Sheet Metal Storage solutions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-08-2017, 07:13 AM   #1 (permalink)
Member # 351914
I know another storage question.
How do you guys store your sheet metal and bigger 4x8 sheets of stuff?
jdereu is offline   Reply With Quote Quick reply to this message
Old 08-08-2017, 08:16 AM   #2 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
I built a cart to hold our sheet steel... Currently it has 10+ sheets of 1/8th and 4 or 5 sheets of 3/16" on it. It's a bit heavy to move around but it still rolls nicely once you get it started moving.
Version #1
Version #2. Added a long handle that stuck out past the end of the sheet metal and upgraded the casters to better ones.
And the handiest thing of all this sheet metal lifting clamp... You can clamp it along the top edge in the middle and handle sheets of steel with a cherry picker. Really saves your back!
The one, the only, the Dane.
billybob_81067 is online now   Reply With Quote Quick reply to this message
Old 08-08-2017, 10:01 AM   #3 (permalink)
Member # 82954
depends on what you use to move the sheet metal.
with forklift;
for full sheets, i've got eight foot pallets for every guage and type sheet i have on hand. stacked all together its about 6ft tall. i remove the the pallets above needed size and pull a sheet off.
then for rems they get placed on end in another storage rack.
tracyb is online now   Reply With Quote Quick reply to this message
Old 08-08-2017, 10:11 AM   #4 (permalink)
Atomic Test Lab Rat
Member # 25325
How about ideas for those of us who don't have fancy garages, and just work out of smaller 2 bay house garages. Right now I have a few 4x8' sheets just leaning up against the back wall. The clamp up above to move with a picker is great, definitely going to get one. I'm still looking for a better storage means though.
IDI F250 Crawler
redranger4.0 is offline   Reply With Quote Quick reply to this message
Old 08-08-2017, 10:23 AM   #5 (permalink)
Member # 723161
Beware of using clamps to hold sheet metal not the best thing but it works in a pinch
Sent from my E6810 using Tapatalk
A7X2889 is offline   Reply With Quote Quick reply to this message
Old 08-08-2017, 10:28 AM   #6 (permalink)
Atomic Test Lab Rat
Member # 25325
I'm looking at specific sheet metal lifting clamps. Your saying they don't work?
IDI F250 Crawler
Old 08-08-2017, 10:31 AM   #7 (permalink)
Member # 723161
No they work just don't trust them like I do dogs or whatever u wanna call them.
Old 08-08-2017, 10:40 AM   #8 (permalink)
Atomic Test Lab Rat
Member # 25325
I was looking at this style. Plus lifting with a engine hoist I would never be under the sheet. more just to move around sheets of 1/8 or 1/4" plate around, as it stands right now its an absolute pain in the ass to work with them.
Hoists & Cranes | Lifting-Attachments | Vertical Plate Clamp Lifting Attachment 1600 Lb. Capacity | 988006 - GlobalIndustrial.com
IDI F250 Crawler
Old 08-08-2017, 07:11 PM   #9 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
Attachment 2668617
Did you build that thing, including a homebrew shackle?
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 08-08-2017, 09:19 PM   #10 (permalink)
Rednek
Member # 52387
No I ended up with a couple of them from a machine shop auction. They were torch cut and ugly so I cleaned them up with a bandsaw and grinder and added the shackle which I just happened to have. Also added the t-handle to the square headed set screw so that you can tighten it up by hand.
They are basically just 1" thick steel cut into an A shape with a hole tapped through for the set screw...
So yes it is "home built" but not 100% by me.
Old 08-12-2017, 12:25 AM   #11 (permalink)
Member # 178637
I used those quite a bit at work years ago to drag around I-beams with a little toy forklift. Never had one let go, and they were all cheap crap.
freestyledude is offline   Reply With Quote Quick reply to this message
