T/C Contender smoothbore .410 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2019, 04:23 PM   #1 (permalink)
6gun's Avatar
Member # 95448
I was discussing with a friend today about options for a smoothbore .410 barrel for my Contender carbine and we arrived at the conclusion that making one would be easier than finding one(I've looked). Discussing options I thought I'd throw out there since you bunch of heathens are always figuring out how to do what shouldn't be done.
#1) Buy a 21" factory rifle barrel and ream it out to .410. But how do you ream 21"????
#2) Buy a used .410 single shot barrel and weld a T/C lug to it.
#3) Bite the bullet and hunt patiently for a factory smooth bore to come available and come up with the $5-600 they go for(OUCH)
Any ideals from the expert machinists here how to ream a barrel the whole way through fairly accurately? Anyone here have capability to do something like that?
'99 Ford Ranger 4.0/5R55E/BW1354E/5.13 gears/'06 D60 F/99 Sterling R/ 39X12.50 Kanati
6gun is online now   Reply With Quote Quick reply to this message
Old 11-11-2019, 06:29 PM   #2 (permalink)
Member # 59610
buy a 45 long colt, and shoot .410 slugs
Originally Posted by 45acp View Post
Titty bar with moms? Sure why not. Right after I masturbate in church.
jeeptj19992001 is offline   Reply With Quote Quick reply to this message
Old 11-11-2019, 06:33 PM   #3 (permalink)
Member # 59610
Thompson Center Shotgun | Thompson Center 12 Gauge Shotgun
https://matchgrademachine.com/thompson-center-shotgun/
455.00
Old 11-11-2019, 07:45 PM   #4 (permalink)
kf4zht's Avatar
Member # 80248
#4) Buy a 410 AR upper and have 15 rounds of 410, forget that single shot nonesense.
Honestly I would do #2. Even if you found a pump gun barrel you could always use it for a sleeve in an adapter to get to TC dimensions.
Where there is a way, there's a will.
kf4zht is offline   Reply With Quote Quick reply to this message
Old 11-11-2019, 08:23 PM   #5 (permalink)
Member # 192237
expert? hah
I'd use a simple piloted d-bit reamer to finish it a couple thousandths under, then press a carbide ball bearing through it to burnish it smooth, it'll plastic foul like crazy if you just leave it as-reamed
ETA: much easier to weld a tc lug onto an existing 410 barrel (or possibly a piece of properly sized DOM. Barrels are soft steel)
Old 11-12-2019, 04:49 AM   #6 (permalink)
6gun's Avatar
Member # 95448
That would work fine for larger stuff but have you ever saw what a .410 slug does to a squirrel? Ain't much left to eat!
Old 11-12-2019, 04:51 AM   #7 (permalink)
6gun's Avatar
Member # 95448
I'm on the list for one of the next shipments of .410 AR uppers. Single shot is just plain fun!
Old 11-12-2019, 04:54 AM   #8 (permalink)
6gun's Avatar
Member # 95448
Originally Posted by [486] View Post
expert? hah
My friend who is a much more accomplished machinist than I (and owns the lathe) was worried about the length of the reamer/extensions etc causing too much wobble. He mentioned a pull thru reamer but was clueless where one that length could be found. The barrel will be polished thoroughly to avoid plastic fouling! It looks like building a barrel is in the lead for easiest to do! Plus I already have a spare barrel that could contribute to the cause!
Old 11-12-2019, 09:10 AM   #9 (permalink)
Member # 36733
Watch your head spacing if you DIY...also better use chrome moly as using softer steel can lead to pressure issues if the wall is too thin at the breech.
[I]Vegetarian is an old Native American word for bad hunter[/I]
DavidVanVorous is offline   Reply With Quote Quick reply to this message
Old 11-12-2019, 09:41 AM   #10 (permalink)
Member # 57170
Ugh..brain failing me, but I'd reach out to a co that specializes in shotgun barrels and ask them.
I cant recall the name. I sent a barrel off to be shortened, re-threaded, and the forcing cone opened up on a barrel and the cost was very reasonable.
They would probably have some good ideas at least.
Retired as fawk :smokin:
14 JKU "The Toad" work in progress
SEREvince is offline   Reply With Quote Quick reply to this message
Old 11-12-2019, 09:51 AM   #11 (permalink)
Member # 123554
Itís been a few years since I sold my TC stuff, but there used to be a couple of TC groups on Facebook where people sold barrels at reasonable prices. House of arms also ran specials from time to time. Personally, I had decent luck on eBay.
Aggie06 is offline   Reply With Quote Quick reply to this message
Old 11-12-2019, 05:54 PM   #12 (permalink)
Member # 192237
no
wrong
Old 11-12-2019, 06:39 PM   #13 (permalink)
6gun's Avatar
Member # 95448
While I will use proper steel for it, considering the amount of fully functional poop-pipe 12G I've seen I'm not extremely concerned.
Sent from my LG-H700 using Tapatalk
Old 11-13-2019, 08:58 AM   #14 (permalink)
Member # 183804
Send your rifle barrel to JES reboring and have him do it for 200ish bucks.
Stories from in between my ears.
micky_blue is offline   Reply With Quote Quick reply to this message
Old 11-13-2019, 09:24 AM   #15 (permalink)
Member # 67823
Dlask might be able to do it. Dunno how the border cross9ng part would go though.
Big diesel Ford, a stable of white toyotas from '84-08, and a bw200. They all need work.
squamch is offline   Reply With Quote Quick reply to this message
Old 11-13-2019, 11:08 AM   #16 (permalink)
Member # 36733
no
wrong
Son I build both ML and shoot wildcat TC stuff and have since the contender 1st came out. A .410 like other shotty cases are all headspaced at the breech.
In fact all TC barrels using rimmed cases are headspaced at the breech. The only shoulder reference head spaced spaced barrels are rimless cases hence a need for the cartridges to be fire formed for decent accuracy. Talk to the folks at TC about it...
Old 11-13-2019, 11:19 AM   #17 (permalink)
Member # 36733
Meh, the ability to handle the breech pressure is not only a function of the material but also the wall thickness...basic material science and Mech Engineering. Pipe like you are talking about will have about .12" wall and "adequate" for a short barrel zip gun.
Given the width of a TC breech the wall thickness on a .45/.410 is thinner hence why TC makes most of their barrels of chrome moly so as to avoid the warranty hassles.
Old 11-13-2019, 12:00 PM   #18 (permalink)
Member # 143737
Few years ago I could have probably gotten what you wanted here in town, but they had to fuck with the T/C plant here.
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 11-13-2019, 02:34 PM   #19 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
https://www.brownells.com/gunsmith-t...mers/index.htm
pull through reamers available at brownells
pull through would take chatter and shit out of the equation and be the better option as opposed to a boring bar
Provience is online now   Reply With Quote Quick reply to this message
Old 11-13-2019, 06:38 PM   #20 (permalink)
Member # 192237
I wasn't talking about the headspace bit, though now that you mention it headspace doesn't fucking matter it's a .410 shotgun shell, you could have 1/4" of it exposed and it'd be fine
I was taking about your comment on needing hardenable steel. Many barrel makers will even use leaded free-machining steel
Old 11-14-2019, 10:32 AM   #21 (permalink)
Member # 36733
I can think of at least 6 books and authors of same that say the 1st remark is BS and an unsafe situation. 1 book (Hatchers Notebook pg 240) also has a real nice pic of a shotty high wall case thats all nicely expanded at the base due to bad head spacing (.1" btw). A few other pics describe the effects of lousy head space for rimless with increasing changes including mid case seperation and barrel deflagration in the case of shotguns.
For ref on the significance of Head spacing and the ramifications of screwing it up in a build:
Modern Gunsmithing - Clyde Baker ref; chpt 16 pgs 243-245
Professional Gunsmithing- Walter J. Howe ref; chpt 5 pgs 84-86
Hatchers Notebook - J.S. Hatcher US Army ret. ref; chpt 10 pgs 231-252
Ordinance went up front - R.F. Dunlap ref; chpt 44 pgs 370-374
Gunsmithing - R.F. Dunlap ref; chpt 14 pgs 208-212
Shotguns - Elmer Keith ref; chpt 6 pg 113
As to leaded steel, like I said previously steel grade and wall thickness come into play when building a barrel. One can make a firearm of plastic on a 3d printer but how long it stays in one piece is debatable, but theres folks with uTube DIY videos out there...
Back in the early 70s I even made a tennis ball cannon out of nothing more than 2 steel bud cans and electrical tape to hold it together that shot tennis balls using about 100 gr of 2f Goex.
Was it functional? yep
Did it fall apart at the tape seam every shot? yep
Point is that one can build out of most anything, the Q always comes down to one of whether or not its durable and lasts or just a toy...
Old 11-14-2019, 05:50 PM   #22 (permalink)
Member # 192237
note how a .410 hull still uses a #209 primer
the case head in a .410 is solid plastic for a good 1/4" because of this
where with cheap 12ga hulls they have a ring hollowed out in the case head down below the level of the primer's flash hole, sort of like the pictures you see of old 'balloon head' style metallic cases
Old 11-18-2019, 11:02 AM   #23 (permalink)
Member # 36733
Meh, 209 primer is nothing more than a means to carry a SR primer in a larger hole, not a significant part of the structural integrity of the case. Same part used by other gage shotty cartridges and in some ML inline designs.
As to the plastic, again larger gages are made the same and have been since the cartridge makers went plastic. Only exception are the old school paper cases one runs into occasionally...if at all nowadays.
Doesnt alter the fact that what you are proposing is at best Booty fab and dangerous.
Ive run into a similar attitude when I took Hunter Safety class eons ago in the early 60s during the practical. Kid was shooting an older .410 H&R top break for the shotty part of the test with his dad feeding the piece. Turned out his dad gave him a 3" mag which the piece took exception to...as did the instructor of the course when he found out.
Kid shot, the case mushrooms inboard towards the muzzle and prevented extraction. Dad starts to the car to get a rod to bounce the case out. Apparently he was used to the problem cuz he had a rod and a ball pein when he started back.
Instructor caught wind of what was wrong, words between instructor and parental unit started getting louder and........the kid and the dad were bounced off the range with the instructor shouting the kid flunked cuz the dad was an idiot...
Old 11-18-2019, 06:38 PM   #24 (permalink)
Member # 192237
larger diameter case means they have room to increase case volume by removing plastic between the case wall and primer
primer being a large portion of the diameter of the case means no room to cut out material there, thus the case head being basically solid
