Mickey Thompson MTZ P3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Snow Wheelin'
Old 11-01-2018, 04:27 PM   #1 (permalink)
rockhog's Avatar
Member # 1655
Anyone having good luck with this tire in the snow?? 35x12.5x15's
97 Jeep TJ/4.0/5 speed/Atlas 5.0/4.56 ARB's/35" MTZ's/RE LA 4.5
rockhog is offline   Reply With Quote Quick reply to this message
Old 11-11-2018, 08:46 PM   #2 (permalink)
Member # 104383
They don't look all that great.
Are you talking deep snow, or just hub deep, or driving on snow that is on pavement?
Three very different end-uses.
For deep snow. No. They aren't very aggressive and the tread has a very square edge on it. Might not float for crap. Also M/T tires are like several others made by Cooper, they run small. You are paying for a 35 but only getting a 33.7-34.1" tall tire.
For hub deep snow, they will probably be o.k. as long as it's not super slushy and cold so it turns to ice as soon as you slip a tire.
For snow on pavement. They might be o.k. but not as good as a heavily siped all terrain or mud tire.
WILLD420 is offline   Reply With Quote Quick reply to this message
Old 11-11-2018, 10:03 PM   #3 (permalink)
rockhog's Avatar
Member # 1655
Thanks for the reply. For snow depth was talking hub to deep snow use. Granted it only going to work so well for a 35" tire on a non beadlocked wheel. I have not had them up to the snow yet but looking forward to it if it ever snows this year. The tire also is bigger than the Copper STT Pro in the same size. Its wider as well. Its right a 13.1" wide.
2017-08-30_07-03-36 by ronfasano, on Flickr
Old 11-12-2018, 08:03 AM   #4 (permalink)
86chevyjoe's Avatar
Member # 128588
Send a message via AIM to 86chevyjoe
its a 35" MT radial - it will perform along the same lines as every other 35" radial MT.
guy here in WA runs them on his Comanche, gets around just fine
I like to snow wheel
86chevyjoe is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 03:28 PM   #5 (permalink)
xjtony's Avatar
Member # 50866
I run them on my 85 Chevy k10, but only snow depth it sees is a few inches in the roadways from time to time. Works fine for that anyway...
Low Budget Sammy
xjtony is offline   Reply With Quote Quick reply to this message
