post up your grooved snow tires - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Snow Wheelin'
Register Blogs FAQ Community Calendar Premium Memberships
Old 04-05-2018, 05:45 PM   #101 (permalink)
Member # 135279
Originally Posted by TimCubed View Post
Chevy Joe: With the horizontal thread design I'm surprised you have to groove the STS's at all. I'm thinking anytime you get cupping in the tracks you are getting max traction. It would be a great comparison to have the same tire bias vs. radial.
Those are my tires I just had Joe post the pic. The tires work really well stock, but they really woke up once I start doing some grooving. I'm actually planning on grooving some more lateral grooves for sidehilling, cornering, Etc.
shrek tits is offline   Reply With Quote Quick reply to this message
Old 04-05-2018, 11:45 PM   #102 (permalink)
thefixxer's Avatar
Member # 422178
Originally Posted by 86chevyjoe View Post
This is track of 44” STS that is bias ply. Has the same mounds that you speak of with your radial iroks. Couple wraps of duct tape on inner bead holds just like normal beadlock
Where exactly are you putting the duct tape?
WILLYS FEVER
-1941 slatt grill
-1944 GPW
-1946 2A
-1948 2A
-1951 M38
-1954 diesel 3B
thefixxer is offline   Reply With Quote Quick reply to this message
Old 04-06-2018, 06:55 AM   #103 (permalink)
Member # 135279
On the inside bead of the wheels. 3 wraps of Gorilla tape is what I'm running with good results.
Old 04-06-2018, 07:30 AM   #104 (permalink)
86chevyjoe's Avatar
Member # 128588
Send a message via AIM to 86chevyjoe
The radial would be better hands down but the tire would probably weigh at least 20lbs heavier, at least in the 44” version.
See pic
I like to snow wheel
86chevyjoe is offline   Reply With Quote Quick reply to this message
Old 10-12-2018, 07:49 AM   #105 (permalink)
Member # 80235
Started grooving my rzr’s summer tires, cutting weight more than anything. 33x10.5R15 Dick Cepek extreme country’s
How much weight did you shave off for the RZR?
MOLOTOV 2 Build
95' X-cab 4.3 Vortec, duals, SAS, CUSTOM
OregonYO is offline   Reply With Quote Quick reply to this message
Old 10-12-2018, 09:46 AM   #106 (permalink)
86chevyjoe's Avatar
Member # 128588
close to 5lbs a tire. I took pics before and after on the scale but since I don't have a star anymore I cant post pictures. grooved tire + beadlock weigh just under 60lbs total
Old 10-17-2018, 08:20 PM   #107 (permalink)
rapier46's Avatar
Member # 165420
Gentlemen, I bought an ideal groover and I want to either groove my tires of just sipe them. I’m leaning toward siping them, i daily drive and wheel the truck all year and don’t want to lose too much tire life, or make them shitty for summer wheeling. But I’m thinking everything I do will help for all year traction
. If I flip the blade upside down on the ideal groover, will that be enough? Just straight sipes? Most snow tires have sipes that are like this /\/\/\ but I don’t know how to achieve that efficiently.
I have these tires
Where is the best place to sipe them and or groove them? Which direction on which lugs? If grooving is the way to go, I will do that.
Groove the big center lugs and sipe them all?
Get some
rapier46 is offline   Reply With Quote Quick reply to this message
Old 10-19-2018, 11:28 PM   #108 (permalink)
Member # 104383
Those look pretty good grooved up but I might try them stock first. I think the biggest drawback is that square edge on the tread. Maybe not though. No scientific research to confirm but I think it makes a stress point in the contact patch and breaks through the crust.
WILLD420 is offline   Reply With Quote Quick reply to this message
Old 10-31-2018, 09:30 PM   #109 (permalink)
rapier46's Avatar
Member # 165420
These tires actually didn’t do too bad on the ice as they are. Just siping may be all they need. When at 7 psi they squish out pretty well, 5 will be better. But there was lots of dry stuff so I couldn’t go too low this weekend.
Got my groover too, going to sipe them and see what works.
Get some
Old 11-01-2018, 10:15 AM   #110 (permalink)
Member # 711425
For what it’s worth everyone has different ideas, but for snow grooving I tend to use a #2 blade in my ideal groover which gives more of a heavy sipe than a groove. I use the #4 inverted for siping which works well. I’m just in the process of hitting my iroks up for this winter.
Scoobynorth is offline   Reply With Quote Quick reply to this message
Old 11-01-2018, 11:57 AM   #111 (permalink)
86chevyjoe's Avatar
Member # 128588
i would use a #2 blade and follow the stock siping the tires came with; looks like a good pattern.
Old 11-02-2018, 09:03 AM   #112 (permalink)
rapier46's Avatar
Member # 165420
Alright. I did 2 last night and came up with this. #4 blade I grooved the center lugs and siped everything. I followed the factory “siping”
Before
After
Get some
Old 11-03-2018, 06:19 PM   #113 (permalink)
rapier46's Avatar
Member # 165420
Ok I finished the rest and added some grooves on the outer lugs to give a couple more edges.
Can’t see the siping yet but I think it will open up a bit.
Get some
Old 11-03-2018, 06:19 PM   #114 (permalink)
rapier46's Avatar
Member # 165420
Get some
Old 11-05-2018, 12:59 AM   #115 (permalink)
rapier46's Avatar
Member # 165420
Here it is after about 150 km and one wheeling trip
Get some
Old 11-10-2018, 06:39 PM   #116 (permalink)
rapier46's Avatar
Member # 165420
We got a sad inch of snow but I went out anyway. Wanted to see how these tires hook up on slick stuff. They work pretty well. I almost want to groove them a little more.
Here’s a little clip of me going up a little hill that others has been spinning up. I crawled up this and some even steeper stuff no problem.
https://youtu.be/BS5nvtkBzG0
Snow sticking in the grooves
Get some
Old 11-11-2018, 10:26 AM   #117 (permalink)
Member # 80235
I met some cool guys snow wheeling, and they had some shit that worked really well. The first pic is some grooved Nitto MGs that worked really good, I noticed the groove pattern basicly turns each lug into smaller knobbies. So pic #2 is my SX grooved out, these will be snow only tires.
MOLOTOV 2 Build
Old 11-11-2018, 10:52 AM   #118 (permalink)
Member # 80235
On a 2nd note about groovers, I borrowed a Ideal, and have compared it to my my Fein multitool. I preheated the ideal, it does good on a shallow groove, like 1/4", but for a deep groove it really struggled. I tried heating the lugs, and noticed after the first cut the lug was pretty warm already. My SXs are not new so the rubber is probably harder than normal.
So on to the multitool, I built a couple blades by taking a worn out fine tooth fein blade, heating a narrow line across it with a torch, bending it into a U shape, reheating it to RED and quenching it in ATF, then sharpening the edge on a belt sander.
Comparing it to the ideal, which I would say does about 1" per second. The multitool is crazy fast. On a shallow groove like 1/4"-3/8" it goes so fast I was accidentally cutting the next lug. And on a deep groove, 1/2"-3/4" it was still double the speed of the ideal.
I will say a couple of the first blades I made for the fein were not nearly as fast as the most recent Ive made, Blade length (front to back) doesnt seem to have an effect on the speed, only thing I can think of is that I belt sanded the whole blade to polish it up, maybe less friction.
MOLOTOV 2 Build
Old 11-11-2018, 06:07 PM   #119 (permalink)
rapier46's Avatar
Member # 165420
Have any pics of how you’ve made the blade and of it attached to the tool? Now I’m curious
Also is that 89snowplow? Looks like his rig before he painted it blue
Get some
Old 11-11-2018, 08:15 PM   #120 (permalink)
Member # 80235
The blade on the tool is actually broke, but still works good, I think the hardening process made it brittle, and broke after cooling off. Only downside is I usually sharpen the backside too, so you can cut pulling the tool tword you also. The 2nd blade was made to have a more square cut.
I dont know about 89snowplow, all I know he lives in eastern OR
MOLOTOV 2 Build
Old 11-11-2018, 09:14 PM   #121 (permalink)
rapier46's Avatar
Member # 165420
I had to google it to find out how it works. Interesting. Great idea if you have one of those tools but they’re twice the price of an ideal. But if it’s also way faster it’s worth it. Very cool.
Get some
Old 11-11-2018, 09:37 PM   #122 (permalink)
Member # 80235
Its got a tone of uses, windshield knife, sander, undercutting door jambs for floor covering, removing grout.
Here you go: https://www.harborfreight.com/variab...ool-63111.html
MOLOTOV 2 Build
Old 11-13-2018, 11:51 PM   #123 (permalink)
rapier46's Avatar
Member # 165420
What is my best option to make these tires better on side hills? I noticed they do have a bit of a weakness there.
I was thinking maybe adding some more grooves. I have #2 and #4 grooving heads now. I used #4 for all my grooving so far.
What are the thoughts on grooving like this with my #2 head, so the groover would be smaller.
A
B
C
D
Get some
Old 11-14-2018, 11:24 AM   #124 (permalink)
86chevyjoe's Avatar
Member # 128588
B for sure. A + C hurt your forward traction. wish I could post pics - I will send you a pic on Instagram of what i'd do
Old 11-14-2018, 02:01 PM   #125 (permalink)
rapier46's Avatar
Member # 165420
Awesome man sounds good. My new instagram is letsgobeau
Get some
