What's on Your Shop Walls (tables and charts) ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-01-2018, 05:36 PM   #1 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
Probably a thread of this at GJ, but fuck 'em.
I don't have a mobile phone, or internet at my shop and I'm occasionally needing information like trailer harness pinouts or bolt torques.
What is handy to have displayed?
Tap/die drill bit stuff, conversions from fractions to .000 to metric,
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 12-01-2018, 05:39 PM   #2 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
Pin up girls
Every day is better than the next.
Benny is offline   Reply With Quote Quick reply to this message
Old 12-01-2018, 10:08 PM   #3 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Drill sizes in decimal form
Tap drill sizes (including NPT tap drill sizes)
Bolt size torque chart
Speeds and feeds for different materials (if you do machining)
Sheet metal gauge thickness in decimal
Wire gauge thickness amp carrying capacity (for electrical stuff)
AN/JIC fitting chart with the fitting thread size?
Trailer plug pinout
I need to get some more/different charts put up. Have a handy dandy hot laminating machine that would be perfect to laminate some with.
I have the drill sizes up on just regular printer paper, and tap drill sizes, but I need to include the NPT tap drill sizes. Also have a trailer pinout printed out and in a plastic sleeve, Would be smart to re-do it and laminate it too.
Another thing is if you keep a bunch of oil/fuel filters on hand is to make a chart with the filter number and what all it fits. We have a cabinet full of filters and have some hand scribbled notes on what the stuff fits. I need to really re-do that sometime too.
This is a good idea for a thread. Hopefully others post up some good ideas for other charts, and if anyone finds any real good charts post them up for fucks sake!
Man I used to have those charts saved on my computer, but that has been years and years ago. Now I can't find them. I will keep looking.
The one, the only, the Dane.
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 12-02-2018, 06:27 AM   #4 (permalink)
Member # 844201
Tits!
madcratebuilder is offline   Reply With Quote Quick reply to this message
Old 12-02-2018, 07:59 AM   #5 (permalink)
Member # 181868
Trailer plug pinout.
These are all good ideas except the bolt torque. I never use a torque wrench unless it's a critical item. In that case, you have to go to a manual because it might not be standard.
I wish they made a plastic poster size of the rest of that stuff. I'd be willing to pay.
The other thing I was planning to do was put up a chalk board. It would be good for putting up info that you want to save, but not forever. Example, the order of something you take apart. Your going to put it back together in a few days (when you get parts) It also could be good for drawing something your fabing.
Project : Amphibious HEMTT
Old 12-02-2018, 08:30 AM   #6 (permalink)
Rednek
Member # 52387
A lot of things that I think should be torqued don't have a specific torque mentioned. Like when putting a water pump on, there usually isn't a specific torque spec for that make and model, so I just go by the bolt size. Or when taking apart and putting back together a hydraulic pump. I'll just check the chart and go by the thread size and pitch for the torque spec. Also I build a lot of random shit, so if it is something bolted together precisely on machined surfaces that I want to take advantage of the maximum holding strength of the bolts I'll torque it to spec.
Now head bolts, main and rod bolts, etc, yes go by the specified torque for that specific application.
EDIT: Oh and if I'm bolting into aluminum threads I'll definitely torque to spec, cause you sure as hell don't want to overtighten the bolts and strip the threads out of the aluminum.
Old 12-02-2018, 08:39 AM   #7 (permalink)
Member # 181868
While I agree with what you're saying, I'm not going to get the torque wrench out. It's an extra step I don't have time for. I haven't had any serious issues with my arm torque wrench.
Old 12-02-2018, 08:02 PM   #8 (permalink)
Member # 859684
Sounds like you need a copy of the pocket ref
Everything you want is in a handy black book that I keep in the top drawer of my tool box
Shorthood is offline   Reply With Quote Quick reply to this message
Old 12-03-2018, 04:50 AM   #9 (permalink)
arse_sidewards's Avatar
Member # 256962
My walls are covered in paint and the paint is covered in metal dust.
Old 12-03-2018, 06:20 AM   #10 (permalink)
Member # 181868
I have most of those tables in small charts or cards in differnt places around the shop, but a big easy to read poster would be better. Wind couldn't blow it away. I could put the drill size and tap chart right where I keep the drill bits. A small book would get lost or eaten by the dog.
Old 12-03-2018, 09:17 AM   #11 (permalink)
freerider15's Avatar
Member # 23795
Send a message via AIM to freerider15
Right now just a 2x3ish whiteboard. Having one of those to scribble on is well well worth it.
I've got a small list, but currently I plan on:
- Tap and Drill chart
- Drill conversion chart
Other than that not too much (as I don't have machining abilities).
XJ Based Buggy: 42's, Tons, Full Hydro, ORI's and a fukkton of tube...
freerider15 is offline   Reply With Quote Quick reply to this message
Old 12-03-2018, 09:21 AM   #12 (permalink)
Member # 207814
The SPI decimal chart is a great place to start.
22" W x 32" H.
SPI Decimal Equivalent Wall Chart (Fraction, Wire Gage, Letter & Metric Sizes) - 98-034-2 - Penn Tool Co., Inc
1989 Toyota know as Captain America
NorIdaWheeler is offline   Reply With Quote Quick reply to this message
Old 12-03-2018, 12:06 PM   #13 (permalink)
Member # 181868
Originally Posted by NorIdaWheeler View Post
I ordered one. Kind of sucked they charge $11 to ship.
Old 12-03-2018, 12:15 PM   #14 (permalink)
Provience's Avatar
Member # 138976
currently nothing except for notes that I've written to myself.
I want: to get a bunch of weld joint design charts up, I have a few.
a large tap/drill chart
a trig triangle picture
solving triangles
common speeds and feeds for things I use the most
speed formula and feed formula
tube coping base angles for various sizes
drill and lathe tool grinding example charts.
I like cluttered walls
Old 12-03-2018, 05:13 PM   #15 (permalink)
bigdaddylee82's Avatar
Member # 54666
I've got a similar version of this Starrett chart, and a decimal conversion chart mouse pad that was SWAG from some vendor.
Trig stuff, I use an app on my phone.
Everything else on the walls is decor.
No Vacancy
bigdaddylee82 is offline   Reply With Quote Quick reply to this message
Old 12-05-2018, 02:28 PM   #16 (permalink)
blown4x4's Avatar
Member # 43190
I keep copies of the machinist handbook in the house and in the shop. My walls are covered with pegboard for quick access to screw drivers, wrenches, extension cords, wire brushes, grinding wheels, and various other items.
1976 F-150 2.5tons locked disk braked 466bff ord doubler 44" boggers coil-overs air bumps etc
blown4x4 is offline   Reply With Quote Quick reply to this message
Old 12-05-2018, 05:11 PM   #17 (permalink)
DozerDan's Avatar
Member # 9144
Send a message via AIM to DozerDan
This, a white board is my go to. Notes, numbers, drawing something out for someone else to understand etc etc.
I even got them for at work, magnetic ones that we keep on each control cabinet next to the controller. Make a small adjustment or want to play with something, just write down what it was etc.
Pretty much all of the other departments have adopted my idea.
Charts- the ones I don't know off hand I just look up as I keep a lap top in the garage.
Dan Smith
'physically strong, mentally awake, and morally straight'
Fear is not an option!
DozerDan is offline   Reply With Quote Quick reply to this message
Old 12-05-2018, 05:23 PM   #18 (permalink)
rockmup's Avatar
Member # 16699
They do, the tool shops give them away every year.
rockmup is offline   Reply With Quote Quick reply to this message
Old 12-06-2018, 04:55 PM   #19 (permalink)
Member # 23795
Sweet, thanks for posting that. I'm going to get some 11 x 17 laminating pouches and get that one made up at work.
Anyone have any others like that, or ones they have offhand?
I've been laminating plenty of things worth it (fuse diagrams for my buggy/XJ's, trailer 6 pin wiring and fuses for my tow rig, etc.).
Having a laminator at work, and a label maker I "have" access to at work is awesome
Old 12-06-2018, 06:17 PM   #20 (permalink)
Window Licker
bgaidan's Avatar
Member # 34948
You can get the Starrett wall poster + 4 pocket cards for $12 shipped on ebay. I've been meaning to look for these...real handy to have the card on the desk when drawing cad and cam'ing for the CNC. Just ordered a set.
https://www.ebay.com/itm/ONE-LARGE-T...s/263581996027
I love Dicks and will continue to shop there.
bgaidan is offline   Reply With Quote Quick reply to this message
Old 12-07-2018, 06:30 AM   #21 (permalink)
today
fredycruger's Avatar
Member # 225557
starrett used to giving the posters away last year
you could order cards and posters
i ordered like 40 of each
http://www.starrett.com/catalogs
fredycruger is online now   Reply With Quote Quick reply to this message
Old 12-07-2018, 06:46 AM   #22 (permalink)
Shift to the Best
R.DesJardin's Avatar
Member # 68266
Tap Drill and decimal equivalent charts. Diff cover chart, cuz umm not sure why. An old MSC chart has the most info I have seen. Always Starrett Drill/Tap Drill cards laying around in strategic locations.
Shift controllers and shifters, AMS mounts
Toyota Triple & Twin Sticks
John 3:16- He is the answer.
R.DesJardin is offline   Reply With Quote Quick reply to this message
Old 12-07-2018, 08:08 AM   #23 (permalink)
Window Licker
bgaidan's Avatar
Member # 34948
Catalogs
They don't have them any more. Ordered some of the other hole saw and band saw charts though.
Next time I'm up that way I'm gonna shoot over to Athol steal some.
Old 12-07-2018, 08:17 AM   #24 (permalink)
today
Member # 225557
bc those fuckers who knew at the time
ordered shitload of them and re-sale them on ebay
Old 02-02-2020, 12:34 AM   #25 (permalink)
Member # 20304
Send a message via AIM to BarrelRoll
Bumping this back up from the dead, stumbled upon this searching for something else
Little machine shop has some good references
https://littlemachineshop.com/info/b...43147249&CAT=1
I like the tap and clearance drill chart and have most of them on the wall. I also have a chart with all the standard torque specs for my jeep, I can't remember where I found it. After seeing enough stuff fall off desert race cars I became a believer in torque wrenches, all of sudden when everything was torqued to spec stuff started falling off. I used to use a wrench and ratchet, they work fine up to about 3/8" and then you really need popeye arms or some leverage to get stuff tight.
This board is no doubt slowly moving from Pirate4x4 to ElitistYuppyWithTooMuchMoney4x4.
-Braxton 357
BarrelRoll is offline   Reply With Quote Quick reply to this message
