone makes a >$1000 CARB legal bolt on, self tuning, throttle body kit.
