50x80 steel building in Phoenix - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2019, 06:22 PM   #51 (permalink)
Member # 37016
Approach formed out and inspected. Monday getting poured. Then clean up dirt and gravel. Then final inspections
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 03:54 PM   #52 (permalink)
Member # 37016
Some more photos.
Old 06-11-2019, 03:54 PM   #53 (permalink)
Member # 37016
Time Lapse of building going up. Missed one day but it's the back wall so couldn't see it well anyways.
https://youtu.be/6_PolQ9SUlY
Old 06-15-2019, 10:51 AM   #54 (permalink)
Member # 37016
Approach is done. Concrete has been buffed clean and densifier has been applied. Concrete sealer goes in next weekend followed by garage doors on the 25th.
Old 06-17-2019, 06:47 AM   #55 (permalink)
today
fredycruger's Avatar
Member # 225557
Originally Posted by 65Chevy4x4 View Post
Some more photos.
is the roof construction just rolled insulation with plywood and sheet metal over ?
shop is cool
fredycruger is offline   Reply With Quote Quick reply to this message
Old 06-17-2019, 10:24 AM   #56 (permalink)
Member # 37016
Roof is actually just rolled insulation with the sheeting ontop of it. The insulation has the fiberglass on outside and vinyl backed on inside.
Old 06-17-2019, 09:26 PM   #57 (permalink)
Member # 37016
Passed final inspection today. Now I can finish it off and move in and get back to work.
Old 06-18-2019, 02:30 AM   #58 (permalink)
Member # 406202
Very nice!
FirstRam is offline   Reply With Quote Quick reply to this message
Old 06-25-2019, 11:28 AM   #59 (permalink)
Member # 37016
Doors going up as I type. Finally can start moving stuff from my current shop to its final resting spot.
Also my wife and I worked in the shop all weekend and got a good jump on framing out the walls and getting ready for electrical and sheeting. I went a little overkill on the studs on bottom part of wall but I've put many holes in the walls on past shops so I wanted studs every 24inch.
Also got the support posts and header set for my lean to to attach to as well. Need to make some steel brackets to tie it all together and then that's ready to go when that time comes.
Also will have the office and bathroom all framed out this week after work as well. Moving along. Hopefully have it all wired. Sheeted and painted by mid July. Which will leave me 2 weeks to get everything out of my shop and cleaned up to turn in the keys.
Old 06-25-2019, 02:56 PM   #60 (permalink)
Member # 37016
Doors are in
Old 06-27-2019, 06:46 PM   #61 (permalink)
Member # 37016
Office and bathroom going up.
Old 07-04-2019, 07:26 AM   #62 (permalink)
Member # 84339
Moar pics of the wife working on your wood
That is a nice looking building. And 24" studs doesn't seem like overkill to me - not for framing in the walls. Are you using plywood or drywall?
Lugnut4x4.com
And i don't want to give Canadiens any more money, so my sig is broke.
Pt_Ranger_V8 is offline   Reply With Quote Quick reply to this message
Old 07-04-2019, 05:05 PM   #63 (permalink)
Member # 37016
Osb for the walls.
Lights hung. Office roof sheeted. Insulation going in. More electrical and conduit going up tomorrow.
Old 07-06-2019, 04:09 AM   #64 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
No trouble with humidity or water getting into the wood touching the concrete?
Lately I've been installing used 3/4 inch conveyor belt under all wood that touches concrete flooring. Keeps the wood from soaking up water from the concrete. I've also used scrap plastic deck boards for the same.
You're not in northern canada, so obviously your humidity isn't the same....
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 07-06-2019, 09:33 AM   #65 (permalink)
v6toy4x's Avatar
Member # 9154
Originally Posted by Crisbee1 View Post
I usually piss on the tires of who evers truck is in the drive way. The urinal is for guests
Words to live by
GOD MADE DIRT, MOTHER NATURE MADE THE ROCKS & HEAVEN MADE THE LAKES
THANK GOD FOR MOTHER NATURE I AM IN HEAVEN
85 4rnr,8"hp,9"det,R151,toybox,d300 4:1
98.5 dodge,EZ,TST,ex brk,Goerend,ford outers,quad bags
'05 arctic fox-880wts solar,inverter,cocktail cubes 24/7
502cu in boat EVIL SATISFACTION
v6toy4x is offline   Reply With Quote Quick reply to this message
Old 07-06-2019, 11:24 AM   #66 (permalink)
Member # 191
The build is going very nice Chevy.... Not sure how much *extra help you've been getting on it however no matter how much the building is going up fast.!
I wanted to know how you like your trailer?? I'm strongly considering building
a copy of one like yours..... with the hydraulic tilt option to eliminate having to use ramps all the time unless absolutely needed.......
any thoughts if you could change anything on yours?? what length is it? I was
thinking of building a 24 footer. definetely drive over fenders. winch up front.
any input you have for me is greatly appreciated.!
--Nice shop build.!
--Sherpa
[QUOTE][i]Originally posted by LAME [/i]
[B]
The guys designing cages for the D9 dozer on your Christmas list are going about this a bit differently way then a few rednecks, too much beer, and a JD2:D [/B][/QUOTE]
SHERPA is offline   Reply With Quote Quick reply to this message
Old 07-06-2019, 03:30 PM   #67 (permalink)
Member # 37016
Love the trailer. It's a pj trailer b6 model. 14k lb trailer. 22ft deck. 24ft would be nice but longer than I needed.
Just the wife and I working after the building went up. My parents came out to help us this weekend and next
Old 07-07-2019, 05:21 AM   #68 (permalink)
45acp's Avatar
Member # 13671
Dude, scroll back up and look at the area around the shop. Phoenix is known for alot of things, but moisture is not one of them.
Awesome build btw. I did the double wall osb thing in my old shop and loved it. You can hang shit everywhere.
45acp is offline   Reply With Quote Quick reply to this message
Old 07-07-2019, 01:18 PM   #69 (permalink)
jemarshall's Avatar
Member # 50690
Send a message via MSN to jemarshall
Build is
I'm in the process of buying 10 acres and I'm on the hunt for a steel building. Would it help or hinder to drop your name if I ask them for a quote ?
What ever you do, please do not suck start a shot gun.
Stick it up your ass...that way you're likely to hit something vital.
jemarshall is offline   Reply With Quote Quick reply to this message
Old 07-07-2019, 04:10 PM   #70 (permalink)
Member # 37016
My building was purchased from bunger steel here in Phoenix. Talk to Keith he is the owners son and helped me with everything. I also had comparable quote from heritage buildings but figured for same price local is good if an issue arise
Old 07-07-2019, 05:43 PM   #71 (permalink)
Member # 37016
Put the wife to work bending up some conduit.
Old 07-08-2019, 05:49 AM   #72 (permalink)
jemarshall's Avatar
Member # 50690
Awesome, thank you
Old 07-11-2019, 06:23 PM   #73 (permalink)
Member # 37016
Conduit done. Wire pulled. Wall sheeting tomorrow.
Office and bathroom drywall is all done and tile laid. Grout tomorrow then finish trim and that good stuff.
Old 07-11-2019, 07:36 PM   #74 (permalink)
Member # 406202
Very nice!
Old 07-12-2019, 06:33 AM   #75 (permalink)
GLTHFJ60's Avatar
Member # 140040
Love that wood tile.
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Similar Threads
Steel Building Erecting Yourself 65Chevy4x4 Shop and Tools 39 01-08-2019 04:43 PM
Elorado Nat. Forest Closures - Tactic 1 Bebe Land Use Issues 129 01-20-2016 10:15 AM
Steel vs Pole Jeepermat Shop and Tools 19 01-21-2015 01:25 PM
steel prices Southbound_Pachyderm Shop and Tools 19 08-04-2013 09:19 PM
