Reloading 458 SOCOM - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-13-2018, 02:36 PM   #1 (permalink)
78bronco460's Avatar
Member # 9152
Reloading 458 SOCOM
Lots of older web-data is out there, much of it inconsistent. Is anybody here loading this cartridge?
Iíve been running a KAK 16Ē barrel and PrimaryArms bcg with sbr ammo and having fun. Now this small pile of brass is needing to be ammo. I have Hornady 350gr fn 4503 and some powders... ?
78bronco460 is offline   Reply With Quote Quick reply to this message
Old 12-13-2018, 06:14 PM   #2 (permalink)
Member # 118035
Just checked my 10th edition Hornady manual and it doesn't have it. But it does have 458 Lott, so go figure.
I haven't looked into the dog laws....except for the one about fucking them.
IEATRKS84 is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 07:27 AM   #3 (permalink)
Member # 189645
I use the Remington 405 JSP a lot. With supers around 1600 FPS and subs. The subs will spin hogs around.
H110/W296 is my ďgotoĒ for supers and I use HS-7 & HS-6 for subs, most often.
jmorrismetal is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 08:09 AM   #4 (permalink)
Member # 9152
You and gozuki convinced me to do this with a kak barrel instead of tromix. Thanks for that. So far, so good. You may be interested in some of this info, I Hope eventually there is helpful data in this thread.
The 405 Remington appears to be discontinued, which is part of the problem Iím finding as itís probably 1/3 of the load ďdataĒ available. Barnes 300gr and 500gr Lehigh seem to be much of the rest. I have plenty of w296, some lilgun and imr4198, so thought Iíd get some stuff put together and see what happens. Casting is a last resort for me.
Old 12-14-2018, 12:06 PM   #5 (permalink)
Member # 189645
These guys have them in stock.
https://www.buffaloarms.com/458-diam...lets-rem457405
Old 12-14-2018, 01:03 PM   #6 (permalink)
Member # 9152
Thanks! I have 500 coming now.
Old 12-15-2018, 03:45 AM   #7 (permalink)
Member # 125208
i built up some loads using lil gun and barnes ttsx heads, starline brass. I still have to run them over the chromo and see what results are. im running a 16" wilson combed barrel/bolt
also have some to test using a 300 gr RN head
redneckboarder is offline   Reply With Quote Quick reply to this message
Old 12-24-2018, 09:59 AM   #8 (permalink)
Member # 9152
I finally got a day without rain to set up the chrony at the range
The 350gr loads I worked up with IMR 4198 turned out okay. Max load averaged 1625 fps and was more accurate than I expected. I used a vortex red dot (3 moa dot) @ 100 yds, and had acceptable groups for my casual effort. The second target looks like I tried to shoot a smiley face, but I was just shooting for center.
Old 01-02-2019, 06:30 PM   #9 (permalink)
Member # 9152
I loaded up some of the Remington 405's over 30-35 grains of IMR 4198 (in 0.5 gr increments) and took them for a spin yesterday. The interesting part is that the velocities seemed to stall at the low 1500's with charges over 33.5gr. I'll work my way down from 35.0 and find the most accurate load, then move on to another powder.
Old 01-05-2019, 10:04 PM   #10 (permalink)
Member # 9152
Today it was Remington 405's over 29.0-31.5 grains of W296. This powder had no problem with velocity, but the 31.5 charges were a little toasty according to the velocities that were predicted with quickload.
I decided to set up a scope to work with on this gun, so I put a Nikon P300 on it and used the lower charges of ammo I was testing to zero the scope at 30yds. The only rounds I had loaded extras for a 100yd target check were the 31.5 and they weren't awesome but grouped within 2". 30.0 and 30.5 were the most consistent, I'll load up some more of those and see how they group.
Charge
Shot#, Velocity
Shot#, Velocity
Shot#, Velocity
Average
SD
ES
29
1 1478
2 1439
3 1476
1464
22
39
29.5
4 1546
5 1494
6 1479
1506
35
67
30
7 1503
8 1494
9 1494
1497
5
9
30.5
10 1504
11 1504
12 1508
1505
2
4
31
13 1510
14 1520
15 1563
1531
28
53
31.5
16 1626
17 1618
18 1585
1610
22
41
31.5
19 1552
20 1635
21 1618
1602
44
83
Old 01-07-2019, 12:12 AM   #11 (permalink)
Gozuki's Avatar
Member # 3088
Speaking of. 458 SOCOM, I have a complete pistol kit I've been meaning to post up. PM for details
Sometimes a two foot level is not handy, but usually there's some ground around.
Gozuki is offline   Reply With Quote Quick reply to this message
Old 01-21-2019, 10:09 PM   #12 (permalink)
Member # 9152
Saturday I ran several calibers of ammo over the Chrony. The only 458S I shot was this load that looked promising a couple weeks ago. It wasn't as consistent with velocities this time, and the targets were interesting. Using a ten round Pmag (3 rounds of 458S), I'd get 2 holes within an inch then a third hole a couple inches out. It or I did this several times. dunno.
458S 405g 30.5 g W296
CCI 350 primer
2.150 COAL
Temperature: 48F
Pressure: 30.3 in Hg
Bullet Weight: 405
Power Factor Average: 630
Power Factor Low: 606
Power Factor High: 659
Number of Shots: 22
Minimum: 1498
Maximum: 1629
Spread: 131
Average: 1557
Standard Deviation: 43
# Velocity Ft/lbs Power Factor Date
22 1629 2386.2 659 1/19/19, 1:33 PM
21 1629 2386.2 659 1/19/19, 1:33 PM
20 1527 2096.7 618 1/19/19, 1:32 PM
19 1622 2365.7 656 1/19/19, 1:31 PM
18 1579 2241.9 639 1/19/19, 1:31 PM
17 1527 2096.7 618 1/19/19, 1:31 PM
16 1543 2140.9 624 1/19/19, 1:29 PM
15 1511 2053.0 611 1/19/19, 1:29 PM
14 1555 2174.3 629 1/19/19, 1:28 PM
13 1566 2205.2 634 1/19/19, 1:28 PM
12 1498 2017.8 606 1/19/19, 1:28 PM
11 1523 2085.7 616 1/19/19, 1:13 PM
10 1504 2034.0 609 1/19/19, 1:12 PM
9 1503 2031.3 608 1/19/19, 1:12 PM
8 1561 2191.1 632 1/19/19, 1:08 PM
7 1604 2313.5 649 1/19/19, 1:08 PM
6 1532 2110.5 620 1/19/19, 1:08 PM
5 1602 2307.7 648 1/19/19, 1:06 PM
4 1557 2179.9 630 1/19/19, 1:06 PM
3 1518 2072.1 614 1/19/19, 1:06 PM
2 1550 2160.4 627 1/19/19, 1:02 PM
1 1620 2359.9 656 1/19/19, 1:02 PM
Old 01-22-2019, 10:05 AM   #13 (permalink)
TNToy's Avatar
Member # 5776
131 fps is aot of velocity varation - or at least it is for pistol. I donít load rifle, so that might be acceptable.
However I do know that your earlier chrono data with only 3 shots fired? The SD and ES figures are largely irrelevant. You canít get an accurate picture of any kind of average until you have 10-20 rounds downrange. I get why you were doing it, I do the same when working up a ladder. But I usually discard the SD/ES figures right then and there.
Old 01-22-2019, 11:18 AM   #14 (permalink)
Member # 9152
This is basically a magnum pistol load, and 131 ES is ridiculous. Iím suspicious of the bullet being forced in/out of coal length by recoil causing the third round thing and some of the ES variation. There are 14 more of this load left and I think Iíll check the BTO, COAL, give 10 of them a light crimp, then go to the range and try it again. After the first two Iíll pull the third uncrimped cartridge and check the COAL before firing it. Iíll make a couple other loads to try also and focus on this gun a little more than the others.
The SD/ES from the 3 shot groups have usually been good indicators of loads to go further with, but not in this case.
