Anyone ever use a small sandblaster gun like this? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-06-2019, 07:51 AM   #1 (permalink)
Member # 322034
https://www.amazon.com/gp/product/B0...6G5KMA1U&psc=1
Do these things actually work for small projects?
montrose818 is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 08:19 AM   #2 (permalink)
Member # 143737
I've got an old siphon gun for sandblasting. It makes a god awful mess and you have to fill it pretty often. I'm sure a little site prep like a homemade cabinet would go a long ways
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 08:27 AM   #3 (permalink)
mothfuckle
fredycruger's Avatar
Member # 225557
it works pretty good for small stuff
if you trying to sandblast yo frame its going to take forever
its messy and hogs lot of air
fredycruger is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 08:35 AM   #4 (permalink)
Member # 322034
Messy is probably OK because I park on a gravel dirt lot.
Smaller stuff, like wheels. Air not an issue, have an old Quincy 325 that should keep up. Thanks, I guess I'll put this on my list!
Old 06-06-2019, 12:21 PM   #5 (permalink)
GLTHFJ60's Avatar
Member # 140040
I used one to blast four wheels. Went through two whole bags of red garnet media IIRC. Felt very unproductive, but it did work.
I feel like that kind of thing is for model making size projects, not truck size projects.
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 12:27 PM   #6 (permalink)
kf4zht's Avatar
Member # 80248
I would just get a venturi tube feed style and stick the tube in a bag/bucket of sand. Plus unless you are spot derusting big stuff that can move a blast cabinet is much easier. You don't get dirty/silicosis, everything around isn't covered in grit, the same bag of media last for months, the stuff stays dry.
Those seem suited for very specific tasks. Eg I need to derust/paint data plates for machinery in the field
Sent from my F5321 using Tapatalk
Where there is a way, there's a will.
kf4zht is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 10:02 PM   #7 (permalink)
freerider15's Avatar
Member # 23795
Send a message via AIM to freerider15
I've got the Harbor Freight version.
Works well enough, but isn't mean for large stuff.
I use it mainly to get areas a wire wheel, flap disc, etc, cant get.
It does use a bit of air, and is a little wasteful on media.
But at $7 for a 50lb. bag of media from Tractor Supply...I'm not worried
XJ Based Buggy: 42's, Tons, Full Hydro, ORI's and a fukkton of tube...
freerider15 is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 11:40 AM   #8 (permalink)
Member # 142852
In every instance I’ve ever used a sand blaster, I’d say there’s not a chance in hell I’d try to do a wheel with that. You’ll be reloading every six seconds, lol.
Prozon is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 04:23 PM   #9 (permalink)
Member # 322034
Noted..
How about these?
I have a 3000 psi 5gpm pressure washer. Is flash rust an issue?
Old 06-12-2019, 09:20 AM   #10 (permalink)
_ogre's Avatar
Member # 343737
what are you trying to blast?
i had eastwood blast-in-a-bucket, those little blasters on a home compressor work fine for little things or trying to get in crevices that the sander won't. it will strip paint but not well or fast. i wouldn't even attempt a wheel
_ogre is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 06:58 PM   #11 (permalink)
Member # 82954
Noted..
How about these?
i have one hooked to a 4000psi 5gpm, and its great. i hang a hopper with media gravity fed. the venturi vacuum other wise is inconsistant. no flash rust when force dried
tracyb is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 10:33 PM   #12 (permalink)
Member # 322034
trying to blast random stuff.. semi truck wheels, lift gate, first things on the list..
Old 06-12-2019, 10:54 PM   #13 (permalink)
Member # 31211
What do you use for media? I just ordered one of those.
charlieboyd65 is online now   Reply With Quote Quick reply to this message
Old 06-12-2019, 10:54 PM   #14 (permalink)
Member # 53528
this
ive had the HF version for 6-7yrs and have used it maybe 3 times
Old 06-13-2019, 06:56 AM   #15 (permalink)
GLTHFJ60's Avatar
Member # 140040
That's a good idea. Did you rig up a stand to hang the (heavy) media from or just hang it from whatever's close to what you're blasting?
