Costco LED shop lights - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-19-2015, 06:22 PM   #1 (permalink)
Member # 121053
I'm pleasantly surprised with my new LED shop lights. Originally I just bought two to see how well they worked then went back for more to completely redo the garage. Costco had them on sale for $31.xx down from $39.xx regularly. Plus we get 2% back with out Premium Membership. Equivalents priced at Home Depot were around $75 each. AND the Costco here just announced they now have diesel at the pumps!
We will see how they hold up over time.
Edit: In the picture I just had them plugged into power strips to see how well they lit and to make sure I had good spacing and all.
Hunt is offline   Reply With Quote Quick reply to this message
Old 04-19-2015, 06:42 PM   #2 (permalink)
Member # 9222
Wow, looks pretty good. I just threw out all of my T8 fixtures and have a couple of T5HO's to go over the work bench. Maybe I'll do some of these LED's for the rest of the space.
larryboy is offline   Reply With Quote Quick reply to this message
Old 04-19-2015, 07:19 PM   #3 (permalink)
D45
Member # 102974
How long are the fixtures?
Watts and lumen?
'16 Chevy Silverado LTZ Z71 / 5.3L V8 / 8 Speed 8L90 / AFM Disabler / Ported TB / Ported Manifold
D45 is offline   Reply With Quote Quick reply to this message
Old 04-19-2015, 07:26 PM   #4 (permalink)
Member # 121053
Watts and lumen?
48" Fixture length
38 Watts
3700 Lumens
50,000 Hour life
4000K Cool white color temperature
Old 04-19-2015, 08:23 PM   #5 (permalink)
D45
Member # 102974
Does it have any ceiling height requirements or suggestions?
Flush mount?
Can these be hard wired?
I'm getting interested
Old 04-19-2015, 08:53 PM   #6 (permalink)
unimogken's Avatar
Member # 11745
I have been considering replacing the crappy 4 footers in the kitchen because i'm tired of replacing bulbs or ballasts.
At that price i'll pick some up!
Later, Ken
1 Mercedes Benz Unimog 404s
unimogken is offline   Reply With Quote Quick reply to this message
Old 04-19-2015, 09:38 PM   #7 (permalink)
Member # 121053
Flush mount?
Here is a link to the 2 pack of the exact same lights I bought. I can not find the singles at the sale price online. This will at least give you the details.
http://www.costco.com/Feit-Electric-...100155638.html
They come with screws for flush mount or a 6" drop cable. I mounted mine on the cable. They come with a standard 2 prong plug with about 4' of cable. No ground. If you want to hard wire them then just lop the end off. Stripe and wire as needed.
Amazon has the same light for $52.97.
Link with more details:
Feit Electric LED Utility Shop Light - - Amazon.com
The majority of the reviews are very good.
Old 04-19-2015, 09:44 PM   #8 (permalink)
Member # 121053
Google-Fo coupon
Feit Electric 4' LED 2 lamp shop light $31.99 @ Costco B&M YMMV
Old 04-20-2015, 04:40 AM   #9 (permalink)
D45
Member # 102974
Don't dual bulb T8 fixtures throw more lumens than these LED fixtures?
Other than operating cost savings....... Are these that much better?
Old 04-20-2015, 09:44 AM   #10 (permalink)
Member # 130300
Dual T8s are 4900 lumen, 64 watts.
Dual T8 76.5 lumen per watt
This LED fixture 97.3 lumen per watt
Mikes79bronco is offline   Reply With Quote Quick reply to this message
Old 04-20-2015, 11:26 AM   #11 (permalink)
D45
Member # 102974
How many fixtures did you buy?
how big is your shop?
Old 04-20-2015, 12:54 PM   #12 (permalink)
civicmindedex79's Avatar
Member # 116609
Just a heads up. We don't have alot of costcos around here but Sam's club had these same lights for the same price a couple weeks back. Might check there also if more convenient for you.
http://www.samsclub.com/sams/4ft-led....ip?navAction=
civicmindedex79 is offline   Reply With Quote Quick reply to this message
Old 04-20-2015, 02:44 PM   #13 (permalink)
D45
Member # 102974
4-foot LED Shoplight - Sam's Club
40 watts
4,200 lumens
5000k color temp
105 lumens per watt
60 LED's per row (2 rows that simulate a tube)
Clear tube protector over each row.
50,000 hours rated
5' cord w ground
4.25 pounds
46.5" long, 6" wide, 2.75 deep
$36.87 each locally
Old 04-20-2015, 02:51 PM   #14 (permalink)
perfection in plasma
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
so far these seem to be good lights. i put 5 of them up in the shop. if they hold up well for the next 2-3 months ill do another 5-10 lights (shops 20'x60') . had to go to 3 places before i found some in stock so i guess others are enjoying them.
carslut is offline   Reply With Quote Quick reply to this message
Old 04-20-2015, 04:11 PM   #15 (permalink)
Member # 121053
I put up 8 in a standard two car garage. Two circuits so I can have the garage door open and shut off the ones about the door but still light the area deeper inside.
Old 04-21-2015, 06:31 AM   #16 (permalink)
45acp's Avatar
Member # 13671
I just ordered 4 of these, and if they work half way decent im ordering 4 more.
Current shop has 4 of the 8' t12's in the main work area. Going to replace each one with a pair of the LEDs and do a comparison. I'll throw up some pics once the UPS man gets here.
45acp is offline   Reply With Quote Quick reply to this message
Old 04-21-2015, 08:32 AM   #17 (permalink)
D45
Member # 102974
8, four foot long lights in a 20x24??????
Seems like A LOT.......How do I determine how many fixtures to get?
My shop currently has old, T12 fixtures.....they hum take forever to turn on in the cold, and I have 4 burned out bulbs
I have the following lights in my shop:
(7) of the 4' long, 2 bulbs fixtures
(6) of the 4' long, 1 bulbs fixtures
My shop is around 16'-18' wide and 62ish feet long
Old 04-21-2015, 10:28 AM   #18 (permalink)
Member # 343737
sounds about right for a work area, it all depends on what your using the shop space for
when you only have a 2 car garage to work in... every square inch is workshop
my 50x50 barn is broken up into workshop, fab bay, storage, garage and upstairs
i have 9 four foot 2 bulb t8s in the 20x30 workshop portion of my barn; in 3 switched zones
6 four foot t8s in the 12x30 fab bay and only 2 four foot t8s in the 20x50 garage area
that leaves 18x30 storage area that has 3 60 watt light bulbs and the 30x50 upstairs that has 3 flood lights
_ogre is offline   Reply With Quote Quick reply to this message
Old 04-21-2015, 10:47 AM   #19 (permalink)
Member # 5943
Location: Southeastern MN. (formerly near Chicago, I've ESCAPED!)
<shrug> I've got 8 4' fixtures (T8s at the moment, seriously considering switching to all LEDs,) in half of a 20'x20'. Almost enough light. When we bought the place, there were 2, count them, 2, 100w incandescents in the whole mancave.
ChiXJeff is offline   Reply With Quote Quick reply to this message
Old 04-21-2015, 11:07 AM   #20 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
Surface mount approved
Quiet - silent operation
Instant on and coloration
Brighter than T8's
I fucking love them. I have 12 fixtures in my garage of which 7 are now these LEDS. I have 5 more "in stock" waiting till the T8's that are left die.
These things are great.
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 04-21-2015, 11:34 AM   #21 (permalink)
D45
Member # 102974
Brighter than T8's
Thanks for the info...........I am only concerned that a bank of LEDs will go bad and render the fixture useless, unless its warrantied
With a T8 fixture that I am considering, just would need to replace the bulbs
Old 04-21-2015, 10:42 PM   #22 (permalink)
Member # 11871
Just something to consider...
Costco corporate does NOT allow handgun carry by permit holders; NOR does it supply armed guards to protect its customers from criminals who ignore corporate policy.
I'll buy from Sam's.
http://supermotors.net/registry/2742#album
steve83 is offline   Reply With Quote Quick reply to this message
Old 04-21-2015, 10:52 PM   #23 (permalink)
Member # 11615
Dude...really? It's a fucking LED light for the garage/shop/weed-room/rape-shack/etc.
Nobody gives a fuck where you buy your made in CHINA light from.
Old 04-28-2015, 08:09 PM   #24 (permalink)
Member # 50177
I drank the koolaid. I actually bought one fixture a couple of months ago but never put it up because the lumen output was so much lower than the t8's. After reading this thread I gave it a chance and put it up yesterday. I had five 4' t12 fixtures and adding that one light seemed like it doubled the amount of light. It was a little dark before I put the light up yesterday and I am almost afraid that it will be too much with 6 of these things.
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
am4x4 is offline   Reply With Quote Quick reply to this message
Old 04-28-2015, 09:15 PM   #25 (permalink)
Tubing Junky
Member # 225995
I had some old 8ft T8s dieing in my back room so I got some of these
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
SO far so good, big difference. Just required a ballast by-pass.
It gives you serious flashes if you look at them.
Trying to CNC everything on a beer budget...
JGSturbo is offline   Reply With Quote Quick reply to this message
