Dodge dakota 4x4 on 285/60r17s in snow/ice - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Snow Wheelin'
Old 02-22-2019, 10:11 AM   #1 (permalink)
Member # 322034
Hey dudes. Tried to go into Big Bear yesterday but had to turn around because truck was overheating uphill (changed radiator, broke fan in process, so, no fan)
However while going up, I did observe that I was sliding a whole lot. I did buy chains (diamond pattern) but didn't get deep enough to put them on.
I realize that this is a pickup truck and a 285/60r17 is a pretty wide tire so I will be more likely to float. Is there anything I can do to make this setup be OK in snow/ice, like chain up all 4 tires, or should I just take a different vehicle up there (1997 cummins DRW with stock sized tires, can remove outer wheel).
I want to try going back up next week (WITH a fan!) but don't want it to be a disaster. I don't have a built rig at the moment, just these two trucks..
montrose818 is offline   Reply With Quote Quick reply to this message
Old 02-24-2019, 07:17 AM   #2 (permalink)
Member # 67823
Put chains on it and drive it. How much snow are we talking? My basically stock 500,000+km '92 runner on 31x10.5s with a locked rear and real chains, not cable BS, will push through bumper deep powder, and dig through a foot plus of crusty shit.
Big diesel Ford, a stable of white toyotas from '84-08, and a bw200. They all need work.
squamch is online now   Reply With Quote Quick reply to this message
Old 02-24-2019, 03:50 PM   #3 (permalink)
Member # 322034
I'll be on roads, but likely with an icy build up. Don't plan on offroading, just getting around town. I think your 10.5s have a good inch less width than mine.. I just noticed a whole lot of sliding with my truck, and there are hills involved going to the destination, so I need to make sure I am good.
There was a guy with an H2 and chains who had to turn back down the hill, he said he couldn't make it into town. The only guy who wasn't complaining had studded tires, but that's not going to work for me.
Old 02-24-2019, 04:20 PM   #4 (permalink)
Member # 67823
Studded tires work great.
You haven't told us what you drive yet.
And never count on anyone in an h2 to be anything but a mouth breather.
Old 02-25-2019, 10:08 AM   #5 (permalink)
Member # 322034
its in the subject.. a 4x4 dodge dakota
its a 2000 with a 5.9 if you want the details, red
I kind of have it set up for pavement duty with the 285s, and worry its too much surface area on ice.
I don't go into the snow often enough to buy studded tires, although its tempting
Just wondering if I'll be OK with chains despite the tire width?
Old 03-31-2019, 05:33 AM   #6 (permalink)
Member # 866364
Contrary to the old wisdom, surface area on ice is not the problem. I have lived in North Dakota for 25 years. Chains are great if you have the clearance, the front is more critical, see where your tires are at full lock, depending on the chains you need 1 1/2" clearance from the tire. I have a set of chains I made from tractor chains when it gets really bad.
I found that siping makes WAY more difference. On my 72 W200 I used to run 33" mud tires. Almost got me killed on ice and have been running 285 Hankook's for a long time. I can go thru about 2 feet of the HARD crusty crap before I start having problems. An 8000 lb truck is not gonna float much anyway, I added a CM trailers steel flatbed and add about 1000 lbs of sandbags in the winter, that really helps for plowing snow.
The big problem with wide tire that grip alot is having the power to turn them in the deep stuff.
Bad Bob1 is offline   Reply With Quote Quick reply to this message
Similar Threads
Big time Dakota build RXT Dodge 57 05-03-2017 11:43 AM
2002 dodge 3500 4x4 diesel 6speed Slt Laramie 94ifs Vehicles and Trailers For Sale 8 03-03-2014 11:43 AM
2003 Dodge 3500 (SRW) 4x4 6 Speed $20,500 (Very Clean) 1fast67 Vehicles and Trailers For Sale 3 01-29-2014 07:10 AM
03 Dodge 2500 HO 4x4 Cummins QCSB 133k miles (trade for 3500) zayne2427 Vehicles and Trailers For Sale 3 09-10-2013 05:15 AM
