Dana 44 Axle ID - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-15-2005, 08:09 AM   #1 (permalink)
85GAJEEPCJ7's Avatar
Member # 27047
Dana 44 Axle ID
I picked up an axle this weekend and I am trying to figure out what it came out of. I was told a wagoneer but now I am not sure.
On the top of the pumpkin it has these numbers:
C38529
44-1f
There is no BOM number anywhere on the axle tubes
It measures 51.5 inches from center of the balljoints on the housing
65 inches WMS to WMS
6 lug
No flat tops
Can anyone help me identify it.
Thanks.
www.ox-usa.com
85GAJEEPCJ7 is offline   Reply With Quote Quick reply to this message
Old 08-15-2005, 08:40 AM   #2 (permalink)
Benzz0's Avatar
Member # 22923
look for the BOM on the tube...
match it up to one of these
603311-1,3JEEP 30 FRONT 1971 CJ-5, CJ-6, CJ-7 GEARS: 3.73
603311-2,4 JEEP 30 FRONT 1971 CJ-5, CJ-6, CJ-7 GEARS: 4.27
603365-1,3 JEEP 30 FRONT 1972-75 CJ-5,CJ-6, CJ-7 GEARS: 3.73
603365-2,4 JEEP 30 FRONT 1972-75 CJ-5, CJ-6, CJ-7GEARS: 4.27
603365-5 JEEP 30 FRONT 1972-75 CJ-5, CJ-6, CJ-7 GEARS: 4.88
603573-1 JEEP 30 FRONT 1976 CJ-5, CJ-6, CJ-7 GEARS: 3.07
603573-2 JEEP 30 FRONT1976 CJ-5, CJ-6, CJ-7 GEARS: 3.54
603573-3,4 JEEP 30 FRONT 1976 CJ-5,CJ-6, CJ-7 GEARS: 4.10
603732-2, 5 JEEP 30 FRONT 1976 CJ-5, CJ-6, CJ-7GEARS: 3.54
603732-3, 4 JEEP 30 FRONT 1976 CJ-5, CJ-6, CJ-7 GEARS: 4.10
603470 JEEP 60 REAR 1979 J20 PICKUP
603683 JEEP 44 FRONT 1978-79 WAGONEER / CHEROKEE
603685 JEEP 44 FRONT 1978-79 J10, J20, HONCHO, CHEROKEE WIDE TRACK
603732 JEEP 30 FRONT 1978 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
603815 JEEP 44 REAR 1977-79 CHEROKEE CHIEF (STD TRANSFER CASE)
603816 JEEP 44 REAR 1977-79 WAGONEER & CHEROKEE (STD TRANSFER CASE)
603817 JEEP 44 REAR 1977-79 WAGONEER & CHEROKEE (QUADRA-TRAC TRANSFER CASE)
603818 JEEP 44 REAR 1977-79 CHEROKEE CHIEF QUADRA-TRAC
603820 JEEP 44 REAR 1977-80 POST OFFICE DISPATCHER
603930 JEEP 60 REAR 1978-79 J20 PICKUP
603941 JEEP 44 REAR 1979 J10 & HONCHO TRUCK
603980 JEEP 60 REAR 1980-81 1/2 J20 PICK-UP
605079 JEEP 60 REAR 1982-85 J20 PICK-UP
605103 JEEP 44 REAR 1982-84 CJ10
605104 JEEP 60 REAR 1982 1/2-84 CJ10
605196 JEEP 60 REAR 1985 AM 720
605236 JEEP 44 REAR 1985 CJ10
605237 JEEP 60 REAR 1985 CJ10
605242 JEEP 70 REAR 1985 CJ 10A MILITARY
605285 JEEP 44 REAR 1986 GRAND WAGONEER
605286 JEEP 44 REAR 1986 J10 PICKUP
605287 JEEP 44 REAR 1986 XJ METRIC TON TRUCK
605289 JEEP 44 REAR 1986 CJ7
605290 JEEP 35 REAR 1986 XJ UTILITY
605291 JEEP 60 REAR 1986-88 J20 PICKUP
605292 JEEP 35 REAR 1986 XJ TRUCK
605293 JEEP 35 REAR 1986 XJ UTILITY
605294 JEEP 35 REAR 1986 XJ PICKUP
605295 JEEP 35 REAR 1987-89 YJ
605315 JEEP 35 REAR 1985 1/2 XJ UTILITY
605316 JEEP 35 REAR 1985 1/2 XJ UTILITY
605323 JEEP 35 REAR 1987-89 XJ UTILITY
605324 JEEP 35 REAR 1987-89 XJ PICKUP
605325 JEEP 44 REAR 1987-93 1/2 XJ METRIC TON TRUCK, XJ HD TRUCK
605329 JEEP 44 REAR 1987-92 GRAND WAGONEER
605330 JEEP 44 REAR 1987-88 J10 PICKUP
605339 JEEP 44 REAR 1988 1/2-96 1/2 YJ
605342 JEEP 44 REAR 1987-87 1/2 XJ UTILITY
605351 JEEP 35 REAR 1988-89 XJ UTILITY, TRAILER TOW, ABS
605387 JEEP 35 REAR 1988 1/2-89 XJ UTILITY, I-6 AUTOMATIC
605389 JEEP 35 REAR 1988 1/2-89 XJ UTILITY, TRAILER TOW
605416 JEEP 35 REAR 1990-90 1/2 XJ UTILITY
605423 JEEP 35 REAR 1990-90 1/2 YJ
605425 JEEP 35 REAR 1990-90 1/2 MJ PICKUP
605427 JEEP 35 REAR 1990-91 1/2 XJ UTILITY, TRAILER TOW, ABS
605443 JEEP 35 REAR 1990-90 1/2 XJ UTILITY, I-6 AUTOMATIC
605444 JEEP 35 REAR 1990-90 1/2 XJ UTILITY, TRAILER TOW
605455 JEEP 35 REAR 1988-89 XJ PICKUP
605475 JEEP 35 REAR 1993-94 ZJ ABS
605483 JEEP 35 REAR 1990-92 1/2 XJ UTILITY
605484 JEEP 35 REAR 1990-92 1/2 XJ UTILITY, I-6 AUTOMATIC
605485 JEEP 35 REAR 1990-92 1/2 XJ UTILITY, TRAILER TOW
605500 JEEP 35 REAR 1991-93 1/2 MJ PICKUP
605502 JEEP 35 REAR 1991-93 1/2 YJ
605507 JEEP 35 REAR 1993-94 ZJ T/TOW, ABS
605525 JEEP 35 REAR 1992-93 1/2 YJ ABS
605528 JEEP 35 REAR 1993-93 1/2 YJ ABS
605534 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
605535 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
605536 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
605541 JEEP 35 REAR 1992-93 1/2 YJ ABS
605564 JEEP 35 REAR 1992-93 1/2 YJ ABS
605579 JEEP 35 REAR 1993-94 XJ UTILITY ABS
605602 JEEP 35 REAR 1994 ZJ ABS
605607 JEEP 35 REAR 1994 ZJ ABS
605655 JEEP 35 REAR 1994 XJ UTILITY, STD
605656 JEEP 35 REAR 1994 XJ UTILITY
605657 JEEP 35 REAR 1994 XJ UTILITY ABS
605658 JEEP 35 REAR 1994 XJ UTILITY ABS
605659 JEEP 35 REAR 1994 XJ UTILITY ABS
605660 JEEP 35 REAR 1994 XJ UTILITY
605661 JEEP 35 REAR 1994-96 YJ/TJ
605662 JEEP 35 REAR 1994-96 YJ/TJ ABS
605706 JEEP 35 REAR 1995-96 ZJ ABS
605707 JEEP 35 REAR 1995-96 ZJ ABS
605725 JEEP 35 REAR 1994 XJ UTILITY ABS (NEW MODEL NUMBER 194)
605727 JEEP 35 REAR 19950-96 1/2 XJ UTILITY ABS
605728 JEEP 35 REAR 1995-96 XJ UTILITY, STD
605729 JEEP 35 REAR 1995-96 XJ UTILITY
605730 JEEP 35 REAR 1995-96 1/2 XJ UTILITY ABS
605731 JEEP 35 REAR 1995-96 XJ UTILITY ABS
605732 JEEP 35 REAR 1995-96 1/2 XJ UTILITY ABS
605733 JEEP 35 REAR 1995-96 1/2 XJ UTILITY
605735 JEEP 44 REAR 1996-97 ZJ ABS
605746 JEEP 35 REAR 1996 1/2 YJ/TJ ABS
605747 JEEP 35 REAR 1996 1/2 YJ/TJ (NEW MODEL NUMBER 194)
605775 JEEP 35 REAR 1996-96 1/2 XJ DIESEL
605776 JEEP 35 REAR 1996-96 1/2 XJ DIESEL
605797 JEEP 35 REAR 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 194)
605798 JEEP 35 REAR 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 194)
605849 JEEP 44 REAR 1997 TJ NON ABS (NEW MODEL NUMBER 216)
605893 JEEP 35 REAR 1996 1/2 XJ UTILITY, STD (NEW MODEL NUMBER 194)
605894 JEEP 35 REAR 1996 1/2 XJ UTILITY (NEW MODEL NUMBER 194)
605895 JEEP 35 REAR 1996 1/2 XJ UTILITY ABS (NEW MODEL NUMBER 194)
605909 JEEP 35 REAR 1996 1/2 XJ DIESEL, ABS (NEW MODEL NUMBER 194)
605913 JEEP 35 REAR 1997 XJ UTILITY ABS (NEW MODEL NUMBER 194)
605914 JEEP 35 REAR 1997 XJ UTILITY ABS (NEW MODEL NUMBER 194)
605916 JEEP 35 REAR 1997 XJ DIESEL, NON ABS (NEW MODEL NUMBER 194)
605918 JEEP 35 REAR 1997 XJ UTILITY, ABS (NEW MODEL NUMBER 194)
605919 JEEP 35 REAR 1997 XJ DIESEL ABS (NEW MODEL NUMBER 194)
605952 JEEP 44 REAR 1997 TJ RHD, NON ABS (NEW MODEL NUMBER 216)
605956 JEEP 35 REAR 1997 TJ ABS (NEW MODEL NUMBER 194)
605957 JEEP 35 REAR 1997 TJ NON ABS (NEW MODEL NUMBER 194)
605960 JEEP 35 REAR 1997 ZJ ABS (NEW MODEL NUMBER 194)
605961 JEEP 35 REAR 1997 ZJ ABS (NEW MODEL NUMBER 194)
605962 JEEP 44 REAR 1997 ZJ ABS (NEW MODEL NUMBER 216)
610053 JEEP 30 FRONT 1979 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
610078 JEEP 30 FRONT 1980-81 IFS - EAGLE - NON-DISCONNECT
610086 JEEP 30 FRONT 1980 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
610089 JEEP 44 FRONT 1980 J10, J20, WIDE TRACK CHEROKEE
610090 JEEP 44 FRONT 1980 WAGONEER / CHEROKEE
610134 JEEP 30 FRONT 1981 IFS - EAGLE - DISCONNECT
610136 JEEP 30 FRONT 1981 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
610139 JEEP 44 FRONT 1981-85 J10, J20, WIDETRACK CHEROKEE
610140 JEEP 44 FRONT 1981-85 WAGONEER / CHEROKEE
610152 JEEP 30 FRONT 1982-82 1/2 IFS - EAGLE - NON DISCONNECT
610153 JEEP 30 FRONT 1982-82 1/2 IFS - EAGLE - DISCONNECT
610154 JEEP 30 FRONT 1981 1/2 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
610156 JEEP 30 FRONT 1982-83 CJ5 - EXTERNAL TYPE WHEEL END
610157 JEEP 44 FRONT 1982-84 WAGONEER, CHEROKEE DISCONNECT STD TRACK
610158 JEEP 44 FRONT 1982-84 J10, J20, WIDE TRACK CHEROKEE
610164 JEEP 30 FRONT 1982-87 CJ7/CJ8 - EXTERNAL TYPE WHEEL END
610172 JEEP 30 FRONT 1984 XJ DISCONNECT, CV
610173 JEEP 30 FRONT 1983-84 IFS - EAGLE - NON-DISCONNECT
610174 JEEP 30 FRONT 1983-84 IFS - EAGLE - DISCONNECT
610175 JEEP 30 FRONT 1984-87 XJ DISCONNECT, CARDAN
610182 JEEP 30 FRONT 1984-85 XJ DISCONNECT, CARDAN, SYSTEM SENTRY
610183 JEEP 30 FRONT 1985-87 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
610206 JEEP 30 FRONT 1985 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
610221 JEEP 30 FRONT 1985 XJ NON-DISCONNECT, CV, SYSTEM SENTRY - LIVE SPINDLE WHEEL END
610222 JEEP 30 FRONT 1985-86 XJ NON-DISCONNECT, CV - LIVE SPINDLE WHEEL END
610227 JEEP 44 FRONT 1985 GRAND WAGONEER
610228 JEEP 44 FRONT 1985 4X2, MILITARY - DEAD FRONT
610234 JEEP 30 FRONT 1985-86 XJ 4X2, SYSTEM SENTRY (DEAD FRONT)
610235 JEEP 30 FRONT 1985-87 1/2 IFS - EAGLE - NON-DISCONNECT - CV
610237 JEEP 30 FRONT 1985 XJ 4X2, SYSTEM SENTRY (DEAD FRONT)
610244 JEEP 30 FRONT 1986 CJ7, LH STEERING, H/L - EXTERNAL TYPE WHEEL END
610246 JEEP 44 FRONT 1986 J10 PICKUP
610247 JEEP 44 FRONT 1986 GRAND WAGONEER
610248 JEEP 44 FRONT 1986 J20
610256 JEEP 30 FRONT 1986-89 XJ 4X2 (DEAD FRONT)
610259 JEEP 30 FRONT 1986 YJ DISCONNECT
610269 JEEP 30 FRONT 1986 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610279 JEEP 30 FRONT 1987 1/2-88 XJ DISCONNECT
610280 JEEP 30 FRONT 1987 1/2-88 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610281 JEEP 30 FRONT 1987-88 YJ DISCONNECT
610282 JEEP 30 FRONT 1987-88 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610283 JEEP 44 FRONT 1987-88 GRAND WAGONEER
610284 JEEP 44 FRONT 1987-87 1/2 J10
610285 JEEP 44 FRONT 1987-87 1/2 J20
610294 JEEP 30 FRONT 1987 1/2-88 XJ NON-DISCONNECT, ABS, ANTI SKID - LIVE SPINDLE WHEEL END
610297 JEEP 30 FRONT 1988 XJ DISCONNECT, VALEO EXPORT
610316 JEEP 30 FRONT 1992 1/2-93 1/2 XJ 4X2 (DEAD FRONT)
610317 JEEP 30 FRONT 1990-90 1/2 XJ DISCONNECT
610318 JEEP 30 FRONT 1990-91 1/2 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610319 JEEP 30 FRONT 1990-90 1/2 YJ DISCONNECT
610320 JEEP 30 FRONT 1990-91 1/2 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610321 JEEP 30 FRONT 1988 1/2-89 XJ DISCONNECT
610322 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610323 JEEP 30 FRONT 1988 1/2-89 YJ DISCONNECT
610324 JEEP 30 FRONT 1988 1/2-89 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610325 JEEP 44 FRONT 1988 1/2-92 GRAND WAGONEER
610327 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT, ABS, ANTISKID - LIVE SPINDLE WHEEL END
610328 JEEP 30 FRONT 1988 1/2-89 XJ DISCONNECT, VALEO EXPORT
610334 JEEP 30 FRONT 1988 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
610336 JEEP 30 FRONT 1990-91 1/2 XJ NON-DISCONNECT, ABS - LIVE SPINDLE
610337 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
610339 JEEP 30 FRONT 1990-90 1/2 XJ DISCONNECT, VALEO EXPORT
610340 JEEP 30 FRONT 1990-90 1/2 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
610346 JEEP 30 FRONT 1992 1/2-93 ZJ ABS, CV JOINT
610348 JEEP 30 FRONT 1992-93 1/2 XJ 4X2 (DEAD FRONT), ABS
610351 JEEP 30 FRONT 1990 1/2-91 1/2 XJ 4X2 (DEAD FRONT)
610361 JEEP 30 FRONT 1991-91 1/2 XJ DISCONNECT
610362 JEEP 30 FRONT 1991-91 1/2 YJ DISCONNECT
610363 JEEP 30 FRONT 1991 XJ DISCONNECT
610367 JEEP 30 FRONT 1995-97 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
610372 JEEP 30 FRONT 1991 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610373 JEEP 30 FRONT 1991 XJ NON-DISCONNECT
610374 JEEP 30 FRONT 1991 XJ NON-DISCONNECT, ABS
610375 JEEP 30 FRONT 1991 XJ 4X2 (DEAD FRONT)
610377 JEEP 30 FRONT 1992 1/2-93 ZJ ABS
610379 JEEP 30 FRONT 1992-93 1/2 XJ NON-DISCONNECT, ABS
610381 JEEP 30 FRONT 1993-93 1/2 YJ DOSCONNECT ABS
610391 JEEP 30 FRONT 1992-93 1/2 XJ NON-DISCONNECT
610392 JEEP 30 FRONT 1992-93 1/2 YJ NON-DISCONNECT
610393 JEEP 30 FRONT 1992-93 1/2 YJ DISCONNECT
610400 JEEP 30 FRONT 1993 ZJ (DEAD FRONT), ABS
610401 JEEP 30 FRONT 1991 1/2 XJ DISCONNECT
610402 JEEP 30 FRONT 1991 1/2 XJ NON-DISCONNECT
610403 JEEP 30 FRONT 1991 1/2 XJ NON-DISCONNECT, ABS
610404 JEEP 30 FRONT 1991 1/2-92 1/2 XJ 4X2 (DEAD FRONT)
610416 JEEP 30 FRONT 1993 XJ 4X2 (DEAD FRONT), ABS
610417 JEEP 30 FRONT 1993-93 1/2 XJ NON-DISCONNECT, ABS
610438 JEEP 30 FRONT 1993 ZJ ABS, CV JOINT
610449 JEEP 30 FRONT 1993 1/2 ZJ ABS
610450 JEEP 30 FRONT 1993 1/2 ZJ ABS
610451 JEEP 30 FRONT 1993 1/2 ZJ ABS
610452 JEEP 30 FRONT 1993 1/2 ZJ (DEAD FRONT), ABS
610461 JEEP 30 FRONT 1994-96 YJ DISCONNECT
610462 JEEP 30 FRONT 1994-96 YJ DISCONNECT
610463 JEEP 30 FRONT 1994-96 YJ NON-DISCONNECT
610464 JEEP 30 FRONT 1994 YJ DISCONNECT
610465 JEEP 30 FRONT 1994 ZJ (DEAD FRONT), ABS
610466 JEEP 30 FRONT 1994 XJ NON-DISCONNECT
610467 JEEP 30 FRONT 1994 XJ NON-DISCONNECT
610473 JEEP 30 FRONT 1994-96 ZJ ABS
610474 JEEP 30 FRONT 1994-94 1/2 ZJ ABS
610475 JEEP 30 FRONT 1994-97 ZJ (DEAD FRONT), ABS
610478 JEEP 30 FRONT 1994-96 ZJ ABS
610489 JEEP 30 FRONT 1997 TJ RHD, NON ABS (NEW MODEL NUMBER 181)
610500 JEEP 30 FRONT 1994 1/2-96 XJ 4X2 (DEAD FRONT)
610501 JEEP 30 FRONT 1994 1/2-97 XJ 4X2 (DEAD FRONT), ABS
610502 JEEP 30 FRONT 1994 1/2-97 XJ NON-DISCONNECT
610503 JEEP 30 FRONT 1994 1/2-97 XJ NON-DISCONNECT, ABS
610504 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
610505 JEEP 30 FRONT 1994 1/2-97 XJ RHD, ABS (NEW MODEL NUMBER 181)
610506 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
610507 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
610557 JEEP 30 FRONT 1995 1/2-97 XJ RHD, NON ABS (NEW MODEL NUMBER 181)
610558 JEEP 30 FRONT 1995-97 XJ NON-DISCONNECT, ABS
610572 JEEP 30 FRONT 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 181)
610573 JEEP 30 FRONT 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 181)
610629 JEEP 30 FRONT 1997 TJ ABS (NEW MODEL NUMBER 181)
610630 JEEP 30 FRONT 1997 TJ
610663 JEEP 30 FRONT 1997 ZJ ABS (NEW MODEL NUMBER 181)
610664 JEEP 30 FRONT 1997 ZJ ABS (NEW MODEL NUMBER 181)
610665 JEEP 30 FRONT 1997 ZJ (DEAD FRONT), ABS (NEW MODEL NUMBER 181)
كافر
Benzz0 is offline   Reply With Quote Quick reply to this message
Old 08-15-2005, 03:51 PM   #3 (permalink)
Member # 27047
As I said, there is no number that I can find on the tubes.
For future reference for others though, here is a list of Bill of Materials for Dana Axles.
http://www.therangerstation.com/tech...M_numbers.html
www.ox-usa.com
Old 08-16-2005, 07:32 AM   #4 (permalink)
Member # 27047
Ok. I found a number and now I cannot find it in the listings.
BOM # is
610036
www.ox-usa.com
Old 11-07-2007, 03:24 PM   #5 (permalink)
Member # 101688
I have a 610035 and it is a 1978 scout ll D44. I dont know why scout axles are not listed in BOM
1977 is offline   Reply With Quote Quick reply to this message
Old 04-12-2012, 02:39 AM   #6 (permalink)
Member # 145927
hi guys i live in uk so am nt familier with all these american trucks but i have a set of these but cannot find bom numbers at all. what will the axles hv come off i need to find out so i can get spares for them thanks in advance
zuk mad is offline   Reply With Quote Quick reply to this message
Old 04-12-2012, 08:08 AM   #7 (permalink)
CSP
Member # 1533
You give absolutely zero information and expect someone to guess what you have?
75 CJ5, 258, T18a, 4.27's, Warn 8274, Howell EFI
CSP is offline   Reply With Quote Quick reply to this message
Old 04-12-2012, 09:08 AM   #8 (permalink)
Member # 145927
the only info i have is the same as the first post here. the numbers i can find are as follow but cannot find any further numbers etc at all on axle
the numbers i have on top of pumpkin are
c38529
44-1f
Old 04-12-2012, 05:05 PM   #9 (permalink)
Corey Young's Avatar
Member # 21622
Pictures please..................they provide clues as to what you have. The yoke, shock mounts, hubs, spring perches, calipers, knuckles, tie rods, etc. can help identify a front axle.
Old 09-25-2012, 07:08 PM   #10 (permalink)
Member # 133069
This is the most useful post of all time
usamedic is offline   Reply With Quote Quick reply to this message
Old 05-25-2014, 04:18 PM   #11 (permalink)
Member # 467705
try this site
http://www2.dana.com/expertforms/deabill.aspx
19dodge86 is offline   Reply With Quote Quick reply to this message
Old 05-26-2014, 12:40 PM   #12 (permalink)
M3C.CA's Avatar
Member # 195381
x2
M3C.CA is offline   Reply With Quote Quick reply to this message
Old 06-03-2014, 12:18 AM   #13 (permalink)
Member # 447402
BOM # is
610036
Found it in the listings as:
1978 K5 Blazer, K10 1/2 Ton Pick-up & Station Wagon on Truck Chassis
610036
DubaiPiratTaxi is offline   Reply With Quote Quick reply to this message
