Rotary Phase Converter- Potential relay - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2018, 05:22 PM   #1 (permalink)
Member # 67907
I am building a 15hp phase converter. I used a 5hp potential relay thinking it would be fine for getting an unloaded idler motor up and running, but
I cant seem to find a larger potential relay. Wondering if I can hook 2 in parallel to handle the load, or if this would cause other issues.
The Beepster
Jeepermat is offline   Reply With Quote Quick reply to this message
Old 08-13-2018, 05:51 AM   #2 (permalink)
Member # 111998
I don’t see any reason why it wouldn’t work.
Tyler76010 is offline   Reply With Quote Quick reply to this message
Old 08-13-2018, 10:25 AM   #3 (permalink)
Member # 192237
just wire it up with another contactor with all the contacts bridged on the start button so it brings the start cap out when you let go of the button.
my start button has only one set of contacts, so I had it switch the start cap contactor directly, three of four contacts bridged, then the fourth contact wired where the start button used to be.
Push in, let go half a second later, can't be simpler.
Old 08-14-2018, 05:47 PM   #4 (permalink)
Member # 67907
Id prefer to have the potential relay vs a start button. We lose power here pretty frequently, I would rather have an auto start system vs a manual start.
The Beepster
Old 08-15-2018, 03:07 PM   #5 (permalink)
Grumpy356's Avatar
Member # 151139
No relay is going to handle the start load of a 15HP motor (loaded or not). If you want a relay it will need to be an interposing relay to make and break the holding coil of the contractor.
Mass quantities of anxiety, internal conflict and discontent, all balled up in one short, tattooed body.
Grumpy356 is offline   Reply With Quote Quick reply to this message
Old 08-17-2018, 05:23 PM   #6 (permalink)
Member # 192237
I don't leave mine run, I haven't checked for certain yet but I'm sure the power factor is so horrible as to be laughable, even at idle.
Even if you have something like a compressor, with a couple delay relays you can set it up so the converter kicks on with the pressure switch, then a few seconds later the compressor contactor starts up the motor, then it all shuts down when the pressure switch reaches it's set pressure.
