Pirate4x4.Com : 4x4 and Off-Road Forum (https://www.pirate4x4.com/forum/index.php)
-   ORACLE Lighting (https://www.pirate4x4.com/forum/forumdisplay.php?f=508)
-   -   ORACLE Single Color Underbody Rock Lights (https://www.pirate4x4.com/forum/showthread.php?t=2671472)
ORACLE_Support 11-16-2018 08:00 AM
The ORACLE 3-Watt Single-Color LED Rock Light Kit consists of two High Intensity LEDs with a stud style screw design.
The unit is resin-injected making it weatherproof. This makes it perfect for rugged applications such as under-cab rock lighting. Easily installs through the inner fender liner by drilling a 3/8 hole.
https://cdn.shopify.com/s/files/1/17...g?v=1542383572
PRODUCT SPECIFICATIONS:
High Output 3 Watt LED - 300Lm
Durable Solid-State C.O.B. Design
Easy 2 Wire 12V Connectivity
Perfect for Off-Road Underbody Lighting
M10 Stud Design for Easy Mounting
Mounting Hole Size: 3/8 Drill Bit
Box Contents : 2x 3W Cree LED Bolts.
One Year Warranty
Box Contents:
*x2 ORACLE 3W LED Bolts
https://www.oraclelights.com/product...ht-kit-2-piece
ORACLE_Support 11-16-2018 08:03 AM
https://cdn.shopify.com/s/files/1/17...g?v=1542384135
redsand723 11-16-2018 08:36 AM
Can more than 1 strand be hooked together?
Sent from my SM-N950U using Tapatalk
ORACLE_Support 11-16-2018 09:27 AM
Yes, you can daisy-chain these. We install up to 6 in a wheel well all wired in-line without a problem.
