Best 38-40" tire for snow - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Snow Wheelin'
Old 01-15-2016, 06:55 AM   #101 (permalink)
wes761's Avatar
Member # 227979
What's not on the list, but probably should be are PB Rockers. Any real world comparisons between Rockers and Iroks? From what I've read, those are the two top dogs for <44". I'm planning on new tires this summer and am undecided between 42" bias or 41.5" radial Rockers vs Iroks. With a price of $2k+ for a set, it's a serious decision.
01' Tahoe, D60hp & 14b both lock'd & link'd w/coils, 4.56's, NP241, hydro assist, 41.5" PBR's
wes761 is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 07:30 AM   #102 (permalink)
Wilson's Avatar
Member # 7233
I've run both. I won't say that one was necessarily better than the other, but the 42" pbr is bigger than the 42" irok. I would take a radial over a bias tire, any day.
Old 01-15-2016, 02:51 PM   #103 (permalink)
86chevyjoe's Avatar
Member # 128588
Send a message via AIM to 86chevyjoe
Not a fan of rockers whatsoever. They are heavy, expensive and have weak sidewalls. Weren't on my list for a reason.
I like to snow wheel
86chevyjoe is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 05:15 PM   #104 (permalink)
Wilson's Avatar
Member # 7233
I have run nearly every popular tire and have been the first test mule (locally) on a few. I can't say that I've ever come across a tire with a "weak sidewall." From reading this site and watching koh over the years I have heard the generalizations that many popular tires have "weak sidewalls." Everything from krawlers, to mtr's and even maxxis tires. The only consistencies that I have personally seen relating to popping sidewalls are air pressure and driving style.
In regards to the rocker, they are heavy because there is a lot of material in them. They have thick beads, thick sidewalls and a lot of rubber. These all contradict a "weak sidewall" statement. In my experience they are a tough tire. They grip rocks a lot better at single digit pressures than at 10+psi, but that is a gamble with any tire (in my opinion). I ran mine at 13 psi in the rocks on a 3700# buggy. In the snow (3 psi) I hit something buried in a ditch at speed. It bent a raceline wheel, but did not cut the tire. As for price, they were cheap when I bought mine. I got 5 42's for $1900 in 2008. Now they are on part with most big tires.
I would be curious as to which size and construction rocker you have experience with. The 39 is an abomination and out of the 3 friends that have run them, they all hated them. The 37 bias also runs small. I have personally had both the 42 and 44" and was happy with them. I have also wheeled with a set of 37" radial Rockers and thought they did well too. The 41.5 radial appeals to me because it is the largest radial (next to the 42" kevlar) that you can get.
Old 01-15-2016, 08:24 PM   #105 (permalink)
86chevyjoe's Avatar
Member # 128588
The weak side wall comment was honestly due to only two set of rockers, both bias 39.5s and 42s. Both guys had trouble with pin hole leaks in the sidewalls; the 39.5s on a first gen 4runner and the 42s on a suburban. They both fought with pitbull to get them warrantied and both ended up going to 39.5 and 42" bias iroks respectively. The suburban was a snow wheeling only rig and the 4Runner wheeled year round. Other then that I don't have any experience with them, but them being so heavy and expensive have also detoured me from buying them
Old 01-17-2016, 11:48 AM   #106 (permalink)
Wilson's Avatar
Member # 7233
Got the geolandars out for the first time yesterday. Snow conditions were mixed and because the tires were new, I played with the pressures a bit. I started at 5 psi in the ruts and on the road in, then dropped to 3 psi once I was punching fresh tracks. Once we were climbing, I went to 2 psi and the tires flat do work. I may have had the lightest rig in the group (YotaAtieToo needs to weigh his) but I was moving around better than the two one ton jeeps on 42" iroks and 42" kevlar's. With the 37" kevlar's on our last trip, the 42's had a clear advantage over me. At 2 psi, I could go anywhere even up the hill side to get around a broken rig. I only managed to bury the jeep once, and a little shoveling is all that it took. The tires do not dig much going forward and consistently found a bite when I let it creep. In reverse the tires will dig, not sure if i'll try the fronts flipped at this point.
Breaking trail at 2 psi and running on the sidewall tread gave me a nearly 18" wide footprint.
This is a sight that I like to see when breaking trail, deep cracks in your tracks. This shows how well you are floating.
Old 01-17-2016, 06:52 PM   #107 (permalink)
Member # 429
Awesome. Looks like those tires are doing you good.
Jack
2007 2500hd max/ali with stuff.
2008 FWC Hawk
1985 4Runner 4.3, R151 on tons
locrwln is offline   Reply With Quote Quick reply to this message
Old 01-18-2016, 09:42 AM   #108 (permalink)
79chevy39.5's's Avatar
Member # 67935
How tall do thwy stand true 40? Or are they closer to 38?
too many trucks not enough dough
79chevy39.5's is offline   Reply With Quote Quick reply to this message
Old 01-18-2016, 05:00 PM   #109 (permalink)
Wilson's Avatar
Member # 7233
If you're asking me, they are the 38x13.50 and measure 38" tall.
Old 01-18-2016, 05:28 PM   #110 (permalink)
YotaAtieToo's Avatar
Member # 25632
We need to find someone to get the 40s
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 01-18-2016, 05:54 PM   #111 (permalink)
Member # 84361
Thinking about it. For the price they may be hard to pass up. I've been shopping for a set of dedicated snow tires for my one ton trail slut.
Toy, 4.3, 4l60, d300, tons, 38's, Trail Slut
JHF GB Chassis in progress.
crazybluerider is offline   Reply With Quote Quick reply to this message
Old 01-19-2016, 05:02 AM   #112 (permalink)
86chevyjoe's Avatar
Member # 128588
they are super cheap on tirerack! if I didn't have 6 "new" OG 37" mtr's, I would be buying the geolanders in a heartbeat
Old 01-19-2016, 05:55 AM   #113 (permalink)
Member # 150599
The 40's are taller than the old MTR's my buddy has them. I would say they measure 39.5" or slightly more.
95 4runner, 64" diamond, 3.4, duals, 5.29 arb's, york oba
mtsnowrunner is offline   Reply With Quote Quick reply to this message
Old 02-17-2016, 07:52 PM   #114 (permalink)
Member # 226
Any updates on the performance from the geolanders? Are you still happy with them?
Ben W is offline   Reply With Quote Quick reply to this message
Old 02-17-2016, 08:12 PM   #115 (permalink)
Member # 25632
Its been sunny and 75* here for the last few weeks.
Old 02-17-2016, 08:21 PM   #116 (permalink)
Wilson's Avatar
Member # 7233
And my jeep is down for mods
Old 02-18-2016, 01:04 AM   #117 (permalink)
86chevyjoe's Avatar
Member # 128588
buy them ben
Old 02-19-2016, 05:53 AM   #118 (permalink)
Member # 150599
My Grooved and siped 40" Toyo MT's seem to work really well. I've been out twice and I'm really happy with them. They air down quicker than I expected also. 5psi and they really look good. 2.5-3 is where I've been running them. My truck is 5,000 lbs.
Old 02-27-2016, 09:25 AM   #119 (permalink)
Member # 135279
Anybody running 42" MTR's? Getting ready to grove mine and looking for feedback.
shrek tits is offline   Reply With Quote Quick reply to this message
Old 02-28-2016, 05:59 PM   #120 (permalink)
Member # 190076
Boggers.... the 39.5 variety.... This is around 20+ inches of snow. Just flat out keep chewing.
BazookaBoy is offline   Reply With Quote Quick reply to this message
Old 02-28-2016, 07:28 PM   #121 (permalink)
86chevyjoe's Avatar
Member # 128588
Ya boggers dig ^ which doesn't end up well when you're on multiple feet of snow and you can't dig to the ground to get traction
Old 02-28-2016, 07:44 PM   #122 (permalink)
wramblerguy's Avatar
Member # 228970
Best 38-40&quot; tire for snow
Mtrs ftw
Build thead stalker
www.greatlakes4x4.com/showthread.php?t=236415
wramblerguy is offline   Reply With Quote Quick reply to this message
Old 02-28-2016, 09:40 PM   #123 (permalink)
Member # 25632
Originally Posted by wramblerguy View Post
Mtrs ftw
Really?
Slowmo driving through 8" of snow?
This thread about the BEST tires for deep snow, not "hey my 40" Boggers can chew threw snow that's half as deep as they are tall"
Old 02-29-2016, 01:30 AM   #124 (permalink)
86chevyjoe's Avatar
Member # 128588
Old 02-29-2016, 04:34 PM   #125 (permalink)
Member # 190076
Really?
Well? Let's hear it... You're obviously the foremost authority on all things snow wheeling. So, what is the BEST tire Mr. shitdick ??
I like how you can't even form a basic sentence or spell 1st grade level words correctly, but somehow are qualified to tell anyone on here anything.
