ORACLE 2015-2019 Ford F-150/Raptor LED Side Mirrors + Install - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > ORACLE Lighting
Old 10-29-2018, 09:36 AM   #1 (permalink)
Sales@OracleLights.com's Avatar
Member # 856638
Lightbulb ORACLE 2015-2019 Ford F-150/Raptor LED Side Mirrors + Install
Get 10% off by using coupon code "forum10" at checkout or CLICK HERE
You can also give us a call at 1(800)407-5776 and mention the coupon code to receive your 10% discount!
This innovative new product from ORACLE Lighting features a set of high powered LED light bars integrated into the factory-style side mirrors caps of 2015-2019 Ford F-150 and Raptor Models. This integration allows for easy installation and a clean, almost OEM look while providing functional peripheral illumination for the driver.
Why is peripheral illumination important? Factory headlights and most auxiliary lights only illuminate the area in front of the vehicle. Ideally for off-road activities, such as trail riding, the driver needs to be able to clearly see the area on the sides of the trail to spot obstructions, which would otherwise go unnoticed and could be a potential hazard.
Besides being functional these new LED Mirrors from ORACLE Lighting look great as well! The LED light bar is a custom design that features a total of 24 powerful Cree LEDs. This gives the driver a increased visibility and peripheral illumination. Each unit has a 45 beam angle to optimize the driver's peripheral visibility weather riding on the trail or in the desert. Multiple aluminum heat sinks are used to effectively wick heat away from the LEDs and are designed to use the airflow through the mirror housing to increase cooling similar to a radiator.
The housing material is made from rugged Polycarbonate and bolts onto the vehicle using the factory mounts for easy installation. A set of anodized rock guards protects the LED acrylic lenses, which also houses the DBM Reflex LED optics. These efficient optics focus the light for optimal visibility from the driver seat position.
Product Features:
- 24x 1W Cree LEDs
- 2200lm total output
- 45 Degree LED Beam Angle
- Advanced LED optics
- Uses Factory Mounts
- 6000K Color temp
- 2 Amp Power Draw
- 2 Year Warranty
- Patented Design
*Will not fit Tow-Mirror equipped vehicles.
Package Includes:
- 1 x Driver Side ORACLE 2015-2019 Ford F150/ Raptor LED Off-Road Side Mirror Cap
- 1 x Passenger Side ORACLE 2015-2019 Ford F150/ Raptor LED Off-Road Side Mirror Cap
Need an answer ASAP? - Call Us At 1-800-407-5776 M-F 8am-6pm CST
VISIT OUR VENDOR SECTION -
FIND YOUR VEHICLE BY MAKE:
Sales@OracleLights.com is offline   Reply With Quote Quick reply to this message
