ORACLE Illuminated LED Wheel Rings - Install Video & Overview - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > ORACLE Lighting
Old 11-06-2018, 03:24 PM   #1 (permalink)
Sales@OracleLights.com's Avatar
Member # 856638
Lightbulb ORACLE Illuminated LED Wheel Rings - Install Video & Overview
ORACLE Illuminated LED Wheel Rings - PART #4215*
Get 10% off by using coupon code "forum10" at checkout or CLICK HERE
You can also give us a call at 1(800)407-5776 and mention the coupon code to receive your 10% discount!
Introducing our NEW and IMPROVED ORACLE Lighting Illuminated LED Wheel Ring Kit*
These Wheel Rings are an easy and effective way to light up your truck’s wheels and suspension! This head-turning lighting product consists of a set of (4) LED illuminated aluminum rings which install around the brake rotor and attach to the brake dust shield but can also be mounted to older vehicles with drum brakes. The effect is a large ring of light which accents custom wheels and stands out at events.
Available In The Following Colors
• White
• Blue
• Red
• Green
• Amber
• ColorSHIFT (No Remote)
Our ColorSHIFT option requires the use of a ColorSHIFT controller to properly operate.
You can browse our ColorSHIFT Controller Options:
ORACLE Smart WiFi ColorSHIFT Controller
ORACLE ColorSHIFT 2.0 Wireless Controller
ORACLE ColorSHIFT Wireless Controller
Product Features:
• Universal Vehicle Fitment
• LED Ring Diameter: 16.5"
• Mounts to Brake Dust Shield
• Operating Voltage: 12V DC
• Super Bright 2835 LEDs
• Easy Wiring Hub Included
• Waterproof Wiring Connectors
• Over 50' of Install Cable
• All Hardware Included
• 1 Year Warranty
These NEW Rings* Will Include:
• (4) x Aluminum Wheel Rings equipped with Premium ORACLE LEDs
• (1) x ORACLE LED Illuminated Rocker Switch (Except ColorSHIFT)
• (12) x Self-Tapping TEK Screws (3 Per Ring)
• (20) x Interchangeable Aluminum Mounting Brackets
• Installation Instructions
WE WILL ALSO BE OFFERING DOUBLE ROW, FOR TWICE THE OUTPUT - CHECK BACK SOON OR FOLLOW THE THREAD
*These are our NEW rings and should be available this week...if you are planning on purchasing and have any questions about which ones you will be getting, please call 1 800 407 5776
Need an answer ASAP? - Call Us At 1-800-407-5776 M-F 8am-6pm CST
VISIT OUR VENDOR SECTION -
FIND YOUR VEHICLE BY MAKE:
Sales@OracleLights.com is offline   Reply With Quote Quick reply to this message
Old 11-06-2018, 03:31 PM   #2 (permalink)
Member # 856638
WHITE ONES INSTALLED
Old 11-06-2018, 03:42 PM   #3 (permalink)
Member # 856638
Red
Old 11-06-2018, 03:43 PM   #4 (permalink)
Member # 856638
BLUE
Old 11-06-2018, 03:43 PM   #5 (permalink)
Member # 856638
Green
Old 11-06-2018, 03:54 PM   #6 (permalink)
Member # 856638
Old 11-06-2018, 05:16 PM   #7 (permalink)
Member # 178200
SLOWPOKE693 is offline   Reply With Quote Quick reply to this message
Old 11-07-2018, 10:41 AM   #8 (permalink)
Member # 856638
Originally Posted by SLOWPOKE693 View Post
Oh nice, our number #1 fan is back. Send me a PM for a discount code and we will HOOK YOU UP brother.
Will you need help installing the kit? I see you have some BIG tires which will have to come off. You sure you can do this by yourself?
Old 11-07-2018, 10:42 AM   #9 (permalink)
Member # 856638
Old 11-07-2018, 10:47 AM   #10 (permalink)
Member # 856638
And here is with the 5th Wheel Ring lit up as well.
Old 11-07-2018, 01:47 PM   #11 (permalink)
Member # 856638
Dallas Mavericks Jeep from Starwood Motors
Old 11-08-2018, 06:42 AM   #12 (permalink)
Member # 143737
These things really are held on by running self tapping screws into your wheels?
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 11-08-2018, 08:29 AM   #13 (permalink)
Member # 856638
Absolutely, and they are actually attached to the Dust Shields on the brakes.
The Wheels Rings are mounted so that they do not move at all, as you would not want the wires rotating at all. That's why we recommend mounting them at the 12 o'clock position with the wire leading straight to the brake cable.
Old 11-08-2018, 09:09 AM   #14 (permalink)
Member # 143737
I guess that makes more sense.. How do I attach them to my 4 wheel drums though bruh? These fit under 15" wheels right?
Old 11-09-2018, 07:50 AM   #15 (permalink)
Member # 856638
Here is a video detailing a drum brake installation. Our new wheel rings already have the brackets attached, so that part is already done for you. Just make sure none of the wiring or bolts are going to touch any moving parts, as the wheel rings stay stationary when the vehicle is moving.
If your wheel is under 15", you can easily cut the ring and reduce the size based on the wheel size. Just tighten it back up and re-bolt it.
Old 11-09-2018, 07:53 AM   #16 (permalink)
Member # 143737
Try again. That looks like disc brakes to me
Old 11-09-2018, 08:03 AM   #17 (permalink)
Member # 856638
My bad, they are disc brakes , but they don't have dust shields. So this would help explain the process for vehicles like a, i.e. like a drum brake.
Old 11-09-2018, 01:43 PM   #18 (permalink)
Member # 856638
Usain Bolt's Custom Wrangler from The Auto Firm
