3ph motor questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-04-2019, 05:42 PM   #1 (permalink)
mjs408's Avatar
Member # 6764
3ph motor questions
So this pig of a motor runs my new to me lathe. It unfortunately is from 1966 and all wiring identification is long gone. I am using a vfd to make 3pg, not sure how to go forward w wiring. My mill still had all thr tags, made it easy. It "ran when pulled"
How do I determine what is what? Ill assume since it only had 3 wires it ground through the machine?
Would i be time ahead to just buy a 3hp motor off Ebay and make a new mount for it?
mjs408 is offline   Reply With Quote Quick reply to this message
Old 05-04-2019, 08:35 PM   #2 (permalink)
Window Licker
Member # 34948
Your pictures suck.
Do the three wires in the first pick go straight to the motor? Is there a wiring tag on the motor? If not, do you know if it was wired for 230 or 480 at its previous home?
If there's no tag and you don't know how it's wired, there are several videos on youtube that show you how to figure out each winding/wire with a multimeter.
If it was wired for 230 previously then it should be as easy as hooking those 3 wires to each of the 3 terminals on the VFD.
A 3p motor + vfd gives you a lot more control options - variable speed, soft starts/stops, easier to reverse, etc. I'd personally try to stick with the motor you have if you can figure it out.
bgaidan is offline   Reply With Quote Quick reply to this message
Old 05-04-2019, 09:36 PM   #3 (permalink)
Member # 192237
put power to the three wires
it spins backwards, swap any two of them
Old 05-05-2019, 08:40 AM   #4 (permalink)
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Yup... It must be grounded through the chassis. We just dealt with this on a submersible pump. Put it in, was running backwards, so I picked two wires and swapped them and it turns the right way now.
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 09:12 PM   #5 (permalink)
Member # 192237
3 ph needs no neutral
ground is for safety only and should absolutely not be conducting from any of the three wires
Old 05-06-2019, 06:42 AM   #6 (permalink)
Member # 228875
I assume those 3 wires are from the cord hanging below the contactor ? You have to go back to the pecker head ( motor junction box ) and check the wiring there. A dual Voltage motor will have 6 leads from the motor windings ( 9 stud on some motors), how these are wired determines the voltage. The Ground is just run from a lug or mounting bolt in the pecker head.
https://www.google.com/search?q=dual...#imgrc=_&vet=1
stephen wilson is offline   Reply With Quote Quick reply to this message
Old 05-06-2019, 08:59 AM   #7 (permalink)
Member # 41764
Or just change the setting on the VFD for phase order. I can usually change B1-14 on a Yaskawa, even when it's in a cabinet faster than I can unpin/repin motor landings.
bggrnchvy is offline   Reply With Quote Quick reply to this message
Old 05-06-2019, 06:03 PM   #8 (permalink)
mjs408's Avatar
Member # 6764
Yaskawa tend to be a decent quality motor? The motor does have 3 sets of 2 wires twisted together.
The mount for above motor was cracked, so im fixing that tomorrow, going to buy 3 new belts, and clean off some major grime
Y
Old 05-06-2019, 06:59 PM   #9 (permalink)
Member # 192237
I run an RPC because fuck power factor
and my chinese VFD died and couldn't be revived by a retard poking around in its innerds, so you know...
Old 05-07-2019, 01:01 PM   #10 (permalink)
Member # 41764
Y
Yaskawa builds good stuff. I don't run their motors mainly because the pump heads all come with Baldor or Leeson's attached, just their VFD's.
I have an RPC for the house, but it's hard to make a pump due volumetric flow control without VFD's at work and not shoot pressures. PF doesn't matter because 480v in is 480v out
well unless I have to set it to constant torque, but whichever
Old 05-07-2019, 06:47 PM   #11 (permalink)
Member # 192237
I dunno but an RPC getting fed single phase on two legs and making the third leg somewhere between the two existing ones has to have horrid PF
Maybe it doesn't?
Old 05-08-2019, 08:41 AM   #12 (permalink)
Member # 41764
Maybe it doesn't?
I was saying where I use VFD's primarily, we're not trying to make a 3rd leg, it's already 480v 3ph.
Similar Threads
anbody built a 3ph generator? widmayer123 Shop and Tools 7 05-19-2015 06:13 AM
1HP, 3ph Motor - new - $100 LiLBucket Misc. Stuff For Sale 10 03-06-2015 05:59 AM
Calculating cost of running a cycling 1phase motor vs 3ph motor that runs constantly. Seabass Shop and Tools 3 07-12-2013 07:53 PM
