Oracle 7" High Powered LED Headlights - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > ORACLE Lighting
Old 11-05-2018, 02:10 PM   #1 (permalink)
Sales@OracleLights.com's Avatar
Member # 856638
Lightbulb Oracle 7" High Powered LED Headlights
ORACLE 7" HIGH POWERED LED HEADLIGHTS
Get 10% off by using coupon code "forum10" at checkout or CLICK HERE
You can also give us a call at 1(800)407-5776 and mention the coupon code to receive your 10% discount!
The Ultimate LED replacement headlight option for any vehicle with 7” Sealed Beam lamps. The rugged design is perfect for Jeep Wranglers JKs, CJs, TJs, Buggies, and Classic Vehicles!
Installation is very easy with the included H4 and H13 “Plug and Play” connectors. The kit even includes a set of H13 plugs with built-in warning cancelers at no additional charge! Each set comes in full color retail-ready packaging and a 2-Year free Replacement Warranty.
Available with the following single Halo Options
• No Halo
• White (See Pictures in Thread)
• Red (See Pics in Thread)
• Blue (See Pics in Thread)
• Green (See Pics in Thread)
• Amber
Available with the following ColorSHIFT Options (See Pics in Thread)
• ColorSHIFT - No Remote
• ColorSHIFT - 1.0 Remote
• ColorSHIFT - 2.0 Remote
• ColorSHIFT - WiFI Remote
Latest Product Improvement
• Improvements in brightness and reliability by adding a constant current LED driver to the main circuit board inside of the lamp to control the halos.
• Increased Reliability- By conditioning the power going into the LEDs this prevents degradation which can shorten the overall lifespan of the product.
• Wider Input Voltage Range- The new SMD Halos can operate on a very wide voltage range from 12V-24V so that voltage spike can not damage the LEDs.
• Brighter/ More Even Light- by moving the heat load of the resistors off the PCB we are able to increase the number of LEDs on the circuit board without thermal issues.
• LED chips upgraded from a Cree LED to a Phillips Luxeon ZES chip.They deliver a very high efficacy 130LM/W ratio while having lower thermal output.
• Optional black circuit board on the optional halo ring.
Product Features: (Per Light)
• Low Beam Wattage: 30W Normal/36W Max
• Low Beam Lumens: 2200 Lumens/3600 Raw Lumens
• High Beam Wattage: 40W Normal/48W Max
• High Beam Lumens: 3600 Lumens/4800 Raw Lumens
• Color Temperature: 6000K (Cool White Color)
• Input Voltage of Light: 12-24V DC
• Input Voltage of Halo (If Included): 12V DC
• Current Draw: 2.50 Amps @ 12V DC / 1.30 Amps @ 24V DC
• Black Bezel Color
• Optional ORACLE Halo RIngs Pre-Installed
• Premium Performance Phillips Luxeon ZES LEDs
• Die-Cast Housing with Corrosion Resistant Coating
• Heavy Duty Solid State Electronics
• Hard-coated Polycarbonate Lens
• Wide Beam Pattern with Sharp Cut-Off Line
• Easy Plug & Play Installation
• 2 Year Warranty
• D.O.T. and SAE Certified
Package Includes:
- 2 x ORACLE 7" High Powered LED Headlights (Pair) - Black Bezel
With Headlight Bracket Upgrade:
- 2 x ORACLE 7" High Powered LED Headlights (Pair) - Black Bezel with ORACLE Halos Pre-installed inside the Headlights. Plus a pair of Headlight Brackets & Bezels for easy installation.
With ColorSHIFT Upgrade:
- 2 x ORACLE 7" High Powered LED Headlights (Pair) - Black Bezel with ORACLE ColorSHIFT Halos Pre-installed inside the Headlights
- 1 x ORACLE ColorSHIFT Controller Module
- 1 x ORACLE ColorSHIFT Wireless Remote
Check the thread below for customer pics and install advice!
Need an answer ASAP? - Call Us At 1-800-407-5776 M-F 8am-6pm CST
VISIT OUR VENDOR SECTION -
FIND YOUR VEHICLE BY MAKE:
Sales@OracleLights.com is offline   Reply With Quote Quick reply to this message
Old 11-05-2018, 02:17 PM   #2 (permalink)
Member # 856638
Wiring diagram for the 7" High-Powered Headlights
Old 11-05-2018, 02:21 PM   #3 (permalink)
Member # 856638
WHITE
Old 11-05-2018, 02:22 PM   #4 (permalink)
Member # 856638
BLUE
Old 11-05-2018, 02:24 PM   #5 (permalink)
Member # 856638
RED
Old 11-05-2018, 02:25 PM   #6 (permalink)
Member # 856638
GREEN
Old 11-05-2018, 02:35 PM   #7 (permalink)
Member # 856638
ColorSHIFT
Old 11-07-2018, 12:36 PM   #8 (permalink)
Member # 856638
Check them out on the Willy!
Old 02-28-2020, 04:31 AM   #9 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
I need a set of matching 7" and 5.75" for this.
What do you have?
Youre the only person on earth who knows all the details of your life, and thus, you are the most qualified captain of your own ship. Dont worry about justifying your course for pirate's sake. There's always someone here to tell you that you did it wrong.
Grendel is offline   Reply With Quote Quick reply to this message
