3 roll bender - diy - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-15-2009, 10:38 AM   #1 (permalink)
Member # 131717
3 roll bender - diy
Here's my first post, hope you enjoy it.
so, to make a unique exo cage, one needs a unique tool. since i don't want to spend 1200 + dollars on a 3 roll bender, i decided to build one
we looked at what was on the market, 1100 plus shipping and exchange.
but they make nice long radius bends
Me and Lane sat down one night and came up with a CAD drawing, we sourced out a water jet, and this is what came out of it
steel shmeel, this is what i have, it may not look like much but hopefully after tonight we will have machined some roller dies from it. This material is available from Johnston industrial plastics, it's called nylatron GSM, a moly impregnated nylon which is super dense, self lubricating (not wet though) and wear resistant. the guy on the phone said i may not need a bushing for the thru bolt, although i will use bearings. a set of steel dies 400+ canadian, 1 foot of 4" dia. nylatron 60 bucks. here are some links
RADIUS CALCULATOR
http://www.handymath.com/cgi-bin/rad2.cgi?submit=Entry
NYLATRON SPECS
http://www.jmjprofile.com/PlasticMat...#nylatronSpecs
Johnston Plastics
http://www.johnstonplastics.com/
JEEPSERIOUS is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 10:39 AM   #2 (permalink)
Member # 131717
we cut a piece with a perfect .750 inch radius, then i ground a relief and filed the edges sharp
i first cut my depth and width and ruf cut with a small tool, after the basic shape was attained, i used the cutter we had made to get the radius just right.
then parted the individual roller, they will be faced to width and fitted with bearings
bearings set in place on the bottom rollers, the other upper roller will have a key way broached, will use a 7/8 inch keyed shaft and the bearings will be set in the top roller assembly
starting to look like a bender, just have to make the top assembly and cut some tube for seperators.
If your wondering what the 2 large nuts are for, 1 will be welded to the top end of the threaded rod the other at the end of the keyed shaft, this will be so i can use the same handle for each action
back from my parents place in scotia, while there i had a chance to do some machine work for roll bender top assembly.
using a boring bar i enlarged the center hole to .875 so i can fit a 7/8 keyed shaft through it.
broached a key way
i used the band saw to rough cut the 2 top pieces slightly larger than 4.5" x 4.0", each plate is 1" thich. one of these will be mounted solid to very top of the bender and will be threaded, the other will be part of the top roller assembly.
Old 05-15-2009, 10:39 AM   #3 (permalink)
Member # 131717
i milled the pieces down to 4.5" x 4.0"
one of the plates were drilled so the threaded rod could pass through
i cut the sides of the assembly in the same fashion as above, then placed them in a 4 jaw chuck so i could bore holes to fit bearings in them
used a boring bar to get the holes to 1.995" so the bearing will have an interference fit, the bearings are 2.000"
pressed the bearings in
just need to take these parts and put them together with the side plates
Old 05-15-2009, 10:40 AM   #4 (permalink)
Member # 131717
all pieces are together and fit just right, i will test it once i get some tube, still need to make a handle
Old 05-15-2009, 10:42 AM   #5 (permalink)
Member # 131717
with the help of some friends and access to some special equipment we have created a working 3 roll bender which saved us over $1000 and created a tool for the club. thanks to all who helped. check out the vid
here's a few pics
here are some links
RADIUS CALCULATOR
NYLATRON SPECS
Johnston Plastics
Old 05-15-2009, 11:15 AM   #6 (permalink)
Member # 3007
Very nice work on the roller, but that rear tube work is god awfull!
Bones is online now   Reply With Quote Quick reply to this message
Old 05-15-2009, 11:16 AM   #7 (permalink)
SpineTx's Avatar
Member # 1499
In! thanks.
Seriously...when will you have these for sale?
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 11:25 AM   #8 (permalink)
513
Member # 121037
Great tech! Definitely saving this one for sure!
513 is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 11:38 AM   #9 (permalink)
Member # 15461
X2
rolled bends are good if you can incorporate them without drawing attention to them... BTF's KOH rig, Zukizzy's rig, Rockbug all come to mind....
remember, less is more.
awesome roll bender, it gives me ideas! I just dont like rolled tube enough to make one.
95geo is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 11:41 AM   #10 (permalink)
Member # 103814
nice roller build...
you know your truck will now be known as "bubblebutt" from now on...
Flatline's Up! is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 11:44 AM   #11 (permalink)
Pdaddy's Avatar
Member # 8133
Originally Posted by SpineTx View Post
In! thanks.
Seriously
Cool tool build !
LCQ / KOH 09 Co-Driver #62
Midwestwheeler / Hardline Custom
Pdaddy is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 12:02 PM   #12 (permalink)
Member # 2395
Great first posts. I have a few questions. What is the tubing that you are bending, how much have you rolled so far, how are the dies holding up, and are you willing to share the cad drawings that you used for the side plates? Thanks.
Dustin is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 12:41 PM   #13 (permalink)
Member # 131717
1.5" x .120" hrew, what you see in the pic is what i have done so far. the dies are holding up fine, i'll see about the drawings... talk to ya later
Old 05-15-2009, 01:55 PM   #14 (permalink)
Member # 2395
Thanks.
Old 05-15-2009, 03:31 PM   #15 (permalink)
78stepsideUAK10's Avatar
Member # 92930
Badass
k1ob.com
78stepsideUAK10 is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 03:34 PM   #16 (permalink)
Member # 96130
Originally Posted by 95geo View Post
X2
Once it is done it'll look good - it's hard to see the completed project at this stage. Besides - if we all had rigs that looked the same, wheeling would be pretty lame
I will say this - his roll bender works really well. It pulls the tubing through like butter, and rolls it with ease.
Corey Kruchkowski, [COLOR="DarkOrange"]TEAM TNT motorsports - car 780/car 781[/COLOR]
[COLOR="Lime"]Pitbull Tires [/COLOR]
[COLOR="Red"]ROARK SUPPLY
[/COLOR]
[COLOR="DeepSkyBlue"]Bilstein Shock Absorbers [/COLOR]
[COLOR="Gray"]Rugged Race Radios[/COLOR]
[COLOR="Orange"]Gear Center Group
[/COLOR]
YJ_and_Corey is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 04:58 PM   #17 (permalink)
Member # 25377
Fawking awesome!
Billy
Follow my build-up at
JeepFreak21 is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 05:10 PM   #18 (permalink)
heepr's Avatar
Member # 26806
Send a message via AIM to heepr
Cool tool tech.
but the rig looks like a dome tent.
heepr is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 05:20 PM   #19 (permalink)
rockkiller's Avatar
Member # 14962
X2
who are you i have'nt seen anything you have built
2 seater car , rock crusher 60's atlas 4.3liter 350 turbo 39 krawlers
rockkiller is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 07:09 PM   #20 (permalink)
Member # 11425
very cool...
[I][SIZE="1"][COLOR="Silver"]"do what thou wilt shall be the whole of the law"[/COLOR][/SIZE][/I]
fledgling666 is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 09:14 PM   #21 (permalink)
Member # 45530
The bender looks great. Seems like it would be easier to buy/beef up/modify the Harbor Freight $150 roller.... There was a review in the tools section that wasn't half bad. Nice job either way!
Panthers65 is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 09:52 PM   #22 (permalink)
SeaBass44's Avatar
Member # 40
we have a tool section............
[COLOR=Red]--
:evil: # 530.532.4529:evil:[/COLOR]
TTC 2010 1989 BRONCO
:evil:-[COLOR="Red"]Awesome web development for your business[/COLOR].
SeaBass44 is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 10:07 PM   #23 (permalink)
Member # 14712
Nice job on documenting the build! Welcome to Pirate
Killerpee is offline   Reply With Quote Quick reply to this message
Old 05-16-2009, 04:44 PM   #24 (permalink)
Member # 20276
Cool tool build.
But those are only good for ROLLING out circles or half circles. Not bending. You do that with a tub bender.
01 RAM 2500 24V CUMMINS DD/Krawlerhauler
85 Yota Buggy 4.3/tb350/x2ler/2.5tons/42"s
Ramrock is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 12:33 AM   #25 (permalink)
Member # 96130
Originally Posted by Ramrock View Post
Cool tool build.
Well - the tubing is no longer straight - so I guess it's now BENT isn't it?
And what the hell is a "tub bender"? Sheesh.
[/COLOR]
[/COLOR]
