What kind of stainless did I buy? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-15-2019, 03:15 PM   #1 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
I found some stainless sheeting at the recyclers today. It is almost mirror finish. It doesn't have the visible grain that is normally in stainless. It feels very rigid, like it would be a pain in the arse to bend it. It is probably 1/16 thick
I would like to know what kind of stainless it is, so I can figure out what filler rod I need to TIG it.
Every day is better than the next.
Benny is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 04:18 PM   #2 (permalink)
ZAG
ZAG's Avatar
Member # 14113
most likely polished 304 stainless
ZAG is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 06:38 PM   #3 (permalink)
rockmup's Avatar
Member # 16699
Why didn't you have them shoot it ? Here, they all have PMI guns.
Take it to a shop and give them a 20 to shoot it.
rockmup is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 06:48 PM   #4 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
I had no idea what you were talking about so I googled PMI gun.
That's pretty cool.
Not worth it for what I am doing. I bought 2 pieces that are 24x36. It cost me $9.31 for both. I want to make a pan in the bottom of the sink cabinet in the kitchen
Old 05-15-2019, 07:45 PM   #5 (permalink)
Member # 192237
got a bunch of sheets like that
they were the mirrors from a prison bathroom
no idea on the alloy, but they sure don't bend or drill good. Pretty much just plasma and abrasives
Old 05-15-2019, 08:06 PM   #6 (permalink)
Member # 200478
I believe 309l is highly regarded for general purpose use on unknown steels. Check out Jody's channel on youtube, welding tips and tricks. He should have content to help you.
isbj60 is offline   Reply With Quote Quick reply to this message
Old 05-16-2019, 11:37 PM   #7 (permalink)
Antisocial
JMAN3203's Avatar
Member # 139337
I'm going with polished 3xx series as well.
Originally Posted by 45acp
I found out about him being an orphan Chinese immigrant. Dude worked the first half of his life in a dim overcrowded toy factory, scrubbing lead dust off of dolls. I can just see him over in the corner with his little asbestos brush and a bottle of formaldehyde cleaner...[...]
JMAN3203 is offline   Reply With Quote Quick reply to this message
Old 05-18-2019, 10:40 AM   #8 (permalink)
JeffHPK5's Avatar
Member # 45481
3 series is non-magnetic and 4 series will show moderate magnetism.
Support Yellow Star Members
Aerospace Tool&Die by trade..Don't call me a machinist!
TEAM CARWASH 2010 TTC CHAMPS
JeffHPK5 is offline   Reply With Quote Quick reply to this message
Old 05-18-2019, 07:05 PM   #9 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
Oh yeah. A magnet sticks to this stuff pretty good.
Old 05-18-2019, 07:56 PM   #10 (permalink)
Member # 200478
Cold worked 300 series can also be magnetic.
Old 06-03-2019, 10:08 AM   #11 (permalink)
Member # 52710
If its highly magnetic, it's not 304 or 316.
Some 400 series stainlesses don't weld great.
Do a test weld, Tig with 309L. Beat it with a hammer and see if you get a brittle failure.
Slowly building:
jpmassey is offline   Reply With Quote Quick reply to this message
Old 06-03-2019, 10:10 AM   #12 (permalink)
Member # 52710
Missed this. Just Tig with 309L and it'll be fine.
FYI, 400 series doesn't have near the corrosion resistance 300 series does.
Slowly building:
Old 06-03-2019, 11:28 AM   #13 (permalink)
Member # 625826
ER312 should work with most any stainless. Very versatile filler rod.
OscarJr is offline   Reply With Quote Quick reply to this message
Old 06-17-2019, 10:35 AM   #14 (permalink)
Gravity Works!
Landslide's Avatar
Member # 25608
If it's mirror finish or polished, it's probably 304 #8 mirror finish. Usually has a PVC protective wrapping on it.
There is an acid test you can use on it along with a tester, one drop of acid on a small pad on the steel then stick the tester on it and count. It should turn a reddish color if it's 316.
304 can and will rust while 316 won't.
Youtube search SS test kit to find out what I'm talking about.
You'll need the correct filler rods for the SS if you Tig weld it. Both 316 and 304 can be formed.
Peg Leg Fab Lab
Landslide is offline   Reply With Quote Quick reply to this message
Old 06-17-2019, 12:27 PM   #15 (permalink)
Member # 36733
If its magnetic its probably 400 series not 300. The OP indicated it was magnetic...you can get 420 and 416 #4bright just like 300 series.
If it weren't for the magnetic issue it can also be 302; that's another 300 series SST used for bright finished consumer goods because it deep draws/bends real nice.
[I]Vegetarian is an old Native American word for bad hunter[/I]
DavidVanVorous is offline   Reply With Quote Quick reply to this message
