50x80 steel building in Phoenix - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-09-2019, 01:18 PM   #1 (permalink)
Member # 37016
Backstory. I'm owner and operator of tt-motorsports.com and have been renting and dreaming of my own home based shop since I started out in 2010. Fast forward to this past November. My wife and I found a perfect home and property to make the dream come true. Sold my rental home in California and got started on the long process. After 2.5 months received the permits and finally getting it going.
Specs are red iron building from bunger steel building. 50x80 16ft eves. 3 12x14 roll up doors and 1 man door on north wall. West wall will have 12x12 roll up door which will open to a 25x50 lean to. Slab is going to be 5inch thick over 4in ABC. Should be a very nice upgrade from my 2000 sq ft current shop that is crammed packed with 3 vehicles and all my equipment.
I will be doing general welding and fabrication. Production suspension and offroad kits. As well as suspension and roll cage fabrication.
Breaking ground this weekend. Concrete should be formed up and poured the end of this month. April 2019. So progress will be a little slow until building is delivered end of may. Myself. My wife. Parents and friends will be erecting the building ourselves.
A little before and after of weed and dirt mount removal. Burned the weeds. Going to cut up trees we removed and trimmed and will burn those once they dry out.
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 02:27 PM   #2 (permalink)
Member # 10
Originally Posted by 65Chevy4x4 View Post
It's awesome of you to provide jobs to the handicapped like that.
Carl Whitmore
I Lean is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 02:36 PM   #3 (permalink)
Member # 10
Oh, and subscribed. Looking forward to what else you come up with.
Carl Whitmore
Old 04-09-2019, 03:29 PM   #4 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Awesome guy!
& Blaine
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 04-09-2019, 04:46 PM   #5 (permalink)
GLTHFJ60's Avatar
Member # 140040
Subscribed.
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 05:59 PM   #6 (permalink)
Member # 109953
glad its finally started for you. Im curious on your numbers vs mine and if you would do the labor yourself again.
AZ Undertakers
ShmUDE is offline   Reply With Quote Quick reply to this message
Old 04-12-2019, 11:04 AM   #7 (permalink)
Member # 37016
The labor quotes j got to erect the building was low end 25k. High end 32k. So I'll rent some equipment and hire a couple erectors on the weekend to help and do it ourselves.
Old 04-13-2019, 11:13 AM   #8 (permalink)
Member # 191
one you get it all rolling could you share prices for components and the building itself for those who are jealous (yes) and would consider doing what you're doing as well?
please?
thank you,
--Sherpa
[QUOTE][i]Originally posted by LAME [/i]
[B]
The guys designing cages for the D9 dozer on your Christmas list are going about this a bit differently way then a few rednecks, too much beer, and a JD2:D [/B][/QUOTE]
SHERPA is offline   Reply With Quote Quick reply to this message
Old 04-13-2019, 11:29 AM   #9 (permalink)
Member # 37016
Building with the 4 door openings 1 man door 2 windows 4inch wall insulation and 6inch roof insulation was 35k. Concrete is 23k. Roll up door installed 7500. Rest will keep updated as I go for lighting. Electrical. Etc.
Old 04-16-2019, 10:26 PM   #10 (permalink)
Member # 37016
So concrete guys are getting started on Friday. Any tips or things you guys suggest to make erecting building and assuring a nice flat slab?
I have a laser transit here I used to grade and am going to double check the forms once set. As well as triple check anchor bolt locations and level and heights as well to make sure putting up the steel is troublefree as it can be.
Any other suggestions or tips please feel free to post away.
Old 04-17-2019, 05:29 PM   #11 (permalink)
Member # 774777
Buy yourself a nice steel 200' tape for checking layout. Believe it or not nylon ones stretch enough to throw your layout. This seems like common sense but make sure whoever is helping you check the layout knows where to hold the tape. Like inside of form not outside and whether youre holding an inch or not. I did steel erection many years ago and you wouldnt believe how many building get poured wro g because of stupid little issues.
Double and triple check your bolt layout. I used to make a plywood bolt pattern/form that the jbolts would hang through with the nut on top for each column and mark on the forms or sonotube where it went. Then right after the pour you can screw the pattern down and wiggle the bolts down into the wet concrete.
If you hire erectors theyll have their own but if you dont, buy a couple spud wrenches (open end wrench with the long point on the other end). They will make your life so much easier when you start setting steel.
Stuckntx is offline   Reply With Quote Quick reply to this message
Old 04-17-2019, 10:04 PM   #12 (permalink)
Member # 37016
Thanks for the tips. I have plastic 300ft tape but will grab a steel one from a friend to check the anchor bolt layout. Concrete guys are doing anchor bolt layout so I'm sure I will have to move and fix those.
Also have a few spud wrenches for the job as well.
Old 04-20-2019, 01:23 PM   #13 (permalink)
Member # 37016
Porta potty delivered. Concrete guys marked the slab and digging starts Monday
Old 04-20-2019, 01:25 PM   #14 (permalink)
Member # 95025
Awesome project/business move.
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 04-24-2019, 06:09 PM   #15 (permalink)
Member # 37016
70 tons of ABC delivered today. Getting footings dug and this stuff processed tomorrow they said. Then forming up foundation for Inspection. Also going to have them pour 12in thick footings for my 2 2 post lifts.
Old 04-24-2019, 06:16 PM   #16 (permalink)
Crisbee1's Avatar
Member # 133544
I had a 90* 4" drain pipe installed and covered in concrete, chip it out after final.
Crisbee1 is online now   Reply With Quote Quick reply to this message
Old 04-24-2019, 06:51 PM   #17 (permalink)
Member # 37016
I'm having a pipe buried under slab for toilet in future. Are you saying do a drain pipe somewhere else in the shop?
Old 04-24-2019, 07:00 PM   #18 (permalink)
Crisbee1's Avatar
Member # 133544
I will use mine for a deep sink and a urinal, just finished the main line from new well.
Old 04-24-2019, 07:19 PM   #19 (permalink)
Member # 37016
Was planning on just having the sink and that drain through the wall and into the ground.
One question for you guys if I'm running a sub panel for electrical Inside the shop should I have them Install a grounding rod in the slab? And should I have them Install conduit for that panel or should just run the conduit from main panel up the outside wall into sub panel. Thinking in through slab would be cleaner install?
Old 04-25-2019, 03:55 AM   #20 (permalink)
Member # 406202
It almost seems Crisbee1 was planning on pissing in his deep sink, killing 2 birds...
FirstRam is offline   Reply With Quote Quick reply to this message
Old 04-25-2019, 04:36 PM   #21 (permalink)
Member # 37016
Base is leveled. Footings tomorrow.
Old 04-25-2019, 04:43 PM   #22 (permalink)
Crisbee1's Avatar
Member # 133544
I usually piss on the tires of who evers truck is in the drive way. The urinal is for guests
Old 04-30-2019, 06:05 PM   #23 (permalink)
Member # 37016
Footings getting dug tomorrow
Old 05-02-2019, 06:42 PM   #24 (permalink)
Member # 37016
Footings dug and some stumps removed
Old 05-03-2019, 06:45 AM   #25 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
That is the most adorable footing I've ever seen.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Similar Threads
Steel Building Erecting Yourself 65Chevy4x4 Shop and Tools 39 01-08-2019 04:43 PM
Elorado Nat. Forest Closures - Tactic 1 Bebe Land Use Issues 129 01-20-2016 10:15 AM
Steel vs Pole Jeepermat Shop and Tools 19 01-21-2015 01:25 PM
steel prices Southbound_Pachyderm Shop and Tools 19 08-04-2013 09:19 PM
