post up your grooved snow tires - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Snow Wheelin'
Register Blogs FAQ Community Calendar Premium Memberships
Old 03-28-2018, 11:36 AM   #76 (permalink)
TimCubed's Avatar
Member # 220897
Well, I did a little tire comparison this morning. Between Irok vs. TSL:
Name:  Tread compare.jpg
Not much to say...Irok wins hands down!
Just a couple observations:
Pushing on the tires side to side at 1 psi, the Irok's moved approx. 3" on the wheel, the TSL's moved approx. 1"...stiffer side to side
Next, the visible track in the snow is different, the TSL's have one continuous mound in the center, where the tread crowns up. The Irok's have small round mounds approx. 1-1/2" high, 4" around, approx. 12" apart.
I see it as the TSL's are just spinning and the Irok's are grabbing cups full of snow. I assume the TSL's are wadding up on the sidewall, the Irok's wad up on the bottom providing traction.
I have lost the bead on the Irok's at 1 psi about 6 times total over the last two years. This year on the TSL's they have burped air down to zero 3-4 times and not lost the bead at all.
'44 GPW Stretched and Linked
'51 Willys bigger Stretch bigger Links
TimCubed is offline   Reply With Quote Quick reply to this message
Old 03-28-2018, 11:43 AM   #77 (permalink)
Member # 85771
I love stuff like this! Thank you.
Make Forums Great Again!
Old 03-28-2018, 12:27 PM   #78 (permalink)
Member # 830074
Attachment 2845026
Attachment 2845018
Put 3m window weld on the inner bead. Never will lose bead. The tsl is stiffer hence less side to side. We have talked lots of times up on the trail about tires and pressure. To me and everything i have seen a large radial is supreme. Bias with lots of grooving and totally breaking down the tire before trail use are good also. See you next weekend tim.
Sent from my SM-G950U using Tapatalk
Deepsnow is offline   Reply With Quote Quick reply to this message
Old 03-28-2018, 04:53 PM   #79 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Awesome tech. And I have seen the “cupping” of the snow following guys with iroks.
Old 03-28-2018, 05:04 PM   #80 (permalink)
Member # 135279
Originally Posted by Deepsnow View Post
I dont think so. The mtr 42 is a very big tire i bet its close to the 44 sts as the mtr is bigger than a 43 sx side by side. In the snow were me and tim wheel at off highway 50 near kirkwood a longer tire works better than a wide tire. With the exception of sugar snow then its widest with most hp goes farther. A longer tire acts more like a track then a wider tire. Tims rig for instance. The longer radial way out performs the wider tire tsl all day everyday so that wider theory on the op rig would be false.
I've had both the 44s are bigger. I will try and get a picture posted of them side-by-side
shrek tits is offline   Reply With Quote Quick reply to this message
Old 03-28-2018, 05:38 PM   #81 (permalink)
86chevyjoe's Avatar
Member # 128588
Send a message via AIM to 86chevyjoe
From my experience, 42” and under you want radials. Everything bigger, except for maybe 44” TSL, 44” bogger, and 47” LTB, will do better just due to pure size.
Ask shrek tits which tire does better in the snow, he’s ran both 42” mtrk and now runs 44” STS......
I like to snow wheel
86chevyjoe is offline   Reply With Quote Quick reply to this message
Old 03-28-2018, 05:40 PM   #82 (permalink)
86chevyjoe's Avatar
Member # 128588
Here you go brandon
Old 03-28-2018, 08:53 PM   #83 (permalink)
Member # 135279
Thanks Joe.
Old 03-28-2018, 09:07 PM   #84 (permalink)
YotaAtieToo's Avatar
Member # 25632
In my experience 44 tsls are closer to a 40 than a 42, so I can see where they could be outdone by a 42 radial.
I still stand by the tires with more aggressive tread doing better down here. The "at" tires like the STS and cepecks can float well, but when you have to go up a hill or climb out of a creek. They struggle, like bad. I had problems climbing out of creek crossings where a few guys with 33s didn't. Pretty embarrassing. This is probably why you never see them down here. I have seen 2 guys with 44 STS and 2 guys with 44 cepecks.
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 03-28-2018, 10:34 PM   #85 (permalink)
86chevyjoe's Avatar
Member # 128588
Wet snow vs dry snow. Almost need 2 sets of winter tires lol
Old 03-28-2018, 10:39 PM   #86 (permalink)
Member # 25632
Which are you saying works best for which?
Old 03-29-2018, 02:34 AM   #87 (permalink)
Member # 830074
If there was a 47 radial or 44 radial or 54 radial. Hands down the radial out perforrms a bias all day. One of these days all the guys on this forum need to get together and see what reaslly works and what does not. Im limited kinda on axle size. I run yota stuff . Im also reaslly easy and not a basher as i think finesse in snow all day except sugar/powder works better. We have sierra cement.lol. were there is so much forward bite sometimes. So i can not run much larger than the 42 mtr. I would like to try a 46 claw
Old 03-29-2018, 02:37 AM   #88 (permalink)
Member # 830074
Here you go brandon
If you took a level do you think there an inch taller
Old 03-29-2018, 07:25 AM   #89 (permalink)
Corey Young's Avatar
Member # 21622
Nokian Tire company in Finland makes a 46" Radial winter tire for Arctic Truck company. I have not had any luck getting a price or a set to the US. Arctic Trucks does alot of tours in Antarctica and they have the tires made just for their trucks.
http://arctictrucks.com/news/News-Ar...-create-a.aspx
Old 03-29-2018, 07:39 AM   #90 (permalink)
Member # 135279
About 1.5" taller and over 7" wider. That's a new mtr also.
Old 03-29-2018, 07:41 AM   #91 (permalink)
Member # 135279
There sugar snow we have up here will never hold any power.
Old 03-29-2018, 08:05 AM   #92 (permalink)
Member # 830074
1049 per tire also only 42.6 i nches tall. Its basicly a 44 cepek with a waaay knarly rubber compound that stays gummey at below freezing temps. If you go on alibaba tire you can buy them for 98 per tire but have to buy 300 at a time.
Old 03-29-2018, 08:09 AM   #93 (permalink)
Member # 830074
I hear ya. Here niether but you can only make it with lots of momentum and wheel speed. I went up to kelowna a few years back thats how there snow was no moisture at all seemed like. Thats why those guys run 800+ hp and 46- 54 inch baja claws
Old 03-29-2018, 08:27 AM   #94 (permalink)
Member # 21622
Group buy?
I thought they made a 46" version.
Old 03-29-2018, 09:04 AM   #95 (permalink)
Member # 135279
Group buy?
At $98 a tire I'm in.
Old 03-29-2018, 09:36 AM   #96 (permalink)
Member # 830074
Only need. 299 more
Old 04-03-2018, 12:42 PM   #97 (permalink)
Member # 7412
hell ill take a dozen
m35A2C 4x4 sitting on 49" R2s,suburban 454/465/205 43" ag tires,Durango on tons and 40s
gunracer1 is offline   Reply With Quote Quick reply to this message
Old 04-04-2018, 09:17 PM   #98 (permalink)
86chevyjoe's Avatar
Member # 128588
Attachment 2845026
Attachment 2845018
This is track of 44” STS that is bias ply. Has the same mounds that you speak of with your radial iroks. Couple wraps of duct tape on inner bead holds just like normal beadlock
Old 04-04-2018, 10:45 PM   #99 (permalink)
Member # 135279
That's about 1psi and several feet of snow. After doing a little grooving the tires really woke up.
Old 04-05-2018, 09:37 AM   #100 (permalink)
TimCubed's Avatar
Member # 220897
Chevy Joe: With the horizontal thread design I'm surprised you have to groove the STS's at all. I'm thinking anytime you get cupping in the tracks you are getting max traction. It would be a great comparison to have the same tire bias vs. radial.
