Propane convenction heater in closed garage? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-13-2018, 04:46 PM   #1 (permalink)
Member # 798313
I bought one of those $100 Remington portable convection heaters from Lowes. Heats the garage up pretty good but they warn it gives off CO and to have open windows. However I used it with the windows closed with a CO detector in the garage and it never went off. So is this warning to just cover their ass, or can propane heaters actually emit enough CO to kill people?
Cyrax is offline   Reply With Quote Quick reply to this message
Old 11-13-2018, 06:44 PM   #2 (permalink)
T-A-I's Avatar
Member # 183106
I've been doing propane heaters like that off and on for years in the garage with no problems. I know it helps that it isn't the most air tight structure and it has overkill for attic vents. No way would I try the same heat source in the house which will close up tight like a thermos bottle.
If your CO detector is happy, I wouldn't be worried about it. I'm basing this on the CO detectors in my big ass camper. Those things sometimes are annoying. Entry door open, jeep or whatever running outside has tripped them before. Not to mention having a smoky grill outside the door doing the same.
"Them that don't know him won't like him and them that do, Sometimes won't know how to take him.
He ain't wrong, he's just different but his pride won't let him, Do things to make you think he's right."
T-A-I is offline   Reply With Quote Quick reply to this message
Old 11-13-2018, 07:44 PM   #3 (permalink)
DozerDan's Avatar
Member # 9144
Send a message via AIM to DozerDan
Been running Propane in the garage for years, never had a problem. But I do not just let it run non stop, and my garage is far from sealed.
Even so never had a CO go off or felt any ill effects from it.
Normally I just use it to take the chill out, then keep my electric ones on. Kick it on and off as needed while I am out there.
For my garage if I keep the doors closed my electric ones will keep it bearable. I supplement with the propane. Of I I have to have a door open I will run it, but no worries on air exchange there. Waste of money, but worth it.
Dan Smith
'physically strong, mentally awake, and morally straight'
Fear is not an option!
DozerDan is offline   Reply With Quote Quick reply to this message
Old 11-13-2018, 08:22 PM   #4 (permalink)
Member # 192237
used to run a big coleman one all the time, just about deafened you after a while
You learn to shut it off and take a break when your head starts pounding from the CO. Let the heat soak into the shit and the slab a bit, then open the door for a bit to change the air out. Everything being warm heats the fresh air back up pretty quick.
Old 11-14-2018, 06:15 AM   #5 (permalink)
Member # 108445
I cringe at relying on a CO detector, which could fail, to protect one's life. Granted garages are generally pretty leaky but duct some fresh air to the burner.
And I don't faking miss that shit one bit.
rocket flier is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 06:22 AM   #6 (permalink)
Propane's Avatar
Member # 30839
I like the infrared catalytic style. Feels like the sun. 2 co detectors?
Bulletproof propane kits for extreme off road and carbureted engines. Please visit our website for details.
_____________________________
TO ORDER ONLINE:
Check us out on Facebook
Propane is online now   Reply With Quote Quick reply to this message
Old 11-14-2018, 06:52 AM   #7 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
Modern CO detectors are designed to respond pretty slowly to reduce nuisance detection, keep that in mind. Most newer propane heaters don't really make much CO as long as the flame isn't yellow and it's clean. I've run through a 15 lb propane bottle on a tank top heater all weekend in my 24x24x10 garage without issue, didn't have a detector going though. Fairly tight garage except for leaks around gaskets.
A bigg warning from my personal experience however: Don't use any chlorinated (non-flammable) brake/electronics/carb cleaner anywhere near one of those heaters. My lungs hurt for a month after using some briefly on a snowmobile carb in my garage near my heater. I knew about not using it around welding operations, but didn't know that just the vapor would react in one of those heaters.
I don't pay nothing for anything.
larboc@hotmail.com is online now   Reply With Quote Quick reply to this message
Old 11-14-2018, 08:37 AM   #8 (permalink)
Member # 228875
Oh yeah, I made that mistake many years ago spraying around a carb. Anything with a flame like a heater or IC engine will burn it, making Hydrogen Chloride acid (HCL) and Phosgene gas (like WW1 "mustard gas") ! I ran out, and it corroded the shit out of any exposed metal in the garage.
stephen wilson is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 11:04 AM   #9 (permalink)
Member # 343737
any ventless gas heater produces heat, co2 and water vapor and is 100% efficient by nature of the ventless. if you can handle the water condensing on every metal surface in the shop, go for it. i switched to a $200 90% gas furnace 17 years ago cuz i couldn't handle the water running off my toolbox and cast iron machines
_ogre is offline   Reply With Quote Quick reply to this message
Old 11-15-2018, 06:22 AM   #10 (permalink)
Member # 70148
Ehhhh, not quite 100%. There is some CO and hydrocarbon given off but it is a small amount. Let's call it 99.5%.
