47" ltbs for snow - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Snow Wheelin'
Old 08-14-2019, 11:51 AM   #1 (permalink)
snowracer's Avatar
Member # 141697
47" ltbs for snow
just got a set of 47 ltbs and plan on running them for snow wheeling only. i know the ltbs are big heavy stiff tires and not the best for snow but i won them so have very little money into the set. looking for ideas on best way to groove them up to make them work better.
flame suit on
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote Quick reply to this message
Old 08-15-2019, 11:08 AM   #2 (permalink)
86chevyjoe's Avatar
Member # 128588
Send a message via AIM to 86chevyjoe
flame suit on
those tires are garbage in the snow, expect to dig to china. they are so stiff they wont flatten out under anything sub 5000lbs.
sell them and use the money to purchase different snow tires
I like to snow wheel
86chevyjoe is offline   Reply With Quote Quick reply to this message
Old 08-15-2019, 11:19 AM   #3 (permalink)
snowracer's Avatar
Member # 141697
my rig is closer to the 6000 pound mark, and they will be better then the cut 44 boggers ive been running.
got them so going to try and make them work
PLAN-B F250 on 44s
Old 08-15-2019, 12:06 PM   #4 (permalink)
snowracer's Avatar
Member # 141697
found a few pics of grooved ltbs
and this one looks like might be better for snow
PLAN-B F250 on 44s
Old 08-15-2019, 12:25 PM   #5 (permalink)
YotaAtieToo's Avatar
Member # 25632
You need some full depth cuts to help them flex, then some smaller grooves or sipes for traction.
Then you really need to break them in, run 0 psi and drive the shit out of them. Definitely will need some beadlocks.
I've heard some people say they work well on heavy rigs, so you'll probably be good. Plus you aren't trying to float on 6' of fresh powder like in norcal and the pnw.
Old 08-15-2019, 02:24 PM   #6 (permalink)
snowracer's Avatar
Member # 141697
waiting to hear back on the cost of doing inner air locks on them as they are 16.5 so might be a better option when running 1-3 psi in the snow. otherwise will be round stock welded on for inner bead and weld on for the outer bead like my boggers. normally the snow we play in is not light fluffy powder and no deeper then waist deep
PLAN-B F250 on 44s
Old 08-15-2019, 04:24 PM   #7 (permalink)
Member # 25632
fuck inner tube bead locks, they are a huge pita to mount, and like to spin on the wheel and rip the stems off at low pressure.
Hummer beadlocks cheap, light (once you get rid of the run flat and don't use 1/2" thick centers) and double beadlocked. Just get the old 8 bolt version and don't worry about rock rings if they're only for snow.
Our snow is usually heavy powder (like the stuff that sticks easily into a snow ball) since it's usually not that cold when it snows here (low 30s to high 20s) in which you usually need big flexible balloon tires to float on top as much as possible.
Old 08-16-2019, 09:33 AM   #8 (permalink)
86chevyjoe's Avatar
Member # 128588
like jeff said, definitely by cheap hummer beadlocks and use PVC inserts.
i still stick by my first comment lol. there's a reason none of the Kelowna, BC guys run LTB's.
with that said, cut out the wear bars, make sure your cuts are FULL TREAD deep, and sipe the crap out of them. look up how carl jantz cut his, they worked OK for what they were
Old 08-16-2019, 09:37 AM   #9 (permalink)
snowracer's Avatar
Member # 141697
its a little harder to find used military stuff around my parts, can find 20" wheels and all the big stuff pretty easy as there is a market for it around here but not the older 16.5 stuff. would like to do this on the cheap and use what i have so that way if i hate the set up im not out money when i sell them or trade ect. if i was buying new id be looking at a set of 44tsl and cut them up as would work better and know they will fit on my truck no issue.
PLAN-B F250 on 44s
Old 08-16-2019, 11:02 AM   #10 (permalink)
Member # 25632
Fwiw, they are still using 16.5 double beadlocks, so not all of them are "older"
I know people have had decent luck with weld on beadlocks and stauns, but that's a lot of money for what it is.
I still say hummer wheels, if the tires suck. Off the tires and keep the wheels.
Old Yesterday, 02:21 PM   #11 (permalink)
Member # 77630
Run them on my 3200lb single seater. 2 seasons and they are starting to break in. Grooved the crap out of them the second season and that made a huge difference. Don't run them year round or they probably would break in a lot faster. They dig but if you go easy they are ok. They work great on the hard drifts.
"I think that was bad...?"
dickwart is offline   Reply With Quote Quick reply to this message
