Rubicon in June? Too Soon? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Rubicon Trail
Old 03-10-2016, 10:55 PM   #1 (permalink)
Member # 657674
Planning my first trip over the Con June 18th weekend. Any concerns from those of you more familiar with the area? Snow Level? High Water Levels?
It's the weekend before Rubithon so I'm assuming it should be fine just thought I'd ask.
jasnusc is offline   Reply With Quote Quick reply to this message
Old 03-11-2016, 06:03 PM   #2 (permalink)
Member # 21815
Given the amount of snow we seem to be getting this year, that may be a problem, especially on the Tahoe side. At this point in time there is no real way to know.
You should plan to either
a) be flexible with your date and make a final decision as June grows nearer (should be fairly easy to know by mid/late May or maybe earlier) or
b) choose a different date later in the year.
WWDD?
N6YBH
Thanks to
for sponsoring the 2017 Cantina For The Con!
"If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford
resqme is offline   Reply With Quote Quick reply to this message
Old 03-11-2016, 07:17 PM   #3 (permalink)
Member # 657674
That's what I'm afraid of. Thought maybe the Rubithon guys knew something I don't since they planned their trip mid-June.
Old 03-11-2016, 07:31 PM   #4 (permalink)
Member # 21815
They always do, and usually it works out fine. In 2011 they ended up delaying it, too much snow. By mid May they had decided to move the trip to mid-July.
WWDD?
N6YBH
Thanks to
Old 03-12-2016, 11:12 AM   #5 (permalink)
222doc's Avatar
Member # 480906
You can use this web page to watch the snow pack. in the pulldown menu there is a ton of options, total snow, when its melting etc.. just be sure to press redraw when changing. You can zoom into a area too.
We have a group out of AZ that will be there in the last week of june, 27th. This year it will depend on how and when it warms. early June looks real IFFY.
Parker 4 Wheelers
Bullhead 4 wheelers
222doc is offline   Reply With Quote Quick reply to this message
Old 03-12-2016, 01:14 PM   #6 (permalink)
Team 261 - VP
atvobsession's Avatar
Member # 31923
To add what John said....
As you get closer...about a month out...you should have a good idea. The worst part of the trail is the Tahoe Side....so sometimes you can easily wheel from Loon to Buck or the Springs....but getting out the Tahoe side is problematic....so you can adjust your route accordingly and still wheel the Con.
Regards,
Ken Hower - KOH #1962 Close Enough Racing/KOH #4899 Legends
Rubicon Trail Foundation - Director 2011-Present
Thanks to
for being the primary sponsor for the 2016 Cantina For The Con!
atvobsession is offline   Reply With Quote Quick reply to this message
Old 03-13-2016, 11:09 PM   #7 (permalink)
Bad Coco's Avatar
Member # 32918
Howdy, this is Eric, Chariman of Rubithon. Normally it isn't a problem, but as John stated, there is always a chance for the exception.
I have friends that go do a club snow run from the Tahoma side over Memorial and then let me know the conditions. The main problem usually reveals itself on Cadillac Hill and some of the drifts up there.
You can email me chairman (at) rubithon (dot) com and I'll be more than happy to pass along their scouting report. But again, there can be snow storms in May and early June that could make things interesting.
Eric
Eric Agee KJ6IZI
Retired Rubithon Chairman / Past FOTR Trail Boss
TLCA# 13531
My poo-flinger build up :
Bad Coco is offline   Reply With Quote Quick reply to this message
Old 03-14-2016, 02:31 AM   #8 (permalink)
cruzila's Avatar
Member # 6650
2011 There was a fresh 2-3 feet on the 15th of the month of MAY!!!!. You just never know until you arrive on the calendar at about that time.
Picture is the trailer when we got to Loon Lake.
edit: added month
Scott Johnston
Founding Director
Past President 2010-2012
Retired Director 2004-2013
ReElected RTF Director Dec 2017
cruzila is offline   Reply With Quote Quick reply to this message
Old 03-14-2016, 10:24 PM   #9 (permalink)
Member # 657674
Eric
Thank you! I'll keep an eye on the weather and check with you after May.
Old 03-17-2016, 08:54 PM   #10 (permalink)
Member # 207585
2011 was an exceptionally wet, cold and long winter. This year is anything but. The Tahoe Basin has had a healthy year, but is below average, receiving around 120" of snow at lake level, 2011 was around 250" at this point. But the main difference has been the temperature, with several warm periods of melting in the past 6 weeks. Also many of the storms we have had have been rain to 8000' for the bulk of the storm, so while there is plenty of water, there can't be the kind of snow we saw in '11. My prediction is there will Jeeps going through to Tahoe by Memorial Day and father's day will be fine.
'53 CJ3B
KJ6NRH-Lake Tahoe Hi-Lo's-NRA-MVCC
timsresort is offline   Reply With Quote Quick reply to this message
Old 03-18-2016, 02:22 PM   #11 (permalink)
rochead's Avatar
Member # 225516
I,m liking what your saying
rochead is offline   Reply With Quote Quick reply to this message
Old 03-18-2016, 10:31 PM   #12 (permalink)
Member # 100029
In 2011, the trail didn't get cut through on the Table side till July 4th weekend and still had snow at Sluice. This year should be good by the end of next month if this weather holds up.
gart is offline   Reply With Quote Quick reply to this message
Old 03-19-2016, 09:00 PM   #13 (permalink)
Member # 24195
AHHHHHH what's that???? The best time of the year IS spring snow wheeling!!!!
Cheers!
Crawl ratio 447:1. 14b frt and rear, 40 spline ARBs. F 3 link, R 4 link, 49" IROKs, double bead
toyrocs is offline   Reply With Quote Quick reply to this message
