ORACLE Wrangler JL LED Bulb Conversion Kit - Headlights & Fog Lights Upgrade - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > ORACLE Lighting
Old 10-29-2018, 09:11 AM   #1 (permalink)
Sales@OracleLights.com's Avatar
Member # 856638
Lightbulb ORACLE Wrangler JL LED Bulb Conversion Kit - Headlights & Fog Lights Upgrade
Looking for an complete LED upgrade for your new 2018-2019 JL Wrangler, but don't want to drop $1000 for the headlight package? ORACLE Lighting LED Bulb Conversion Kits are the perfect way to keep money in your pocket, while giving your Wrangler JL a complete visual overhaul.
Get 10% off by using coupon code "forum10" at checkout or CLICK HERE
You can also give us a call at 1(800)407-5776 and mention the coupon code to receive your 10% discount!
FIND BOTH KITS HERE:
Headlights: https://www.oraclelights.com/collect...conversion-kit
Fog Lights: https://www.oraclelights.com/collect...conversion-kit
Witness for yourself how easy it is to install the ORACLE Lights Jeep Wrangler JL LED Headlight Bulbs with our step-by-step video install guide at the top of the post.
The Fog Light install is even easier. Just remove and replace your stock fog lights! Plug N' Play is that simple.
Product Features:
• Minimum Output: 4000+ Lumens
• Maximum Output: 6000 Lumens
• Compliant 6000k Color
• Easy DIY Installation
• No Flickering/Flashing
• Non-Glare-Engineering
• Extended Durability
• Efficient Lighting
• Can-Bus Compatible
• Self Regulated Cooling
• Less Points of Failure
• Instant Start-up Light
• No Relay Harness Needed
• No High-Draw Ignition
• Less Amp/Power Draw
• One Bulb High/Low Beam
• 2 Year Warranty
Need an answer ASAP? - Call Us At 1-800-407-5776 M-F 8am-6pm CST
VISIT OUR VENDOR SECTION -
FIND YOUR VEHICLE BY MAKE:
Sales@OracleLights.com is offline   Reply With Quote Quick reply to this message
