Snow unlocking hub dial - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Snow Wheelin'
Old 04-22-2018, 09:09 PM   #1 (permalink)
wes761's Avatar
Member # 227979
Anyone else have problems with lockout hub dials getting unlocked due to snow pack turning them? It usually only happens to me a couple times a season when the snow pack starts to melt and the ditches are soft and drag you in. Yesterday I had my passenger side unlock several times and it's time to come up with a solution. My first thought is to try a fernco cap w/hose clamp to cover the dial.... any other ideas?
Drive flanges would be a solution, but I travel on the highway too often. I would also prefer a lockout to be a fuse when snow wheeling.... easier to change on the spot than a shaft, especially when it's below freezing.
01' Tahoe, D60hp & 14b both lock'd & link'd w/coils, 4.56's, NP241, hydro assist, 41.5" PBR's
wes761 is offline   Reply With Quote Quick reply to this message
Old 04-22-2018, 09:16 PM   #2 (permalink)
YotaAtieToo's Avatar
Member # 25632
3" wheel spacers
There was a guy making rock rings for Toyota hubs, that might help.
Old 04-23-2018, 04:03 PM   #3 (permalink)
Member # 135279
You sure it's not your buddies? That sounds like the shit my crew would do.
shrek tits is offline   Reply With Quote Quick reply to this message
Old 04-23-2018, 04:32 PM   #4 (permalink)
wes761's Avatar
Member # 227979
I wheel solo majority of the time.... good call though
Old 04-23-2018, 09:07 PM   #5 (permalink)
Member # 25632
I've seen it happen before. Most Toyota guys dont have that problem since they're all running offset wheels, spacers, ifs hubs or a combination of them.
Old 04-23-2018, 09:18 PM   #6 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Take the cap off and see if the shaft is hitting the inside of the dial.
total newb is online now   Reply With Quote Quick reply to this message
Old 04-24-2018, 04:51 AM   #7 (permalink)
wes761's Avatar
Member # 227979
Just had them off, not hitting.
It's almost always the passenger side, which makes sense with forward rotation of the tire vs dial. I've swapped hubs brands/styles without luck.... haven't tried yukons yet.
I'm thinking some sort of cap/cover or even duct tape might do the trick. Wonder if the d60 is more susceptible since the surface area of the dial is double of everything else out there.... more snow contact and leverage.
Old 04-24-2018, 06:59 AM   #8 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
It’s the shaft hitting. Pull the cap put grease in the cap and I bet you’ll see it’s hitting
Old 04-24-2018, 08:05 AM   #9 (permalink)
wes761's Avatar
Member # 227979
Why would it matter? The shaft, hub, hub internals and cap are all locked moving together, how would the shaft touching the cap turn the dial when it's all locked together moving the same direction? It might actually help hold it locked by creating some resistance in the dial.
I only have issues with this in specific warm densr snow conditions. Never in rocks, sand, mud or cold powder snow. It's happened over several years, different hubs, and different shafts, always this time of year.
Old 04-24-2018, 09:35 AM   #10 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Ok I see your point. I have heard of the passenger side locking when just going down the road.
I think I’d try to come up with a “guard” to go around the hub to see if that stops it. Or just some duct tape before you come up with something more permanent.
Old 04-24-2018, 09:46 AM   #11 (permalink)
Member # 25632
I'm for some reason I thought this was in the Toyota section.
For a 60, just get Yukon Hubs, they're kinda hard to unlock. Impossible with a load on them.
Old 04-24-2018, 10:55 AM   #12 (permalink)
snowracer's Avatar
Member # 141697
buddy had it happen a few times on his 60 with warn hubs and always the pass side. once he went with a wider offset rim the hub was farther in and was not an issue anymore. another guy in our group runs rims with less offset so hub is almost flush with the outer rim bead and runs yukon hubs with zero issues.
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote Quick reply to this message
Old 04-24-2018, 12:24 PM   #13 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
This the toyota section, he just simply swapped out all the inferior Toyota parts
And yes the Yukon hubs are are impossible to unlock with a load on them.
Old 04-24-2018, 02:12 PM   #14 (permalink)
Member # 708218
This worked for me, (duct tape) had same issue awhile back and have since switched to drive flanges. The heavy spring snow would do it.
Edit-for the record the hubs were just regular warns on a D60, Im sure if they were premiums or any other brand it wouldve been a non issue as the plastic hub insert is quite easy to turn on the warns.
FullTilt N HillBilt
HILLBILT is offline   Reply With Quote Quick reply to this message
Old 04-27-2018, 05:44 AM   #15 (permalink)
BobCat5.0's Avatar
Member # 136221
The warn rear full floater kit had locking hubs with set screws to keep them from unlocking ,maybe could do something similar ?
BobCat5.0 is offline   Reply With Quote Quick reply to this message
Old 04-28-2018, 04:59 AM   #16 (permalink)
Member # 19251
I've been running drive flanges on the front of my Jeep with a Detroit locker for roughly 15 years and have never owned a tow rig. Pavement is a non issue.
microtus is offline   Reply With Quote Quick reply to this message
Old 04-28-2018, 07:58 PM   #17 (permalink)
wes761's Avatar
Member # 227979
I'd rather not run my homemade front driveshaft and longfield spindle bushings at 65 mph every weekend going to the trails. Used duct tape today and it worked like a charm.
