9mm AR? - Page 18 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2017, 08:53 PM   #426 (permalink)
Member # 149425
So, what are you guys running for a buffer and buffer spring?
I have a PSA glock lower and it says you can use a regular AR15 buffer and spring, but reading a lot of conflicting reports on the internet.
I have a extra PSA buffer and CMMG spring, but want it to run right and will buy whatever's going to work best (within reason ).
Also, anyone stacking quarters or running a spacer to prevent over travel?
eyehatetofu is offline   Reply With Quote Quick reply to this message
Old 01-05-2017, 09:51 PM   #427 (permalink)
Gozuki's Avatar
Member # 3088
I bought the 9mm buffer with the kak pistol tube and blade. No need for spacers, it's the right weight and length.
Sometimes a two foot level is not handy, but usually there's some ground around.
Gozuki is offline   Reply With Quote Quick reply to this message
Old 01-05-2017, 10:25 PM   #428 (permalink)
Member # 149425
Cool. I too am using the kak tube and shockwave. I saw the kak buffer, and its affordable to boot. Are you using a regular buffer spring?
Old 01-06-2017, 06:33 AM   #429 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
I'm using the NFA spacer and no problems.
Originally Posted by Mustard Dog
Me and my co driver were running across the Lakebed on our way to pre run when we saw :gary: walking his dog.
We didn't stop to say hi cause he's a fucking douchebag.
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 01-06-2017, 01:23 PM   #430 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
H or HB buffer.. a NFa spacer bumper thing and then I limited overtravel with 200 shilling Ugandan coins
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 01-06-2017, 03:36 PM   #431 (permalink)
Gozuki's Avatar
Member # 3088
I got the kit from Schuyler Arms, all matched for 9mm. And it was ridiculously cheap too. I wanna say like $55 shipped with the blade.
Old 01-15-2017, 10:29 AM   #432 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
This seems like a good solution for those having buffer issues.
https://www.kakindustry.com/ar15-con...-buffer-system
Old 01-19-2017, 09:50 AM   #433 (permalink)
Member # 129677
I ended up buying a Slash 9Q-T buffer for my Quarter Circle 10 Glock 9mm. Was not getting consistent bolt hold open on last round like I was with the shorter KAK 9mm non-adjustable buffer. Was pulling my hair out trying to get it figured out by lightening it up and just happened to notice there was only about 1/8" between the bolt and bolt catch when manually locking the bolt back. Ended up having to mill 1/8" off the end of the buffer bumper to give the bolt catch time to lift. This gun will be a dedicated suppressed gun if I ever get my form 4 back...
jeepman1320 is offline   Reply With Quote Quick reply to this message
Old 02-24-2017, 12:12 PM   #434 (permalink)
Member # 4554
Send a message via AIM to bluesman2a
A couple of Builds I've been working on. I started out with the idea of building a side-charging upper and just decided to go with a slick-side.
First up pistol to later be SBR'd
mil-spec lower
rock river magwell block
Kaw Valley Precision 4.5" barrel
Spinta slick-side upper
KVP 5" guard
KVP comp
KVP bolt/buffer
POF 3.5# flat trigger
Blade stabilizer
<blank>
bluesman2a is offline   Reply With Quote Quick reply to this message
Old 02-24-2017, 12:17 PM   #435 (permalink)
Member # 4554
Next up competition carbine:
CMMG dedicated 9mm lower
Taccom3G carbon handgurd
Velocity 3.5# trigger
KVP 16" barrel
JP bolt
JP Silent Capture Spring
Not pictured, but on the bench: C-More 6MOA dot.
<blank>
Old 03-01-2017, 01:02 PM   #436 (permalink)
Member # 98578
Originally Posted by TJGreg5 View Post
Two e-form 1's, both submitted 5/12/16, approved today.
Finally went out and shot mine yesterday. NFA lower, LRBHO/side charger upper, wilson arms 7.5" barrel, pistol buffer. Shot well. Took a bit to get broken in, probably 100 rounds or so before is started to function 100%. Bolt was sticking prior to that point; LRBHO worked great as well. Had to download the 33 rounds to 30/31 rounds to have the bolt pick up a round and slam home. Standard glock mags worked perfectly though.
Semper Fidelis
TJGreg5 is offline   Reply With Quote Quick reply to this message
Old 03-01-2017, 01:10 PM   #437 (permalink)
Member # 109953
i want a 9mm upper for my SBR lower. what mag block should i be getting? i hear some are terrible while others are awesome and cost 3x as much.
AZ Undertakers
ShmUDE is offline   Reply With Quote Quick reply to this message
Old 03-01-2017, 01:59 PM   #438 (permalink)
Member # 70825
How quiet are you guys getting these? My friend and I both have one, and both of us are disappointed on how loud they are while suppressed. The pistols using the same ammo and suppressor are quieter than both of our rifles.
It's not uncomfortable to shoot, but there is enough sound to echo off the trees. Something that doesn't happen with the pistol.
Every time Hillary coughs, a demon gets his horns.
void_of_light is offline   Reply With Quote Quick reply to this message
Old 03-01-2017, 02:28 PM   #439 (permalink)
Member # 121794
What ammo and barrel lengths are you using?
If you pretend to know everyting you will not learn anything.
thedonn007 is offline   Reply With Quote Quick reply to this message
Old 03-01-2017, 03:22 PM   #440 (permalink)
Member # 70825
147gr subs
mine is a 3.5" barrel Not sure what my friends is, roughly the same.
I believe the suppressor we tried was his 45cal octane. Its the only one we had that would work on a pistol and rifle for comparison.
Old 03-01-2017, 04:04 PM   #441 (permalink)
Member # 36317
Send a message via AIM to Numidian
147gr subs
Running a heavy buffer? Maybe you're getting some sound from the chamber itself because it's blowing back too soon?
[CENTER]Brennan
[I]Nemo me impune lacessit [/I][/CENTER]
Numidian is offline   Reply With Quote Quick reply to this message
Old 03-01-2017, 04:32 PM   #442 (permalink)
Member # 118035
The Hahn bottom loading adapter has worked the best for me in a bunch of builds.
IEATRKS84 is offline   Reply With Quote Quick reply to this message
Old 03-01-2017, 10:02 PM   #443 (permalink)
Member # 129677
This... You will need to run the heaviest buffer you can to delay the bolt in order to really quiet it down.
Old 03-02-2017, 05:39 AM   #444 (permalink)
Member # 4554
What weights are you guys running for suppressed? I have a KVP 7 ounce or so that I tried last night on a 4.5" barrel and it was surprisingly loud. I have a HeavyBuffers one that is heavier, I think 8.5... I might give that a try. The only other one I'm seeing is the Heavy Buffers 9QT at 12 ounces.
I also have a JP Silent Capture spring setup, any feedback on that vs heavy buffer setup?
<blank>
Old 03-02-2017, 07:54 AM   #445 (permalink)
Member # 109953
says its for colt and RRA uppers. whats the difference in, say, a CMMG upper?
AZ Undertakers
Old 03-02-2017, 09:08 AM   #446 (permalink)
Member # 118035
Nothing. I run the CMMG bolt with the hahn adapter in Aero Precision uppers and never a problem.
Old 03-02-2017, 09:29 AM   #447 (permalink)
Member # 70825
I read that might be an issue. Sounded like snake oil to me. I guess I can give it a try.
Old 03-02-2017, 11:17 AM   #448 (permalink)
Member # 157357
Well shit! I've lurked long enough to get bit
Now I've got to build one. Mine would be in 9mm/Glock.
On another note, a buddy just got a Mech Tech in .40 and it is very cool!
Run what ya brung for a lower and BAM, you've got a PCC!
Now I may have to rethink an AR-style set up
I still haven't decided what parts-n-pieces based on umpteen pages of 'this is what I did...' for an AR build
Mo Printer is offline   Reply With Quote Quick reply to this message
Old 03-02-2017, 01:46 PM   #449 (permalink)
Member # 4387
I finally built a pistol, NFA glock lower, spinta bolt, kak 8" barrel and slim flash can, shockwave brace, carbine buffer and spring with NFA spacer. Need to test it, put on a angled grip depending on how the wife wants it.
Norm is offline   Reply With Quote Quick reply to this message
Old 03-02-2017, 02:07 PM   #450 (permalink)
Member # 36317
My shockwave brace didn't hold up to the recoil with just the set screw. I actually wound up using a PVC coupler as a spacer between the brace and the receiver so it couldn't slide forward, but to give me a few extra inches of length.
[CENTER]Brennan
